Understanding the Uniqueness of Retarded Time in Electromagnetism
  • Context: Graduate
  • Thread starter Thread starter arcTomato
    Potentials
The discussion centers on the concept of retarded time in electromagnetism, specifically regarding how the potential from a moving charged particle is observed. Participants clarify that the retarded time is unique and solely dependent on the distance between the observation point and the charged particle. The retarded vector potential is discussed in the context of the Lorenz gauge, emphasizing that the electromagnetic field is uniquely determined by localized charge-current distributions. The conversation highlights the relationship between potential observations and the constraints of causality in electrodynamics.
  • Understanding of electromagnetism principles, particularly retarded potentials.
  • Familiarity with the Lorenz gauge and gauge transformations in electrodynamics.
  • Knowledge of Jefimenko's equations and their application to electromagnetic fields.
  • Basic grasp of the concept of causality in physics.
  • Study the derivation and implications of Jefimenko's equations in electrodynamics.
  • Explore the concept of gauge freedom in the Lorenz gauge and its significance.
  • Investigate the relationship between retarded time and causality in electromagnetic theory.
  • Learn about the mathematical formulation of potentials and fields in classical electrodynamics.
This discussion is beneficial for physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the nuances of potential theory and the implications of retarded time in electrodynamics.
arcTomato
Hello, PFI'm studying electromagnetism, delayed potentials, and I've been wondering about a few things.
My understanding of the delayed potential is that the information from a moving charged particle at a given time travels through space at the speed of light to reach the observation point, so what is actually observed is the potential that deviates from the true position of the charged particle.
My question is: Is it possible for information about a charged particle to be observed from more than one position at the same time? In other words, is the particle's location information indeterminate?Thank you, have a good day.
If the charge moves at constant velocity, the Coulomb force points towards the current location. See my recent post:
A.T. said:
In this applet you can choose "linear" to show a charge at constant velocity. :
https://phet.colorado.edu/en/simulation/radiating-charge
The mechanism is roughly: The field lines emanating from the charge "inherit" its velocity. So if the charge maintains a constant velocity, they will remain straight and radial around the charge. If the charge velocity changes, the field lines just at the charge "inherit" the new velocity, but this disturbance in the pattern propagates at the finite speed c, resulting in "waves".
What do you mean by "observe from more than one position at the same time"? You can only have one direction for the Coulomb force at some point in space and time. But if the charge is accelerating, you might not be able to deduce it's position from that measurement.
Thank you.
What I meant was a situation like where the information of a moving charged particle at time ##t_a## and the information at time ##t_b## is observed simultaneously at time ##t_c##.
What exactly are the circumstances, if such a situation could happen?
How is the information observed exactly?
Such as for example potential. (That means information propagates at the speed of light.)
How do you observe the potential exactly?
And how do you define 'simultaneously' for measurement at two different points?
Oh, I see. I really didn't think that much about it because this is just a thought experiment of mine. I'm sorry.But how we observe doesn't seem to be that important as far as my question is concerned, I think.
Let me clarify my question. (And thank you for answering my question.)
"The potential at time ##t_1## and the potential at ##t_2## are simultaneously observed when a moving charged particle is observed at a single point ##M##."
I don't expect to make observations at more than one point.
Is this situation possible?
it might help you to answer your question, to think about how potentials are related to actual observations,
arcTomato said:
"The potential at time t1 and the potential at t2 are simultaneously observed when a moving charged particle is observed at a single point M."
I am not 100% sure that I am understanding your question. However, if I am understanding correctly then the answer is that the retarded time is unique, so the retarded potential is unique also.
Dale said:
If I am understanding correctly then the answer is that the retarded time is unique, so the retarded potential is unique also.
Thank you. and sorry for my bad English.
Could you tell me more about it?
Does that mean that the retarded time is uniquely determined because it only depends on the distance between the observation point and the charged particles?
The retarded vector potential in electrodynamics is unique up to a gauge transformation. The retarded vector potential is in the Lorenz gauge, but even within the Lorenz gauge there's some restricted gauge freedom left.
What's, of course, unique is the electromagnetic field ##(\vec{E},\vec{B})## which for the usual physical situation, where you have some localized sources (charge-current distributions), is the retarded solution, which you get by the usual derivative of the vector potential, leading to what's known as Jefimenko equations.
You have to view the electromagnetic field as a functional of the charge-current distribution. It's easier to explain if you look at the solution for a point particle. There it's a functional of the particle's world line. This world line is time-like everywhere, and this implies that the retarded time is always uniquely determined for any spacetime point of the observer (the only other solution is the advanced time, which is ruled out by causality reasons).
