Acceleration doesn't cause the Twin Paradox?
45 replies · 13K views
starfish99
Acceleration doesn't "cause" the Twin Paradox?
In a recent review of a physics textbook, the reviewer is critical of the author of the book because the the author doesn't correct the persistent notion of many students that it is the acceleration of one of the twins that "causes"[reviewer's quotes] the differential aging in the twin paradox.
Suppose we have a set of twins, Eartha and Stella. Stella accelerates in a ship to nearly the speed of light and lands on a planet 30 light years away. Immediately upon landing,Stella sends a picture of herself to Eartha, the stay-at-home twin. What would Eartha say upon receiving the image of her twin? Eartha would say that her sister looks exactly like the day she left!
All Stella did was accelerate to near the speed of light.There was no meet-up back on earth. There wasn't even a turn around or any change in direction. Just acceleration and deceleration
My Question: Why is this persistent notion in error?
If acceleration didn't cause the differential aging, what did?
(Please no General Relativity)
There's a few sources which just say "well one of the twins accelerated, so use GR for this". That's maybe what the reviewer was criticizing? In effect, it is the acceleration that breaks the symmetry of the problem and allows a non-ambiguous result to be reached. But one certainly does not need GR to analyze the twin paradox. Whichever twin switched reference frames will be the one who turns out to be older.
You mean younger?
Right, younger. >.>
I wrote that without thinking. <.<
Indeed acceleration is sufficient but not necessary - you need a way to break the symmetry, and acceleration is one way to do so. Consider the case where the the universe is compact and thus finite, say a torus, that allows its observers to travel in one direction and then arrives back where he started. See here for more details. This gives rise to the so-called "cosmological twin paradox", see this thread and this thread for detailed discussion. I just quote the scenario for clarity here:
Garth said:
Take two twins, one twin stays put and the other is accelerated to
9.999…%c she passes her sister and they synchronise clocks. She continues at constant velocity along a geodesic path and circumnavigates the universe. She eventually meets up with her sister again.
She has aged only 50 years in this near light-speed voyage. However her sister has aged 10 billion years!
Or is it the other way round? How do you tell?
Note that you have two accelerations in your scenario: to reach near c, and to land on a planet. They are not essential to your interesting question (in fact they refute it if the goal is to show inessentiality of acceleration).
Let's suppose stella passes right by a space station near earth, and stella and eartha look at each other, seeing they are about the same age (and they syncrhonize wristwatches). Then suppose stella sends eartha a self image as stella passes the distant planet. Further, let's suppose eartha sends stella a self image from a time such that it happens to reach stella at a time after stella passes the planet that is very slightly less than the time it took (per stella) to reach the planet. This means, stella would conclude eartha sent her image 'at the same time' per stella, that stella passed the planet. Eartha, meanwhile, by direct (delayed) communication with the planet verifies stella's image was sent when stella passed the planet.
What do they see? Eartha sees a picture of stella that has aged only a month (for example), though sent after 30 years (per Eartha), and arriving after 60 years per Eartha. Stella gets a picture of Eartha after (for example) two months (planet passed after one month, per stella). But Eartha's picture (say, based on wristwatch in image) has aged less than an hour since stella left eartha! (It would be a good exercise for you to work out why this is so).
Thus there is symmetrical time dilation, and no paradox, when all motion is inertial. Acceleration of at least one twin is necessary for a twin paradox in SR. Further, they have to get back together to have a mutually agreed on age difference. As to what part of difference in path through spacetime is responsible for the age difference, I hold that is a completely meaningless question. In that sense (only) I would say you can't say acceleration caused the age difference, but you can say it enabled it.
Actually, what this cute example shows is that (if you allow flat but topologically nontrivial spacetime), acceleration is neither necessary nor sufficient. It is not sufficient, because if you symmetric acceleration, there is no differential aging (each accelerates away and back, with identical thrust profile). It is not necessary due to (and only due to) nontrivial topology.
from an earlier post of mine
(https://www.physicsforums.com/showthread.php?p=3272665#post3272665)
"First, is it reasonable to say that
it is during his acceleration at C
that twin 2 suddenly loses time or age, and that
this loss at C causes the final age difference at B?
