A strange kind of straight line kinematics with uniform acceleration.
The problem involves kinematics with uniform acceleration, specifically analyzing the motion of a ball thrown upward from a height of 30 meters and its subsequent descent over a total time of 6 seconds.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the separation of the motion into upward and downward phases, questioning how to apply kinematic equations with missing variables. There is exploration of the initial velocity and the total distance traveled.
Some participants have provided guidance on using specific kinematic equations, while others have pointed out the importance of correctly identifying known and unknown variables. Multiple interpretations of the problem setup are being explored, particularly regarding the direction of acceleration.
Participants note the challenge of having two unknowns in the equations and the implications of defining the coordinate system, including the choice of positive and negative directions for acceleration and displacement.
ZamielTheGrey
A ball is thrown upward from a building 30 meters tall and misses the edge on its way down, hitting the ground 6 seconds after it was thrown.
A) With what speed was it thrown?
B) What is its highest height?
Vf = Vi + at
x = 1/2(Vi + Vf)
x = Vi t + 1/2(at^2)
Vf^2 = Vi^2 + 2ax
Vf = final velocity
Vi = initial velocity
a = acceleration
x = distance
t = time
So, it is a two part problem, the upward motion, and then the downward.
I will label the distance from being thrown to the highest point of the arc as x1, which is also the same distance down to being level with where it was thrown from, and then x2 is 30 meters.
Thus goes that to find time, I need to use x = Vi t + 1/2(at^2).
xtotal = x1+30
Vi = 0
t2 = 6 - t1
a = 10 (lets make positive downward)
So here I am stumped by the fact that I do not have three known variable to make use of the equation. How am I supposed to proceed?
Make use of this form of the equation.
x = x0 + v0t + 0.5at2
[edit- you are trying to find v0]
Yeah... so we have two missing variable then. An X and Vo :O
If the x-axis represents height, you know x0 and you know the final x. v0 is the only unknown. Totally solvable.
If I take the base of the skyscraper as the start of the x axis, the ball is thrown up from 30m.
x0 = 30m
xfinal= 0
That completely ignores the up and then down arc of the ball, what am I not understanding?
The up and down arc is not relevant. Let the equation do the work.
[edit-- "a = 10 (lets make positive downward)". If +x is pointing up, then a should be negative.]
So...
-30 = V0 + 0.5*(-10*62)
-30 = V0 - 180
150 = V0
Is this it?
Close! You dropped the "t" from v0.
Oh, oops.
-30 = V0*6 + 0.5*(-10*62)
-30 = V0*6 - 180
150 = V0*6
V0 = 25
Alright, great, thanks. The second part I can easily do on my own. :)
Good!
