A simple trigonometry problem: Put eight coins around a central coin
  • Context: High School
  • Thread starter Thread starter Charles Link
    Trigonometry
37 replies · 10K views
Going back to post 20 for the 3-D problem, I'm going to attempt to post much of the solution here. We have 2 balls at the poles, surround by 5 balls just above the equator, and then 5 balls just below the equator. We can give as coordinates for the centers of one of the balls above the equator as ## (x_1,y_1, z_1) ##, and one just below the equator ## (x_2,y_2, z_2) ##. Let me go to the next post to write those equations, because if I hit the wrong button on the computer, it may delete everything.
Mathematics news on Phys.org
Continuing:
## z_1=(a+1) \cos{\theta_o} ##.
## x_2=(a+1) \sin{\theta_o} \cos(\pi/5) ##.
## x_1=(a+1) \sin{\theta_o} ##.
I think I've listed them all now. The rest was just to solve this set of equations, which we did. You eliminate ## \theta_o ##, and all of the other variables, and solve for ## a ##. (The last two in post 32 really count as one).
Charles Link said:
Edit 2: and if it is fairly straightforward I do welcome anyone who will make the effort to compute it for the case of a dozen outer spheres, and see if they agree with the result that ## a \approx 1.10 ##.
I appear to no longer understand what we are talking about, and have not since I saw this post.
Is 'a' the radius of the outer spheres?
In that case, I can only see 'a' as being equal to 1.
A slightly indirect way to do it is to observe that each corner of an icosohedron is surrounded by five equilateral triangles. The outer five edges of those five triangles form a pentagon of side ##2a##, where ##a## is the radius of the outer balls. The center-to-corner distance of the pentagon is ##P## and satisfies ##a/P=\sin 36##. But the distance from a corner to the center of the ball above the center of the pentagon must be ##2a##, so the ball's center is a distance ##z## above the plane of the pentagon, where ##z^2+P^2=(2a)^2##. So ##z=\sqrt{4-\mathrm{cosec}^2 36}a##.
We can then place the center of the inner ball (radius ##b##) a distance ##z'## directly below the center of the pentagon. We require ##z+z'=a+b## and ##z'^2+P^2=(a+b)^2## so that the outer balls all touch the inner one. If I've set that up correctly, I get that $$\begin{eqnarray*}
b&=&a\left[\frac{2}{\sqrt{4-\mathrm{cosec}^236}}-1\right]\\
&\approx&0.902a
\end{eqnarray*}$$
Reply
  • Love
Using an identity from the Math Stack exchange: ## 4 \cos^2(\pi/5)=2 \cos(\pi/5)+1 ##, I was able to show that the solution @Ibix would have for for ## a ##, (post 35), is identical to mine in post 20, ( with ## b=1 ##). (It takes a little algebra to show that they are the same). Very good @Ibix :)
In the 2-D case, you can put 6 pennies around a penny in the center, and ## a=b ##. It perhaps would be a neat thing to have a 3-D case where you could put 12 balls around a center ball, all of the same size, but we find with some calculations (e.g. see post 20 and @Ibix post 35) that nature/mathematics didn't work this way, but instead ## a \approx 1.108 ## when ## b=1 ##.
I just realized that you can put 12 balls around a center ball two different ways, so.... , NEVER MIND!
(It was in your next post!)
Number of spheres in the outer layers going down the y axis
I swear, that even in my mid-sixties, I'm still as impatient as I was at 12.
Reply
