A square matrix A with ker(A^2)= ker (A^3)
  • Thread starter Thread starter yeland404
    Matrix Square
11 replies · 7K views
yeland404
a square matrix A with ker(A^2)= ker (A^3), is ker(A^3)= ker (A^4),verify...
micromass said:
What did you try already??
it means that A^2*vector x= 0 and A*x=0 has same result,then I really confused how to do the next step
No, it means that
[tex]A^2x=0~\Leftrightarrow~A^3x=0[/tex]
You need to prove that
[tex]A^3x=0~\Leftrightarrow~A^4x=0[/tex]
micromass said:
No, it means that
emm..., to the difinition it says that ker(A) is T(x)=A(x)=0
Yes, but you're not working with ker(A) here, but with ker(A2).
should define a matrix A and write A^2 as dot product of A & A,and also to A^3...it seems to be so complex, or use the block to divide the matrix into some small matrix?
Do you understand my Post 4??
so times A on both side of the equation?
No, you need to prove two things:
If [itex]A^3x=0[/itex], then [itex]A^4x=0[/itex]. This can indeed be accomplished by multiplying sides with A.
But you also need to prove that if [itex]A^4x=0[/itex], then [itex]A^3x=0[/itex].
so Ker (A^2)=0 can lead to Ker(A^4)=0,then?
NO ONE has said that Ker(A^2)= 0 so I do not understand why you are asking this question. You seem, frankly, to have no idea what the question is saying. ker(A^2)= ker(A^3) means, as micromass said, "A^2x= 0 if and only if A^3x= 0". You want to use that to prove "A^3x= 0 if and only if A^4x= 0". As micromass said, the first part is easy: if A^3x= 0 then, applying A to both sides, A^4x= A0= 0 which proves that ker(A^3) is a subset of ker(A^4). You still need to prove the other way: if A^4x= 0, then A^3= 0. You cannot just multiply by A^{-1} because you have no reason to think that A is invertible. But notice that ker(A^2)= ker(A^3) has not yet been used so it might help to note that A^4x= A^2(A^2x).
