AA battery to lift 1000kg up 1meter
  • Context: Undergrad
  • Thread starter Thread starter one_q_a_day
    Battery Lift
The discussion revolves around the feasibility of using a single AA battery to lift a 1000kg weight by 1 meter. Participants explore the energy requirements, mechanical efficiency, and practical considerations involved in such a task.
  • One participant calculates that lifting a 1000kg rock requires 9800 joules of work, which is nearly equal to the energy stored in a single AA battery (9360 joules).
  • Another participant suggests that using a second battery would be necessary for safety and efficiency.
  • Some participants argue that gearing down the winch could allow the battery to lift the weight over a longer period, making it feasible.
  • Efficiency concerns are raised, noting that the low gear ratio may require more energy than calculated due to losses in the system.
  • There is a discussion about the comparison of mechanical energy to thermal energy, with one participant reflecting on the energy required to boil water versus lifting weights.
  • Several participants mention practical considerations, such as the voltage limitations of the battery and the inefficiencies in converting electrical energy to mechanical work.
  • One participant emphasizes that energy is expended even when supporting the weight, not just during the lifting process.
  • Another participant points out that friction in the mechanical system could affect the lifting capability, suggesting that practical designs may not allow for the proposed scenario to work effectively.
Participants express a range of views on the feasibility of using a single AA battery for this task, with no consensus reached. Some agree on the need for additional batteries or considerations of efficiency, while others question the practicality of the entire approach.
Participants highlight limitations related to efficiency, voltage requirements, and mechanical design, which may affect the theoretical calculations presented.
one_q_a_day
I am on the Earth's surface and I want to lift my 1000kg rock up 1m.
I quickly calculate the amount of work required to accomplish this feat:
1000kg * 9.81 m/s2 * 1m = 9800 kg m2/s2 or 9800 joules
thats really not that much work.
i see from http://www.allaboutbatteries.com/Energy-tables.html" that the energy stored in a single long-life alkaline AA battery is 9360 joules. almost what i need to lift the rock by one meter.
it seems incredulous to me to think that one AA battery could be used to lift a 1000kg rock up one meter. what a i missing?
A second battery.
You're not missing anything - as long as you gear down your winch so it takes 5-10 min to expend its energy, it should work. (but add a second battery for safety factor). There isn't as much potential energy in lifting a weight as most people think...or maybe its vice versa.
There is also a small matter of efficiency, which may be relevant in this particular system because such a low gear ratio is involved. You'd probably really need the second battery - or even more - in practice.
But it goes to show what good value mechanical energy is in 'making a difference' to situations compared with thermal energy. 9800J would only raise the temperature of a cup of water by a few degrees.
sophiecentaur said:
[...] it goes to show what good value mechanical energy is in 'making a difference' to situations compared with thermal energy. 9800J would only raise the temperature of a cup of water by a few degrees.
This brings back a memory.
On a bicycle it's a backbreaking effort to climb a mountain that is 1 kilometer high. Just for the heck of it I calculated how much water could be brought to a boil with the same amount of energy. I had a hard time believing the result; it gave me a whole new respect for my stove's ability to bring a whole kettle of water to the boil in minutes.
I may be too nerdy but things like that make me pleased I have been an engineer!
Meh, I do that kind of thing all the time. My friends give me funny looks when I pull factoids like that out of my...the air...but they are things I get curious about.
Ever calculate how much it costs to make ice in your freezer? If you ever considered turning off the ice maker to conserve energy, you never will again.
I think there's a catch here.
When I'm heating water on a stove then the change of temperature comes from a conversion process: potential chemical energy is converted to heat.
However, in the case of a freezer the change of temperature is effected by transporting heat. Heat is withdrawn from the water in the freezer, and dumped outside the freezer. It is my understanding that the energy cost of heat transportation is less than the cost of conversion.
This means that a simple calculation just looking at the amount of Joules of energy involved in freezing/thawing may well give a higher number than the actual energy consumption of the freezer.
You have to include both the cost of operating the ice-maker and the cost of additional heat load on your homes AC system, of course in the winter the second cost is actually a credit. Did you include these factors in your calculation?
A rather long time for the entire process to happen. If the battery isn't rechargeable, you also have to determine the amount of "work" that is being done by the battery just to support the 1000kg while it's lifting for say 20 minutes at 9.8m/s^2 * 1000kg.
Though it's not technically work, it's energy that's being expended.
As the commercial says: it's in there. That force is the lifting force.
It's just a lot of practical considerations. You need to produce a certain voltage to make a practical motor produce enough torque to really lift the load. The battery is limited to 1.5V. You are not going to be 100% efficient extracting that energy, and not close to 100% turning it into work. In theory, it should be possible, but I would be surprised if it were anywhere close to practical.
The only extra energy expended would be to overcome friction. Your "keeping it up" is a bit of a red herring. If the mass is moving then the force from the motor will be bigger for that reason. The friction in the sort of gearbox necessary for this task (I.e. very low gear) would be enough to prevent the load going down even if the motor were turned off for a while. Practical worm drives can't be made to work the other way round, for instance.
  • · Replies 21 ·
17K
  • · Replies 17 ·
36K
  • · Replies 56 ·
54K
  • · Replies 19 ·