The answer is "no."
It is just as unreasonable to blame the acceleration at C
for the total age difference of the twins
as it would be,
in the case of a triangle ACB in the ordinary Euclidean plane,
to say that the larger length of the path ACB,
as compared to the straight path AB,
is caused by a sudden gain of length at the corner C."
The Clock Paradox in Relativity Theory
Alfred Schild,
The American Mathematical Monthly, Vol. 66, No. 1 (Jan., 1959) (pp. 1-18)
http://www.jstor.org/pss/2309916
Yes. You are right. I should have been more careful :-p
What about the claim by Dr. Mendel Sachs that the twin paradox is itself not a valid interpretation?
http://mendelsachs.com/on-the-twin-clock-paradox/
I should note that a post asking for clarification on how, given two paths relative to a given inertial frame, the integral of time along the path integral does not correspond to aging was deleted. I asserted that the path with the most acceleration relative to that frame should age more.
I guess Mendel Sachs did not like my definition of aging as a biological measure of the rate of time, and thus subject to SR.
I was actually in college when Sachs first proposed his thesis on the twin paradox (circa 1971). It caused a lot discussion and snickers.
Sachs is/was a serious scientist, but on this, his position is crank, and in decades of writing has not swayed any to his side.
The integral of proper time along world line (with any amount or lack of proper acceleration) is, by definition, the time experience by any physical process following that world line. In both SR and GR, this a definition leading to predictions. Any observation counter to this would be disproof of relativity. There are no such observations, so far as I know.
Thank you for confirming my thoughts. This appears to make his sites a haven for SR doubters. It seems the flaw in logic is outlined by TataKai in the following forum post.
http://mendelsachs.com/cgi-bin/forum/Blah.pl?b-MSFORUM4/m-1155004653/
Here it is argued that Einsteins postulates are inconsistent, thus SR is in error. It would seem to me that these postulates are not well defined, leaving the status of SR inconclusive based on the invalid arguments deriving from these postulates.
Unfortunately, it appears to me that those who refute SR based on this line of argument fail to observe that SR can also be derived based on the following, clearly consistent, postulates:
1) An inertial reference frame is Euclidean.
2) Any trajectory moving with a constant velocity in any reference frame defines the origin of another reference frame.
3) The transformations between frames form a mathematical group.
This then limits the form of the transformation to a single undetermined parameter, 1/c^2, that has been determined to be a precise constant using many methods beyond the optical methods implied by Einsteins postulates. In fact, this can be used to clarify what is intended by Einstein's postulates as theorems.
Electromagnetic/optical phenomenon were the first system where we reached an accuracy able to distinguish this value from 0, and refute the Galilean transformations.
Returning to the twin problem in SR, this derivation would require us to first fix a reference frame. Further, the twins trajectories must have identical initial and final coordinates for a comparison to be meaningful. Each twin will have their age reduced based on how much time dilation is observed in the given frame along the trajectory they followed.
This delta in age must be Lorentz invariant. Otherwise the theory WOULD be inconsistent.
Hello starfish99:
The Twin Paradox outcome is not dependent on having an acceleration phase. An age difference can also be demonstrated by other means of symmetry breakage.
Let’s say that observers A and B are separated and are approaching each other on a collision course with constant relative velocity. Observer A takes the initiative of synchronizing their clocks as follows. When A’s clock reads T1 he sends a signal (at light speed) to B. B’s receipt of that signal resets his clock to zero and immediately sends a return signal to A, who receives it at his time T2. With the assumption that both light signals traveled at the same speed, A concludes that from his point of view, B reset his clock to zero when A’s clock was at (T1+T2)/2, the midpoint of the T1-to-T2 interval. That being so, A resets his clock at T2 to the time (T2-T1)/2. As far as A is concerned the two clocks have been synchronized.
