Abs Continuous Function w/ Unbounded Derivative on [a,b]
The discussion centers on identifying an absolutely continuous function on the interval [-1, 1] with an unbounded derivative. The function defined as f(x) = x^2 sin(|x|^{-3/2}) for x ≠ 0 and f(0) = 0 serves as a valid example, with its derivative f'(x) being integrable on [-1, 1]. The key takeaway is that even though the derivative is unbounded, it can still be Lebesgue integrable, as demonstrated through the calculation of the integral of its absolute value, which is finite.
  • Understanding of absolutely continuous functions
  • Knowledge of Lebesgue integrability
  • Familiarity with Riemann integrability
  • Basic calculus, particularly differentiation and integration techniques
  • Study the properties of absolutely continuous functions in detail
  • Learn about Lebesgue integration and its applications
  • Explore examples of functions with unbounded derivatives
  • Investigate the relationship between Riemann and Lebesgue integrability
Mathematicians, calculus students, and anyone interested in advanced topics in real analysis, particularly those studying properties of continuous functions and integrability.
glacier302
What is an example of an absolutely continuous function on [a,b] whose derivative is unbounded?
I know that the function f: [-1,1] defined by f(x) = x^2sin(1/x^2) for x ≠ 0, f(0) = 0 is continuous and its derivative f'(x) = 2xsin(1/x^2)-2/xcos(1/x^2) for x ≠ 0, f'(0) = 0 is unbounded on [-1,1]. But this function isn't absolutely continuous...
Any help would be much appreciated : )
We can construct another example along the same lines. Consider the following:
f(x)=\begin{cases} x^2 \sin (|x|^{-3/2}) & \text{if }x \neq 0 \\ 0 & \text{if } x=0 \end{cases}
Computing the derivative yields:
f'(x) = \begin{cases} 2x \sin (|x|^{-3/2}) - \frac{3}{2} \operatorname{sgn}(x) |x|^{-1/2} \cos(|x|^{-3/2}) & \text{if } x \neq 0 \\ 0 & \text{if } x=0 \end{cases}
Since the derivative is integrable on [-1, 1], f is absolutely continuous on that interval.
Thank you for your help. One question: How I do know that the derivative of that function is integrable? If f' were bounded, then the fact that it is only discontinuous at x = 0 would make f' Reimann integrable, and Reimann integrability implies Lebesgue integrability for bounded functions. But in this case, f' is not bounded, so how do I show that it is Lebesgue integrable?
f' is obviously measurable, so you only have to show that the integral of the absolute value is finite. But we have:
\begin{align}\int_{-1}^{1} |f'(x)| \ dx & \leq \int_{-1}^{1} 2|x| |\sin(|x|^{-3/2})| + \frac{3}{2}|x|^{-1/2} |\cos(|x|^{-3/2})| \ dx \\ &\leq \int_{-1}^{1} 2 + \frac{3}{2} |x|^{-1/2} \ dx \\ & = 4 + \frac{3}{2} \int_{-1}^{1} |x|^{-1/2}\ dx \\ & = 4 + 3 \int_{0}^{1} x^{-1/2} dx \\ & = 4 + 6 \sqrt{x} \Big\vert_{0}^{1}\\ & = 10 < \infty \end{align}
Aha. Thank you! I knew that if a bounded function is Reimann integrable then the Reimann integral and the Lebesgue integral of the function are equal. However, I always forget that this can be extended to unbounded functions as long as the Reimann integral is finite.
Thanks again!
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
