Undergrad How Does the Ratio Test Determine Convergence in Power Series?
The ratio test is used to determine the convergence of the power series, with a radius of convergence calculated as R = 3/2, leading to the interval -0.5 < x < 2.5. When evaluating x = 2, it is confirmed that the series converges since the limit remains less than 1. The discussion highlights the importance of substituting specific values into the series to assess convergence. Ultimately, it concludes that the series converges at x = 2, reinforcing the relationship between the power series and the sequence A_n. Understanding these concepts is crucial for analyzing convergence in power series effectively.
Leo Liu
TL;DR
{##A_n##} is a sequence of positive numbers. ##\sum_{n=0}^{\infty} A_n(x-1)^n## has a R of convergence ##R=\frac 3 2##. Does ##\sum_{n=0}^{\infty} A_n## converge or diverge?
I tried to use the ratio test, but I am stuck on finding the range of the limit.
$$\because \left|x-1\right|<1.5=Radius$$
$$\therefore -0.5<x<2.5$$
$$\lim _{n \to \infty} \left| \frac{A_{n+1}(x-1)^{n+1}}{A_n(x-1)^n} \right|$$
$$\lim_{n \to \infty} \frac{A_{n+1} \left|x-1\right|}{A_n} <1$$
$$\lim_{n \to \infty} \left| \frac{A_{n+1}}{A_n} \right|< \frac 1 {\left| x-1 \right|}$$
Then I plotted the graph of 1/|x-1| and I found that the limit of A_n+1/A_n could vary from 2/3 (convergent) to infinity (divergent), as shown by the image below. What should I do next?
What happens if you take ##x = 2##?
Likes etotheipi
No conclusion?
Leo Liu said:
No conclusion?
What does that mean? Is ##2## inside or outside the radius?
Does this show the radius of convergence ##R'## of the series A_n is 2?
Leo Liu said:
It means we have to use another method to test the convergence of the series. 2 is in the radius R.
Eh?
Leo Liu said:
Summary:: {##A_n##} is a sequence of positive numbers. ##\sum_{n=0}^{\infty} A_n(x-1)^n## has a R of convergence ##R=\frac 3 2##.
PeroK said:
Eh?
I think it is in the radius of convergence because ##-0.5<2<2.5##
Leo Liu said:
I think it is in the radius of convergence.
You're saying that you think ##2 < \frac 3 2##?
No, but I am quite confused--we are talking about x, not ##\left| x-1 \right|##, right?
Likes PeroK
Yes, sorry, of course it's inside the radius of convergence. In any case, what does ##x = 2## tell you about ##A_n##?
Likes Leo Liu
Can you please tell me what I should do next? This is not a homework question and I am doing it just for interest.
I've actually told you: put ##x = 2##.
When ##x \geq 2 \: or \: x \leq 0##, the series converges.
Leo Liu said:
When ##x>2 \: or \: x<0##, the series converges.
And what is the series when ##x = 2##?
Converges at x=2?
Leo Liu said:
Converges at x=2?
Write down the sequence for ##x = 2##.
Likes Leo Liu
$$\sum_{n=0}^ \infty{A_n}$$
Likes PeroK
That's what you should have done after post #2.
Likes Leo Liu
Oh, thank you! So it is actually convergent because the limit is less than 1 if we sub in x=2!
In general, the series:
$$\sum_{n = 0}^{\infty} A_n $$
converges, if and only if the power series:
$$\sum_{n = 0}^{\infty} A_n x^n$$
converges at ##x = 1##.
Those two properties are clearly equivalent.
Likes Leo Liu