Nevertheless, when A and B finally collide (or, hopefully, pass one another) they compare clocks and find that A’s clock has advanced more than B’s clock (of course by an amount predicted by SR for their relative velocity.)
As you might expect, if B initiates the synchronization process, the aging outcome would be inverted. And all this without any acceleration.
It does no good to ask why time behaves this way. Such questioning falls in the same category as “Why are there only three spatial dimensions?” (if indeed that’s all there are.)
The current answer to such questions can only be: “That’s the structure of spacetime.”
Clocks that are moving with respect to one another cannot be synchronized since they tick at different rates. They can only be reset to the same time when they are colocated. By the time A responds to the signal from B, B's clock will no longer be at the same time. I don't know what you think this accomplishes.
George:
Yes, clocks in motion relative to each other will not remain synchronized. That’s the gist of SR. That’s what accounts for the age difference, both in my example and in the standard twin paradox problem. Both have the same result for this same reason.
In one case (the standard twin paradox problem) they momentarily synchronize their clocks and mutually agree that they had done so because they were together at the synch moment. In my example only A can claim the synch moment , and only by inference.
For A to conclude that B’s clock read zero when A’s own clock read (T1+T2)/2 is most reasonable. And for A to reset his clock to (T2-T1)/2, so that it would have read zero at what he considered to be a simultaneous event with B’s clock-zero, gives him an easy way to compare elapsed times when they meet. In either case A’s synch moment is fleeting, and serves only to make it easier to compare the clocks’ elapsed times between events.
The “mechanism” that brings about the aging difference is the same in both the standard twin problem and the one I showed here.
My purpose was only to put to rest the idea that acceleration is a necessary ingredient.
Actually, we could have wrapped up the discussion with PAllen's post, because it tells the story in a nutshell. I'll just go ahead and add the space-time diagram for what PAllen has just said (but leaving out acceleration details). I've included a couple of hyperbolic calibration curves to help keep track of the proper times for the twins. The traveling twin takes 10 years going out and 10 years returning, while the stay-at-home twin sits there and ages 40 years.
I think the reviewer of the textbook referred to in post #1 was frustrated because he felt that it is the path taken through space-time that should be the point of focus when talking about the twin paradox.
I have a question.
Why are there no textbooks that actually DO the Lorentz Transformation?
Why do we never actually take the event-mapping one-to-one, and see what the space-time diagram looks like from the traveling twin's point of view on the OUTBOUND trip?
Why do we never actually take the event-mapping one-to-one, and see what the space-time diagram looks like on the RETURN trip?
Is there some kind of conspiracy, or is it just considered "wrong" to do it, for some reason?
JDoolin said:
I have a question.
Is this what you are looking for? Or did you want to see space-time diagrams for the traveling twin's rest system?
JDoolin said:
I have a question.
Since you can analyze any scenario from any Frame of Reference, why bother with doing a Lorentz Transformation?
The Twin Paradox is so easy to analyze from a frame in which the one twin remains at rest. You just apply Einstein's super simple time dilation formula for a moving clock, τ=t√(1-β2), you plug in the speed, β, as a fraction of the speed of light that the traveler goes at and the time, t, in the rest frame that he is gone and you get his age, τ, when he returns. So if he's traveling at 0.8c and he's gone for 10 years (5 years out and 5 years back), he'll be only 6 years older when he gets back compared to the 10 years of his brother:
τ=t√(1-β2)=10√(1-0.82)=10√(1-0.64)=10√(0.36)=10(0.6)=6
Now if you want to use the Lorentz transformation to analyze this from a frame in which the traveling twin is at rest during the outbound portion of the trip, you will have to first assign events to the first frame. I prefer to only include t and x in the form [t,x] and use units of t in years and x in light-years.
So we start with both twins at the origin of our frame, [0,0].
Next we calculate where the traveling twin will be after 5 years at 0.8c which is 4 light-years away, [5,4].
