About the definition of a Manifold
In summary: The definition of a manifold requires that every point in the manifold has an open neighborhood that is homeomorphic to a Euclidean space. This homeomorphism requires specifying a topology for both the manifold and the Euclidean space. In the case of the coordinate function, the topology of the Euclidean space is given by the standard topology on ##\mathbb R^n##, which directly determines the (local) topology on the manifold. This topology cannot be arbitrary, as it must resemble a Euclidean topology. The main idea of manifolds is to eliminate the notion of a manifold as a surface in a larger space and instead focus on the manifold itself. Charts, or local homeomorphisms, allow for calculations to
cianfa72
1,828
203
TL;DR Summary
Locally euclidean request in manifold definition
Hi,
I'm a bit confused about the locally euclidean request involved in the definition of manifold (e.g. manifold ): every point in ##X## has an open neighbourhood homeomorphic to the Euclidean space ##E^n##.
As far as I know the definition of homeomorphism requires to specify a topology for both spaces (here the open neighbourhood as a space itself and the Euclidean space ##E^n##). Are the two spaces "silently" supposed to be endowed each with the subspace topology ?
Euclidean space includes the definition of a metric and therefore a corresponding metric topology. It is unclear what you mean by subspace in this regard. Neither the manifold nor Euclidean space need to be thought of as subspaces of a larger space. Although you can consider the case of submanifolds, there is nothing in the definition of a manifold that requires you to do so.
It should also be mentioned that, while Euclidean space is equipped with a metric, there is no requirement that a general manifold is or, in the case when it is, that such a metric needs to be mapped to the Euclidean metric by the homeomorphism.
Likes Klystron
Sure that's clear but is not my point.
My doubt is actually more basic (I'm not a mathematician): manifold definition requires homeomorphisms between manifold open sets and euclidean open sets. Each homeomorphism definition requires a domain with its own topology and the same for the codomain.
My question is: which are the underlying topologies involved in each homeomorphism definition ?
For the coordinate function (i.e., the map from the manifold to ##U \subset \mathbb R^n##), the topology in codomain ##U## is given by the standard topology on ##\mathbb R^n##. This directly tells you what the (local) topology on the manifold needs to be.
quoting the definition: "A topological space X is called locally Euclidean if there is a non-negative integer n such that every point in X has a neighbourhood which is homeomorphic to the Euclidean space ##E^n##"
Thus starting from the very fact topological space ##X## has its own topology take an open neighbourhood ##O## of a manifold point and consider the homeomorphism to the Euclidean space. The open neighbourhood ##O## as a set is the domain of the homeomorphism, but which is the topology to "attach" to it ? I believe it is the subset (or subspace) topology when the open neighbourhood ##O## is viewed as subset of the manifold ##X##
The manifold can either come with a topology or have a topology induced by the mapping from ##U##. In the latter case it is quite clear that the resulting mapping is a homeomorphism, otherwise you have to check that it is. It is not sufficient that the set ##O## itself is open in the manifold topology. There is a topology on ##O## induced by the topology on the manifold. So
cianfa72 said:
I believe it is the subset (or subspace) topology when the open neighbourhood O is viewed as subset of the manifold X
is correct in that case.
cianfa72 said:
I believe it is the subset (or subspace) topology when the open neighbourhood is viewed as subset of the manifold X
Correct. The essential point, however, is that the topology on ##X## cannot be arbitrary, since it is required to look like a Euclidean topology. This is a strong restriction.
The basic idea of manifolds is not so much the topologies on them, but rather to get rid of the view that a manifold has to be a surface in a surrounding space. It is as if there is only the manifold and nothing else. Now to do analysis on it, we need the charts, the local homeomorphisms. That is: we go down to the chart, perform our calculations, and return up to the manifold.
Likes Orodruin
I do not understand why this point about the subspace topology is not highlighted in the definitions I read...
Sure I got it !
If we have a topological space and refer to subsets, we don't change the topology. The aspect to consider a subset as the entire space for your now no more local homeomorphism is artificial. The natural view is to consider the homeomorphism as a function which is only locally defined, will say on an open set ##\mathcal{O}\subseteq X##. There is simply no need to transfer from ##X## to ##\mathcal{O}##. That's why.
Your consideration comes into play if we talk about manifolds with boundaries. For a boundary we need something outside. Now a manifold has no outside, just as the universe doesn't expand into something. There is no something. To solve the issue, we lend the concept from the Euclidean space: if the charts have a boundary, then the upload of it to the manifold is called boundary there. In this case we have to take care about subset topologies. In the general case we do not.
Likes Klystron
Not sure to fully get your point. Could you elaborate a bit please ?
Thanks.
If we have a chart ##\xi\, : \, X \longrightarrow \mathbb{R}^n## then it is locally defined, that is its domain is an open set ##\mathcal{O}\subseteq X##. This is a local homeomorphism. We do not need to switch to a view ##\xi\, : \,\mathcal{O} \longrightarrow \mathbb{R}^n## where the locally defined map ##\xi## becomes a globally defined map on a topological space ##\mathcal{O}##, what the transfer to the subset topology would be. Quite the opposite is true! What we really consider is a family of such charts, an atlas. The main requirement for an atlas is, that overlapping charts yield the same results for our calculations, i.e. it doesn't matter if we perform a calculation in one chart or the other. Therefore we need to consider the entire family of charts. If we had transferred to the subspace topology for each, we would have trouble to handle the overlappings as they were now in two different spaces! But as open sets in still the same topological space ##X##, we don't have to bother any subspace topologies at all.
