A version of the twin paradox without accelerations
The discussion revolves around a variant of the twin paradox in special relativity, focusing on a scenario where two observers, Bob and Alice, synchronize their watches while Alex travels between them. The conversation explores the implications of time dilation, synchronization of clocks, and the effects of relative motion without acceleration.
  • Bob and Alice synchronize their watches using a light signal, but this synchronization may not hold in all reference frames due to length contraction, as noted by some participants.
  • Alex's perspective on the synchronization of watches differs from Bob and Alice's, leading to a debate on whether Alice's watch is ahead when Alex passes her.
  • Some participants argue that the method of exchanging light pulses introduces personal choice and is not free from ambiguity regarding clock synchronization.
  • Time dilation alone does not provide a consistent theory without considering the relativity of simultaneity and length contraction, which are encapsulated in the Lorentz Transformation.
  • There is uncertainty about the feasibility of the experiment as described, with some suggesting that it could yield results under certain conditions, while others assert that absolute synchronization is impossible in a relativistic context.
  • Participants express differing views on whether Alex's watch would show less time than Alice's, with some asserting this is a consequence of spacetime geometry.
  • Suggestions are made about potential modifications to the experiment, such as placing Bob and Alice at the midpoint between their planets for synchronization, but these are challenged as equivalent to previous methods.
Participants generally disagree on the implications of clock synchronization and time dilation in the context of the experiment. While some believe Alex's watch will show less time than Alice's, others argue about the impossibility of achieving absolute synchronization and the effects of relative motion on clock readings.
Participants acknowledge limitations in the experiment's design, including the dependence on the choice of reference frames and the unresolved nature of synchronization methods. The discussion also highlights the challenges of conducting such an experiment with current technology.
  • #61
George Plousos said:
I have no objection to that, but perhaps nature hides surprises as is often the case from the point of view of quantum physics, and a (reliable?) experiment that combines the two theories will test the "twin paradox" in a few years, as long as it does not have the luck of similar experiments that have been abandoned in the past:
That is just a complete and utter intellectual cop-out! Testing the twin paradox is not something that has any relevance to physics in 2020. The whole of modern physics is built on SR, including the models of spacetime and energy-momentum that are tested every day in particle collisions. If you don't understand SR then that's no problem - it's not the easiest thing to learn. But don't pull the "SR might be wrong card" out of your pocket - that doesn't achieve anything.
  • #62
PeroK said:
But don't pull the "SR might be wrong card" out of your pocket - that doesn't wash!
Indeed - in particular, the experiment cited seems to be a test of GR and quantum physics. If I understood right they're building a single-atom interferometry experiment and allowing the two paths to have different flight times due to gravity. This certainly isn't an "intro to SR" twin paradox scenario - it's something much subtler. It can't make the twin paradox anything other than what it is (we've already done that experiment), but may reveal something interesting about the interaction between quantum particles and gravity.
  • #63
Agree. At least I've learned a lot here and the range of my doubts about Relativity is now more limited.
  • #64
Of course you are right, the kinematic effects of SR (and also of GR by the way) including the twin paradox have been tested by experiment to a very high precision. That does not imply that new tests using other contexts have no relevance to physics. The quoted test of time dilation in the context of quantum theory is at least interesting. Of course, I don't expect any surprises here, but still it's interesting and no such test of well-established theory is irrelevant.
Of course, the arguments of the typical "Einstein cannot be right, because it's contradicting my common sense", are unlikely to bring forward anything substantial ;-(.
  • #65
If you need some resources to help you understand relativity better, I'm sure some people here can help you out with that. I can also let you know some pointers I found helpful when I first learned it (I did do a fairly intensive study of relativity, I just had to get a refresher in this thread as it had been a year and a half since I did a relativity problem). If explained the right way, the "paradoxes" start making sense, to the point where they stop seeming like paradoxes.On a different note:
I just laugh at the irony of that argument, as it was precisely Einstein's argument in the EPR paper.
  • #66
Well, it's well known that Einstein was not very satisfied with this infamous EPR paper, but that's another story.
  • #67
I will study your notes, Ibix. In the meantime I have prepared this thought experiment:
I think I can show that the answer to the original question may be different. ……..
Here is Minkowski diagram of your new experiment. Generally it is nothing more then Ibixs picture, maybe with more explanations. It is without scale.
You can arrange the synchonization of Alice and Bobs (Alex and Helens )clocks before, and set it up so, that Bob,Tom and Alex has the zero time at the same event.
You can see, that from Alice, Bob and Tom point of view Helens clocks started earlier (and symmetricaly Alices).
When Bob and Helen meets, Bobs clocks shows 1.x and Helens 2.x , but from Bobs point of view Helens clocks started much earlier, so even if from Bobs view Helens clocks are slower, they shows more.
At the end of experiment, when Alice Tom and Helen meets, Toms clocks show 4, Alice and Helen 4.x, but again their clocks ticks slower (from Toms view), but they started earlier. And also From Toms view Bobs and Alexs clocks show less (3.x) .
  • · Replies 57 ·
  • · Replies 55 ·
  • · Replies 36 ·
  • · Replies 26 ·
  • · Replies 43 ·
  • · Replies 47 ·