Meanwhile the other twin is at [5,0].
Then 5 years later, both twins are reunited at [10,0].
To do any Lorentz Transforms, we start by calculating gamma for beta of 0.8:
γ=1/√(1-β2)=1/√(1-0.82)=1/√(1-0.64)=1/√(0.36)=1/0.6=1.667
Now it's fairly easy to transform the first two events into the rest frame of the traveler using the simplified Lorentz Transform. In fact, the first one is the origin which is also the origin of any other frame. But the second event for the traveler is:
t'=γ(t-xβ)=1.667(5-4*0.8)=1.667(5-3.2)=1.667(1.8)=3 years
x'=γ(x-tβ)=1.667(4-5*0.8)=1.667(4-4)=1.667(0)=0 light-years
But the event for the stay-at-home twin is:
t'=γ(t-xβ)=1.667(5-0*0.8)=1.667(5-0)=1.667(5)=8.333 years
x'=γ(x-tβ)=1.667(0-5*0.8)=1.667(0-4)=1.667(-4)=-6.667 light-years
Now the event for the traveler looks good because since he is at rest in this frame, his position remains at 0 and his time is 3 years, half of the accumulated age that we calculated earlier (since he is half-way through his 6 year trip, according to him).
But what about the event for the stay-at-home twin? Those numbers don't make any sense at all, do they? But they do if we remember that these are coordinates in a different frame. If we want to know how much the stay-at-home twin aged up to this point, we have to use the time dilation formula on the coordinate time to get his proper time which is 8.333 times 0.6 which is 5 years.
Now we want to bring the twins back together using the last of the events:
t'=γ(t-xβ)=1.667(10-0*0.8)=1.667(10-0)=1.667(10)=16.667 years
x'=γ(x-tβ)=1.667(0-10*0.8)=1.667(0-8)=1.667(-8)=-13.333 light-years
Again, the stay-at-home twin has a coordinate time of 16.667 years but if we multiply this by 0.6 we get 10 years.
The traveling twin is a little more complicated because we don't know off hand what his speed is but it's not too hard to calculate if we just take the difference in the last two events for him, [16.667,-13.333] and [3,0] which is [13.667,-13.333]. This means he has traveled 13.333 light-years in 13.667 years for a speed of 0.9756c. Plugging this into the time dilation formula, we get an accumulated age of:
τ=13.667√(1-0.97562)=13.667√(1-0.9518)=13.667√(0.0482)=13.667(0.2195)=3 years
Wasn't that fun?
ghwellsjr said:
Wasn't that fun?
Hi ghwellsjr.
Yes, that was fun. I like your problem set-up. We have three major events
e1: departure (x,t)=(0,0)
e2: turnaround (x,t)=(4,5)
e3: return (x,t)=(0,10)
You also have defined another event (x,t)=(0,5), for which (x',t')= (-6.667,8.333). Then you said: "Those numbers don't make any sense at all, do they? But they do if we remember that these are coordinates in a different frame." I totally agree; but there's a lot more to say about that. Why doesn't it make sense. Why does it make sense? How does it make sense? How long is the outbound twin's reference frame relevant to the outbound twin? For only three years. But this event happens at t=8.333 years! How far away is it going to happen? 6.667 light-years from the origin.
We should also figure out when and where this event happens according to the inbound twin's reference frame.
Here is my calculation of the coordinates of e1, e2, and e3 in the outbound and inbound frames:
e1': departure (x,t)=(0,0)
e2': turnaround (x,t)=(0,3)
e3': return (x,t)=(-13.333, 16.667)
We can calculate the necessary change in velocity by figuring Δx/Δt between event 2 and event 3.
And in the return-frame, we have
e1'': departure (x,t)=(-13.333,-10.667)
e2'': turnaround (x,t)=(0,3)
e3'': return (x,t)=(0,6)
My point is, those numbers DO make sense if you show the space-time diagram in the other frames. However, none of the textbooks on relativity actually SHOW the space-time diagrams in the other frames, so the reader is always left with these loose ends, wondering if it really makes sense, or just accepting the authority of the author, who claims it makes sense.
