About computing the tangent space at 1 of certain lie groups
The discussion focuses on calculating tangent spaces at the identity element for specific Lie groups: ##T_ISL_n(R)##, ##T_IU(n)##, and ##T_ISU(n)##. The method involves defining smooth curves ##\gamma : (-1,1) \to M## with ##\gamma(0) = I##, expanding these curves into Taylor series, and determining the tangent vectors ##\dot\gamma(0)##. The tangent space is spanned by these vectors, which can be derived using the canonical Cartesian coordinate system and the properties of skew-symmetric matrices for the special orthogonal group.
  • Understanding of Lie groups and their properties
  • Familiarity with smooth curves and tangent vectors
  • Knowledge of Taylor series expansions in multivariable calculus
  • Basic concepts of matrix differentiation and skew-symmetric matrices
  • Study the derivation of tangent spaces for ##GL(n)## and ##SL(n)## using Taylor series.
  • Learn about the properties of skew-symmetric matrices and their role in Lie groups.
  • Explore the concept of equivalence classes of curves in differential geometry.
  • Investigate the use of canonical coordinate systems in computing tangent vectors.
Mathematicians, physicists, and students studying differential geometry, particularly those interested in Lie groups and their applications in theoretical physics and advanced calculus.
aalma
Hello :),
I am wondering of the right and direct method to calculate the following tangent spaces at ##1##: ##T_ISL_n(R)##, ##T_IU(n)## and ##T_ISU(n)##.
Definitions I know:
Given a smooth curve ##γ : (− ,) → R^n## with ##γ(0) = x##, a tangent vector ##˙γ(0)## is a vector with components ##(˙γ1,..., ˙γn)##.
Two (smooth) curves ##γ,γ': (− ,) → M## with ##γ(0) = γ'(0) = x## are called equivalent if in a certain chart containing x (or in any chart) they define the same tangent vector at ##x##.
We define ##T_x(M)## to be the set of equivalence classes of curves as above. We note that ##T_x(M)## is a vector space: Choose a chart ##a : U → R^n## containing x. Then the assignment ##γ → d/dt (a ◦ γ)(0)## defines a bijection from ##T_x(M)## to ##R^n##. Different charts define different bijections, but they differ by the Jacobi matrix: if ##b : U → R^n## is another chart, the bijections from ##Tx(M)## to ##R^n## differ by the Jacobi matrix at ##a(x)## of the transformation ##b◦a^{−1} : a(U) → b(U)##.
Example: Let ##G = SO(n,R)## and let ##γ## be a curve in ##G## with ##γ(0) = 1##. Then we can write ##γ(s) = 1 + sA + o(s^2)## where ##A ∈ M_{n× n}## and we want to describe possible values for ##A##. Obviously ##γ(s)^t = 1 + sA^t + o(s^2)## so ##1 = γ(s)γ(s)^t = 1 + s(A + A^t) + o(s^2)## which implies that ##A## is skewsymmetric. In the opposite direction, if ##A## is skew-symmetric, ##γ(s) = e^{sA}## is orthogonal and ##e^{sA} = 1 + sA + o(s^2)##. We have proven that ##T_1(G)## in this case is the vector space of skew-symmetric matrices.
Can you please suggest a way to compute such tangent spaces.
aalma said:
Is there a way to calculate the above tangent spaces in a way similar to the example I added?
You need to define curves ##\gamma \, : \,(-1,1) \longrightarrow M## with ##\gamma(0)=x## where ##x=I## is the identity matrix in your case. Then you expand ##\gamma(t)## into a Taylor series, and ##\dot\gamma(0)## will be your tangent vectors. Next, gather so many curves ##\gamma(t) ## such that you cover all ##\operatorname{dim}M## many possible directions to be able to span ##T_x(M).##
The procedure in the link does the same, only that it uses the canonical Cartesian coordinate system:
T_x(M)=\operatorname{span}\left\{\sum_{i,j}^{\operatorname{dim}M} \left. a_{ij} \dfrac{\partial }{\partial x_{ij}}\right|_{t=0} \gamma(t)\right\}
and the obvious curves
\begin{align*}
\gamma \, : \,(-1,1) &\longrightarrow M\\
t &\longmapsto \begin{pmatrix}1 &0 &\ldots &0\\ \ldots &x_{ij}&\ldots&0 \\ 0&0&\ldots& 1\end{pmatrix} \in M
\end{align*}
plus the defining equations, e.g. ##\det(a_{ij})=1## and / or ##(a_{ij}) + (a_{ij})^*=0.##The next problem is to find all curves. These are ##\operatorname{dim}M## many different ones since ##\operatorname{dim}T_x(M)=\operatorname{dim}M.##
In the linked article, I have chosen the easiest ones, still given the Cartesian coordinate system. E.g. a typical element of ##M=\operatorname{SL}(2)## looks like
\begin{align*}
X(t)&=\begin{pmatrix}x_{11}(t)&x_{12}(t)\\ x_{21}(t)&x_{22}(t) \end{pmatrix}\; \\&\wedge \;x_{11}(t)\cdot x_{22}(t)- x_{21}(t)\cdot x_{12}(t)=1\; \\&\wedge \;x_{11}(0)=1\, , \,x_{12}(0)=0\, , \,x_{21}(0)=0\, , \,x_{22}(0)=1
\end{align*}
and a typical curve accordingly
\gamma (t)=X(t)\, , \,\gamma(0)=X(0)=I
Differentiation for those matrices is easier than the full Taylor expansion. We are only interested in the second term evaluated at the identity matrix ##I## anyway. This would be the calculation in equations (26) and (27) for the determinant condition:
\left. \dfrac{d}{dt}\right|_{t=0}\operatorname{det}(\gamma(t))=\left. \dfrac{d}{dt}\right|_{t=0}1=0=\operatorname{trace}\left(a_{ij}\right)
Of course, you can choose your own charts (providing the coordinate system), curves (providing the tangent vectors at ##x=I##), and calculate the entire Taylor series, but the Cartesian charts, coordinate functions ##t\mapsto (x_{ij}(t))##, and the first derivative ##\left(\left. \dfrac{d}{dt}\right|_{t=0}x_{ij}(t)\right)## are likely the easiest you can get. The crucial condition is ##\gamma(t)\in M## with ##\gamma(0)=I.##
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
Thanks. Can you please give more deatils of how to do the calculations with taylor series expansion?
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 36 ·
  • · Replies 73 ·
