A solid non conducting sphere
The discussion revolves around calculating the total charge and electric field of a solid nonconducting sphere with a nonuniform charge distribution defined by ρ = ρsr/R. Participants are tasked with proving that the total charge on the sphere is Q = πρsR^3 and that the electric field inside the sphere is given by (kQr^2)/R^4. There is confusion regarding the integration process, particularly in distinguishing between the variables r and R, which is causing difficulties in setting up the integral correctly. Users are seeking clarification on the integration steps and assistance with resolving the discrepancies in their calculations. The conversation highlights the challenges faced in understanding charge distribution and electric field derivations in electrostatics.
Liquidxlax
A solid nonconducting sphere of radius R carries a nonuniform charge distribution, with a charge density ρ = ρsr/R, where ρs is a constant and r the distance from the centre of the sphere. Show that
i) the total charge on the sphere is
Q= πρsR3
and
ii) the electric field inside the sphere is given by
(kQr2)/R4
Qenc = integral(dQ) = inetgral(ρdV) = ρintegral(dV) = ρV =
((Q4πr3)/3) / ((4πR3)/3) = Q(r/R)3
dA = 4πR2dr
ρdA = 4πρsrRdr
integrate r from 0 to R but i have a 2 in front.
You're confusing r and R when setting up your integral.
even when i do it that way, I'm left with 2 in front and then R^2
i really need help with this one. my prof is fluffing everyone off.
please and thanks :)
Show your work. I'm not sure exactly what you did.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 18 ·
  • · Replies 18 ·
10K