I know it does make sense, but that's because I've gone through the effort of actually looking at it from the different frames. But I've never seen ANY relativity texts actually go through the effort of transforming the coordinates of the events to other reference frames, and showing how those coordinates DO make sense.
When an author says "it doesn't make sense" does he mean
  • "it doesn't make sense to me," or
  • "it doesn't make sense to most people" or
  • "it really makes no sense, i.e. it is really wrong"
  • It makes no sense, i.e. it is meaningless;
  • "it does not make sense to our primitive human brains, but it is mathematically correct."
  • other?
So which event coordinates "do make sense," and which ones "don't make sense?"
In the Earth frame:
In the outbound frame
In the return frame
It appears that everyone agrees that events e1, e2, e3 all make sense, e1' and e2' both make sense, and e2'' and e3'' both make sense.
However, the coordinates of the two remaining events seem to be in question:
What is the opinion of the General Relativity Experts? Do the coordinates of those events "make sense" or "not make sense?"
JDoolin said:
Hi ghwellsjr.
You asked the question:
I'm trying to provide an answer. Part of that answer is that when you transform some significant events in one frame to another frame, they are no longer significant. The event in question is the one for the stay-at-home twin that is simultaneous with the turn-around event for the traveler. When we transform these two events into the frame in which the traveler is at rest during the outbound portion of the trip, they are no longer simultaneous and therefore don't represent anything significant to the traveler. But they do represent something significant to us once we remember, as I previously said, that they are coordinates in a different frame. I showed how we can use the time dilation formula to convert the coordinate time to the proper time and get back the age difference of the home twin. What we are really doing is dividing the coordinate time, 8.333, by gamma, 1.667, to get the proper time of 5 years and we could also divide the coordinate distance, -6.667 by 1.667 to get the proper distance, -4 light-years.
Yes, since this is still not a significant event to the traveling twin, what we really need to do is consider how far away the home-twin is after traveling for 3 years at -0.8c. That would be -2.4 light-years. That is the symultaneous event (-2.4,3) of the home-twin at the turn around event of the traveling twin in the rest frame of the traveling twin. (I hope no one is getting confused by the interchange of x and t in our two conventions.)
All of this is illustrating the relativity of simultaneity. But my point is that simply doing Lorentz transforms of the events in one frame to another frame is not enough. You have to do extra work to figure out the significant events. I'm not sure students learning Special Relativity are going to grasp all this in a beginning course, especially, as I said earlier, it's so easy to understand almost any scenario in one frame.
I need some help understanding what you have done here. First off, what is the value of β? Where is the origin? What is the starting frame that you are converting into the double-prime frame?
Can you draw the spacetime diagrams that will help it make sense? I don't see how it can help because as I pointed out significant events in one frame may not be significant in another frame.
  • other?
I stated what I meant in my original post: it doesn't make sense until "we remember that these are coordinates in a different frame".
General Relativity Experts? What has this got to do with General Relativity?
After you explain how you got the double-prime coordinates, if it's still relevant, I'll comment on the rest of your post.
Sorry I missed that question this morning bobc2.
Yes, space-time diagrams for the traveling twin's rest systems. (plural)
So there are two β values, 0.8 for the outbound trip, and -0.97561 for the inbound trip. For the first boost, I used (0,0) for the origin. For the second boost, I converted directly from the outbound reference frame to the inbound reference frame. I used (x=0,t=3) for the origin, and used a "translate"-"boost"-"translate back" strategy.
I was trying to follow along closely with what you did, with a little more matrices.
Here is a line-by-line explanation.
Code:
e1 = {x1, t1} = {0, 0};
e2 = {x2, t2} = {4, 5};
e3 = {x3, t3} = {0, 10};
This defines the original events in the original reference frame.
