Absolute zero temperature is impossible to achieve?
The discussion revolves around the concept of absolute zero temperature and whether it is physically achievable. Participants explore theoretical implications, methods of cooling, and the limitations imposed by thermodynamics.
  • One participant muses that achieving absolute zero might be impossible due to the requirement of infinite energy removal, drawing an analogy to the speed of light and mass increase.
  • Another participant suggests that cooling an object to absolute zero would necessitate contact with something colder than absolute zero, questioning the feasibility of such a scenario.
  • A participant references laser cooling, questioning how it works without physical contact and whether the interaction of atoms with photons constitutes contact.
  • Concerns are raised about the implications of the third law of thermodynamics, suggesting that while cooling methods can lower temperatures, they cannot reach absolute zero in a single stage.
Participants express differing views on the feasibility of achieving absolute zero, with some arguing it is impossible while others discuss methods that approach very low temperatures. The discussion remains unresolved regarding the implications of these methods and the theoretical limits involved.
Participants reference various cooling methods and thermodynamic principles, but the discussion lacks consensus on the specifics of these methods and their limitations. There are also unresolved assumptions about the nature of contact in cooling processes.
Chad Jensen
Just a general musing. Could absolute zero ever be physically possible or is it like the speed of light but for an inverse reason? The speed of light take infinite energy to achieve. So therefore is impossible because the energy put into the system adds mass. This is not noticeable at slower speeds but I would imagine the speed vs mass converts more and more to mass and your speed increase becomes less and less the faster you go, thus preventing you from ever reaching the speed of light. I have learned in calculus that one of the definitions of Zero is 1/infinity. Could this mean that absolute zero is impossible because it takes an infinite amount of energy removal to reduce the molecular motion to zero? And the issue with energy removal is the greater the difference between ambient energy and the energy of a system is the harder it becomes to remove said system energy to the point it becomes infinitely hard to remove the system energy.
Thanks
Science news on Phys.org
The answer is no, but I don't remember the specifics --- this has been asked and answered MANY times here on PF so I suggest a forum search for the details.
Thank you for your answer. I did do a forum search and I worded my question poorly. I was aware of not being able to get to absolute zero. I was just wondering on the possible why. I will see if I can search a bit deeper and dig up the why.
The way to cool an object to temperature ##T## is to put it in contact with something colder than ##T##. (Putting it in contact with an object whose temperature is exactly ##T## won't do the trick because as heat flows from the warmer object to the colder object, the colder one warms up so we end up with the two objects in equilibrium at a temperature higher than ##T##).
So to cool an object to absolute zero you need something colder than absolute zero. And where are you going to find that?
Chad Jensen said:
I was under the impression they could use lasers to cool an object with no physical contact.
That depends if you consider "an atom absorbing and emitting photons" as physical contact... or magnetic fields manipulating atoms in
Magnetic refrigeration
So the only way you could hypothetically remove "all" contact from an atom is to surround it with atoms at absolute zero which don't exist.
This seems to imply that refrigerators aren't possible. You can get lower than the temperature of the environment. The third law of thermodynamics implies that you can only reduce the absolute temperature in a single cooling stage by a constant factor. This was already known for a lot of cooling methods, but a rigorous proof of this was only given this year. http://www.nature.com/articles/ncomms14538
  • · Replies 19 ·
  • · Replies 23 ·
15K
