Is the Rank-Nullity Theorem Always True for Linear Operators?
  • Thread starter Thread starter geor
    Theorem
The discussion centers on the Rank-Nullity Theorem and its application to linear operators. A counterexample provided by a professor demonstrates that while the theorem states that a vector space V is isomorphic to the direct sum of the image and kernel of a linear operator T, this does not imply that V is the internal direct sum of these subspaces. The confusion arises from the distinction between isomorphic (external direct sum) and equal (internal direct sum) spaces. The professor's example shows that in certain cases, such as when T is an operator from V to itself, the internal direct sum condition does not hold. Ultimately, the theorem remains valid but must be understood in the context of external versus internal direct sums.
geor
Hello all,
In wikipedia, http://en.wikipedia.org/wiki/Rank%E2%80%93nullity_theorem" a generalized rank-nulity theorem as below:
"If V, W are vector spaces and T : V -> W is a linear operator then
V is isomorphic with the direct sum of im(T) and ker(T)".
I had an exercise in Algebra which would be straightforward by using the theorem
above, but we had been given a somewhat complicated hint. When I mentioned this to the prof she said that this is not true and she also gave me the counter-example below:
T : R^2 -> R^2
T(e1)=0
T(e2)=e1
(R = the real numbers, e1, e2 the usual basis).
As she said, in this example, <e1>=ker(T)=Im(T) so the above theorem "is not true"..
I'm a bit confused, could you give some light please?!
I guess that this has to do with the fact that we say "isomorphic" and not "equal" (?!),
but still, that does not mean that the theorem is not correct.
In fact, the exercise we had to do was this:
If V is a v.s. and A: V -> V is a linear operator with Im(A^p) = Im( A^(p+1) ) for some p \in Z, prove <various stuff> and also prove that V = ker( A^p ) \directsum Im( A^p ).
Well, if you take in account that A^p is also a linear operator and by using the theorem above, this is straightforward.
Her proof is a almost a page...
Then I mentioned her this theorem and she said that it is not true and she gave me the above "counterexample"..
What do I miss here?!
Thanks in advance..
Yup: "isomorphic" vs "equal to" is the problem. What wiki has is definitely true, as can be seen just by comparing dimensions. The direct sum in this case is the "exterior" direct sum of vector spaces, not the "interior" direct sum of subspaces. Your prof's counterexample shows that V is, in general, not an internal direct sum of kerT and imT when T is an operator V->V. On the other hand, notice that in that example kerT=~R and imT=~R, so that R^2=~kerT x imT.
Just repeating what dvs said, what wiki said is true, but it's not helpful to the problem at hand because it is a statement about the external direct sum while you are asked to prove a statement about the internal direct sum.
Your professor gave a counter-example showing that even in the special case V=W, the formula V\cong Im(T)\oplus Ker(T) (external direct sum) cannot be improved to V= Im(T)\oplus Ker(T) (internal direct sum).
Thanks a lot for the feedback! I see it now..
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