Code:
eventList = Transpose[{e1, e2, e3}];
(*This puts all of the relevant events into a matrix form:
[tex]eventList=\begin{pmatrix}<br /> 0 & 4 & 0\\ <br /> 0 & 5 & 10<br /> \end{pmatrix}[/tex]*)
Code:
MatrixForm[eventList]  (*Shown as Out[184]*)
(*This simply sent the output. Mathematica hides the output if you use a semicolon, and shows the output if you leave off the semi-colon*)
Code:
\[Beta] = .8;
\[Gamma] = 1/Sqrt[1 - \[Beta]^2];
LT = \[Gamma]*{{1, -\[Beta]}, {-\[Beta], 1}};
This is the Lorentz Transformation Matrix [tex]LT = \left( \begin{array}{cc} \gamma & -\beta \gamma \\ -\beta \gamma & \gamma \end{array} \right)[/tex]
Code:
outBoundEventList = Chop[LT.eventList];
This line performs the Lorentz Transformation. The dot (.) operator does matrix multiplication. The Chop function takes any value that is closer to zero than 10^-15 and zeros it out. It basically gets rid of a rounding error.
Code:
MatrixForm[outBoundEventList](*shown as Out[189]*)
Shows the result of the operation
Code:
reCenteredOutBoundList = Chop[
   outBoundEventList - {{0, 0, 0}, {3, 3, 3}}];
This translates all of the relevant events back in time 3 years (0,-3). Note the minus sign, putting the turn-around event at the origin. The goal here is to go through a process of "translate"-"boost"-"translate back" so that the transformation is done around the correct origin.
Code:
MatrixForm[reCenteredOutBoundList] (*Shown as Out[172]*)
{{X1, X2, X3}, {T1, T2, T3}} = reCenteredOutBoundList;
I'm just preparing, here, to calculate the velocity for the return trip. We have six numbers in the reCenteredOutBoundList, and we want four of them. This is the quick way to get them.
Code:
\[Beta]2 = (X3 - X2)/(T3 - T2) (*Shown as Out[174]*)
This calculates the velocity change needed for the return trip. This is mathematically, exactly the same thing you did. It came out to be the same value that you got.
Code:
\[Gamma]2 = 1/Sqrt[1 - \[Beta]2^2];
LT2 = \[Gamma]2*{{1, -\[Beta]2}, {-\[Beta]2, 1}};
This finds the Lorentz Transformation matrix needed for the return trip.
Code:
reCenteredInBoundList = Chop[LT2.reCenteredOutBoundList];
inBoundList = reCenteredInBoundList + {{0, 0, 0}, {3, 3, 3}};
This adds three to the hour on all of the events. This is the third step in "Translate"-"Boost"-"Translate back"
Code:
MatrixForm[inBoundList] (*Shown as Out[179]*)
That gives the relevant event coordinates in the final frame.
I will do that.
This event at (x=0, t=5) in the original reference frame seems significant to the nonmoving twin, why? Because that is the time he will (later) figure out that the traveling twin turned around. He doesn't see the inbound twin turn around at that time. He won't see the inbound twin turn around until much later, because of the speed of light delay.
Now, I have this temptation to say we should only worry only about "significant" events, events that the traveling twin actually observes. That temptation is probably pretty valid.
But what are those events that the traveling twin is going to observe? Well, if he's interested at all in figuring out Special Relativity, he's going to aim a telescope at Earth and observe EVERY event. He's going to be watching where he came from the whole time. So he WILL eventually see that event at (x=0,t=5), but when and where?
So he's not going to be just asking what his own watch says. He's going too be asking "What news from Earth? How far away am I from Earth?" And this question has a very INTERESTING answer (to me anyway). But you wouldn't know it by reading any of the texts on special and general relativity.
Pardon my late entry into the discussion. The paradoxical part of the "Twin paradox" stems from the implicit use of absolute time in a theory in which time is relative.
