How can you calculate impedance using the formula Z = R + jX?
  • Thread starter Thread starter chan1
    Impedance
To calculate impedance using the formula Z = R + jX, one must understand that resistance (R) remains constant at 4.7 kΩ regardless of frequency changes, such as at 10 Hz, 100 Hz, 1 kHz, or 10 kHz. The discussion emphasizes that unless a non-ideal resistor model is provided, frequency does not affect the resistance value. The imaginary component (reactance, X) would need to be determined separately based on the circuit elements involved. Therefore, the impedance calculation simplifies to Z = 4.7 kΩ + jX, where X is dependent on the specific circuit configuration. Understanding these principles is crucial for accurately calculating impedance in various scenarios.
chan1
know that the frequency is10hz and 4.7kΩ resistor calculating the impedance in kΩ
i spend half hour on this and still have no idea what to do ,tell me the formula or the step thanks
4.7K ohms.
rude man said:
4.7K ohms.
what about when frequency is 100hz, 1khz 10khz? what's th impedance
thanks
thanks
4.7K ohms. Resistance is independent of frequency unless you were given a model of a non-ideal resistor.
