Absolute Value of e(i): Why is it Equal to 1?
The discussion revolves around the absolute value of the complex exponential function, specifically why |e^i| equals 1. Participants explore definitions, properties of complex numbers, and the implications of various mathematical representations.
  • One participant questions the equality |e^i| = 1 and seeks clarification on the definition of absolute value for complex numbers.
  • Another participant explains that |z| is defined as z z*, where z* is the complex conjugate, and applies this to show |e^{ix}| = 1 for real x using algebraic rules.
  • A participant expresses gratitude for the explanation and engages positively with the discussion.
  • There is a query about the directness of showing that (e^{ix})* = e^{-ix}, with a suggestion to use the sine/cosine representation for clarity.
  • Another participant mentions using a shortcut for finding the complex conjugate by replacing i with -i, prompting a question about the necessity of proving this shortcut.
  • A detailed explanation of the analytic continuation of the exponential function is provided, including its properties and how it relates to the absolute value calculation.
  • A participant introduces the Schwartz reflection principle, indicating that f(\bar{z}) = \overline{f(z)} is not universally true.
  • There is a discussion about the validity of certain formulas in the context of real and analytic functions, with a participant questioning the proof of a specific case involving infinite sums.
  • A claim is made that the only real and analytic function is a constant, supported by a proof involving Cauchy-Riemann conditions.
  • A participant expresses unfamiliarity with complex analysis and seeks clarification on the definition of real analytic functions.
Participants present multiple viewpoints and approaches to the topic, with no consensus reached on certain definitions and properties, particularly regarding the nature of real analytic functions and the validity of specific mathematical statements.
Some discussions involve assumptions about definitions and properties of complex functions that may not be universally accepted. The conversation also touches on the implications of analytic properties and the nature of infinite sums, which remain unresolved.
Vectorspace
Why does [tex]|e^i| = 1[/tex] ?
For any complex number z, we define |z| as z z*, where z* is the complex conjugate of z, right?
Then seeing that
[tex]|e^{\mathrm{i} x}| = 1[/tex]
for any real number x is a matter of applying the definition and simple algebraic rules.
Thank you very much buddy.
How is it obvious that [tex]\left( e^{ix} \right) ^{*} = \left( e^{-ix} \right)[/tex]? I'd use the sin/cos represenatation, but the way you suggested it implies there's a more direct way?
Vectorspace, you're welcome.
Using the sin/cos representation makes it explicit, because then you split it into its real and imaginary part.
For myself I always use the "shortcut": the complex conjugate is obtained by replacing every i in the expression by -i.
Oh I see. Is that shortcut something that needs proving, or is it something evident?
The analytic continuation of the exponential function which preserves the fundamental property of the exponentials:
[tex] \exp{(z_{1} + z_{2})} = \exp{(z_{1})} \cdot \exp{(z_{2})}[/tex]
and is equal to the natural exponential function on the real line, i.e.:
[tex] \exp{(x)} \equiv e^{x}, x \in \mathbb{R}[/tex]
is given by:
[tex] \exp{(z)} \equiv \exp{(x + i y)} = e^{x} \, \left(\cos{(y)} + i \, \sin{(y)}\right)[/tex]
You can show explicitly that this function:
1. It satisfies the above functional equation;
2. It is analytic everywhere on the (finite) complex plane by seeing if the Cauchy Riemann conditions are satisfied and that the partial derivatives are continuous;
3. It reduces to [itex]e^{x}[/itex] when [itex]y = 0[/itex] which is trivial.
Then, you simply use the definition of absolute value to show that:
[tex] |\exp{(z)}| = \sqrt{u^{2}(x, y) + v^{2}(x, y)} = \sqrt{e^{2 x} \, \cos^{2}{(y)} + e^{2 x} \, \sin^{2}{(y)}} = e^{x} = e^{\Re{z}}[/tex]
BTW, what 'mr. vodka' was asking. It is not necessarily true that:
[tex] f(\bar{z}) = \overline{f(z)}[/tex]
See Schwartz reflection principle for further discussion.
Thank you Dickfore. Could it be true though that your invalid formula is true in the special case of f being real and analytical? Then you can write the infinite sum and it seems reasonable that the complex conjugate of an infinite sum is the infinite sum of the complex conjugates, although I don't actually know how to prove that if [tex]\sigma = \sum_i^\infty a_i z^i[/tex] with a_i real and z complex, that [tex]\rho_n = \sum_i^n a_i \overline{z^i} \to \overline{\sigma}[/tex].
The only real and analytic function is a trivial constant.
Proof:
[tex] w = f(z) = u(x, y) + i \, v(x, y), \; z = x + i \, y[/tex]
[tex] w \in \mathbb{R} \Rightarrow v \equiv 0[/tex]
From the Cauchy Riemann conditions:
[tex] \frac{\partial u}{\partial x} = \frac{\partial v}{\partial y} = 0[/tex]
[tex] \frac{\partial u}{\partial y} = -\frac{\partial v}{\partial y} = 0[/tex]
Because both partial derivatives of u w.r.t. x and y are identically equal to zero in the region of analyticity, it means [itex]u = \mathrm{const.} \in \mathbb{R}[/itex]. Q.E.D.
I'm sorry, I'm not familiar with complex analysis. With "real analytic function" I meant a function whereof the expansion [tex]\sum a_i z^i[/tex] has only real a_i's (maybe a characterisation of such a function is an analytical function with f(R) a set of reals?)
  • · Replies 22 ·
28K