To be correct you must qualify the question "which twin is older/younger/are they the same age?" with some specification of the frame of reference. Each observer moving at a distinct velocity (vector velocity!) has a distinct definition of time and thus also a distinct definition of "at a given time" i.e. simultaneity of events.
The best way to express the paradox in my opinion is to have the triplets, two of whom leave home simultaneously (on their 20th Birthday) in craft traveling in opposite directions at relativistic speeds, say 80%c=4/5 c and the third staying home. Call them Adam, Bob, and Carl (Bob stays home).
You can then analyze the three questions:
When 20 years have passed for Bob how old are his brothers from his perspective?
When Adam is 20 years older how old does Bob and Carl appear to him (also how fast is Carl moving relative to him)?
When Carl is 20 years older how old do Adam and Bob appear to him?
Answers:
From Bob's perspective the event where Adam and Carl are simultaneous to Bob's 40th Birthday occurs 20 years and 16 light-years from the common launch event so Adam and Carl will each have experienced [itex]\tau = \sqrt{ 20^2-16^2}=12[/itex] years. They will be as Bob sees it, 32 years old.
From Adam's perspective Bob is moving away at 80%c so on Adam's 40th birthday the simultaneous event in Bob's life is 20 years and 16 light-years away from the launch event and that's 12years along Bob's lifeline so on Bob's 32nd birthday.
To see how Adam perceives Carl's events we need the relative velocities. Note that 80% (of c in c=1 units) is approximately [itex]c\tanh(1.0986123)[/itex], doubling the pseudo angle yields: [itex]c\tanh(2\times 1.0986123) \approx 0.97561c[/itex].
To add relativistic velocities ( as a percent of c) express them as hyperbolic tangents of a boost parameter and add the parameters. Thus Adam see's Bob moving at 80% c and sees Carl moving at about 97.561% c (boosted twice as much via the parameter.)
From Adam's perspective Carl has a simultaneous event 20 years and about 19.5122 light-years away (97.561% of 20y) from the launch event and that occurs when Carl has experienced [itex]\sqrt{20^2 - 19.5122^2} \simeq 4.39[/itex] years. Adam see's Carl as only 24.39 years old on Adam's 40th birthday.
Carl see's Bob and Adam in the symmetric way as Adam sees Bob and Carl.
This is the correct relativistic analysis and by making it symmetric we've removed issues of who has or hasn't accelerated. Specifically Adam and Carl each has experienced symmetric opposite accelerations.
In short, when each triplet reaches 40 years old,
As Bob calculates it, Adam and Carl are 32 years old.
As Adam calculates it, Bob turns 32, and Carl turns only 24.39
As Carl calculates it, Bob turns 32, and Adam turns 24.39
What you are calculating is the "current age of distant objects." What you probably don't know is that there is a raging controversy on this topic; (well maybe just a one-man-raging-controversy.) Namely Mike Fontenot is arguing that this is an important concept. I agree that it is an important concept. You, apparently agree that it is an important concept.
But General Relativity Experts are claiming that it is NOT an important concept. They apparently think that the "current age of distant objects" is a fabrication.
http://en.wikipedia.org/wiki/Talk:Twin_paradox#Unacceptable_original_research
This, along with the other blatant fabrications introduced by Michael Fontenot, should be removed, and no mention should be made here or anywhere else in the encyclopedia of his uncited paper from the unreliable source Physics Essays, which has failed for over 10 years to generate the slightest interest from professionals in the field.
Why do professionals in the field not have an interest in figuring out such a simple question?
Wow that's well said. I think that's the clearest & most accurate comment in this thread regarding the twin paradox.
Here is a space-time diagram created by WWoods for Wikipedia's Twin Paradox Article.
You can see discussion of that here:
here, here, and here
WWoods did a good job at picking out the events A, B, and C. B is simultaneous with the turn-around event in the home-frame. A is simultaneous with the turn-around-event in the outbound frame, and C is simultaneous with the turn-around event in the return-bound frame.