Or for short: We only need open neighborhoods in ##\mathcal{O}## and they are open in the subspace topology as well as in the original topology. So why bother a change?
Thus we have a chart ##\xi## from ##X## to ##\mathbb{R}^n## defined just only on the set ##\mathcal{O}## open in ##X##. In that case on which ##\mathbb{R}^n## values are mapped by ##\xi## points not in ##\mathcal{O}## ?
cianfa72 said:
In that case on which ##\mathbb{R}^n## values are mapped by ##\xi## points not in ##\mathcal{O}##?
What do you mean? ##\xi(X-\mathcal{O})## is not defined, so we do not care. Same as ##x\longmapsto \frac{1}{x}## isn't defined for ##x=0##. The image of ##\xi## is an open set in ##\mathbb{R}^n##.
On no values. A chart is only required to be defined on a subset of the manifold. The chart is not from the manifold to ##\mathbb R^n##, it is from a subset of the manifold to ##\mathbb R^n##.
but in that case I believe ##x\longmapsto \frac{1}{x}## is a map/application/function from ##\mathbb{R}-\{0\}## to ##\mathbb{R}## and not from ##\mathbb{R}## to ##\mathbb{R}##. From my understanding a map/function/application has to be defined on each point of its domain
that's the reason why I was wondering about the topology to attach to it in defining an homeomorphism from a set open in the manifold topology to ##\mathbb{R}^n##
Yes, and the domain of the coordinate chart is a subset of the manifold, not the manifold itself in exactly the same way that ##1/x## has ##\mathbb R \setminus \{0\}## as its domain. In fact, ##1/x## is a chart of the manifold ##\mathbb R## with the covered part of the manifold being everything but ##x = 0##.
That's nitpicking and a notational question how you write a function. My notation doesn't require to name the domain, only the space the domain is part of. We could debate for hours whether this is right or wrong. I don't care. I will continue to distinguish the domain from the space the function originates from. If you like, you can write ##\xi\, : \,\mathcal{O} \longrightarrow \mathbb{R}^n ## and give ##\mathcal{O} ## the subset topology. It is just not necessary and complicates the case of overlapping charts, as you now have three potentially incompatible topologies: on either of the two open sets, and on the intersection of both. Of course they are not incompatible, but you will have to prove it. Then for every new patch you need to consider a new topology. What for? It is good for nothing, since we always deal with the topology of ##X## and nothing else. So it is far easier to say that charts are only defined on open sets of ##X## than to introduce new topologies. It is as if we argue whether the book is an atlas of a country or a collection of individual maps. And in our case, we do not allow maps to have different scales, because their intersections are required to be compatible.
Likes Klystron and Orodruin
Orodruin said:
...otherwise you have to check that it is. It is not sufficient that the set ##O## itself is open in the manifold topology. There is a topology on ##O## induced by the topology on the manifold.
Basically what you're saying is that in case the manifold is endowed with a given topology, then we have to explicitly check if the topology induced to the set ##O## by the chart (a bijection from ##\mathbb R^n## transferring to it the Euclidean topology) is the same as the topology induced by the manifold topology when ##O## is viewed as a subset of it (actually thinking of it as endowed with the subset/subspace topology)
Does it make sense ?
To be honest, I do not see why you are hung up on this technical detail. When you deal with an actual manifold most of these issues are going to be essentially self evident.
Likes fresh_42
you are right of course that the homeomorphism from an open set O in a manifold X, to E^n, should be with respect to the subspace topology on O inherited from X. We who know this are notoriously lazy about making it clear when we write. In this case of course, the subspace topology on an open set O is pretty easy, namely the open sets in O, for the subspace topology, are exactly those open sets of X which happen to be contained in O. This is because the intersection of two open sets is also open. So maybe in this case the author can be forgiven for leaving it to the reader to surmise the correct definition, as you have in fact done. So now you have learned a valuable lesson for reading math, namely when something is left out, use the most natural fill-in that you can think of, and see if it works out. To test yourself, try reading a proof that uses the topology and see whether your candidate gives the right result.
Likes dextercioby
Thank you all for the clarification
What is a manifold?
A manifold is a mathematical concept that describes a space that looks like a flat surface when zoomed in, but can have more complex shapes when zoomed out. It is a generalization of the concept of a plane or a curve in higher dimensions.
What are the properties of a manifold?
A manifold is a topological space that is locally Euclidean, meaning that it looks like Euclidean space when zoomed in. It is also second-countable, which means it has a countable basis for its topology. Additionally, a manifold is Hausdorff, meaning that any two distinct points have disjoint neighborhoods.
What are the different types of manifolds?
There are several types of manifolds, including topological manifolds, smooth manifolds, and complex manifolds. Topological manifolds are the most general type and can have non-smooth or non-differentiable points. Smooth manifolds are differentiable and have a well-defined tangent space at each point. Complex manifolds are smooth manifolds with additional complex structure.
What are some examples of manifolds?
Some common examples of manifolds include spheres, tori, and projective spaces. In physics, spacetime is often described as a four-dimensional manifold. Other examples can include the surface of a globe, a Mobius strip, or a Klein bottle.
Why are manifolds important in mathematics and science?
Manifolds are important because they provide a way to generalize geometric concepts to higher dimensions. They are used in many areas of mathematics, including topology, geometry, and differential equations. In science, manifolds are used to model complex systems and describe the behavior of physical phenomena. They are also essential in fields such as computer graphics, robotics, and machine learning.
  • Differential Geometry
  • Topology and Analysis
9K
