Acceleration due to Gravity - Newton's 2nd?
  • Context: High School
  • Thread starter Thread starter wangdang
    Acceleration Gravity
The discussion centers on the nature of acceleration due to gravity and its constancy for all masses on Earth, exploring the implications of Newton's second law and gravitational theory. Participants delve into theoretical explanations, mathematical derivations, and conceptual clarifications regarding gravitational acceleration.
  • One participant questions why acceleration due to gravity is constant for all masses, referencing Newton's second law and suggesting that a body with double the mass should have half the acceleration.
  • Another participant argues that by doubling the mass, the force acting on the mass also doubles, which keeps acceleration constant at approximately 9.8 m/s².
  • A different viewpoint introduces the concept of relative acceleration, explaining that while the acceleration of an object falling toward Earth is influenced by both masses, the effect of the Earth's acceleration toward the object is negligible due to the large difference in mass.
  • One participant seeks clarification on the concept of relative acceleration and the combination of accelerations from both masses, expressing confusion about the derivation process.
  • Another participant notes that the acceleration derived from Newton's law is based on an inertial frame of reference, while relative acceleration is measured from a non-inertial frame, leading to further questions about combining these accelerations.
Participants express differing views on the nature of acceleration due to gravity, with some asserting its constancy and others highlighting the complexities introduced by relative acceleration. The discussion remains unresolved, with multiple competing perspectives present.
Participants mention the need for clarification on the assumptions underlying their arguments, particularly regarding the frames of reference used in measuring acceleration and the implications of mass ratios in gravitational interactions.
wangdang
Hi folks,
I know this topic has been discussed countless times before but I could not find an answer to my specific query.
I am struggling to understand why acceleration due to gravity is constant for all masses on Earth.
Newton's 2nd law says that the acceleration of a body is prop. to the influencing force (gravity in this case) and inversely prop. to it's mass:
a = F/m
Therefore why isn't it that a body with twice the mass has half the acceleration?
Could someone also provide an example (proving accel. due to gravity is constant) with real values, as this usually helps me with understanding.
Thanks in advance.
by doubling the mass you are also doubling the force acting on the mass causing "a" to remain constant
F/m = 2F/2m
remember that F will change as the mass changes, the only variable that should remain constant in a given location will be "a" in this case ~9.8 m/s^2
does that sound right?
Newton's second law is F=ma while his universal law of gravitation says that the force due to gravitation is F=GMm/r2. Putting these together says that the acceleration of some object of mass m falling toward the Earth is GM/R2.
However, the Earth is also accelerating toward the mass by Gm/R2. Combining the acceleration of the object toward the Earth and the acceleration of the Earth toward the object yields the relative acceleration
[tex]a_{\text{rel}} =<br /> \frac{G(M_{\oplus}+m)}{R_{\oplus}^{\,2}} =<br /> \frac{GM_{\oplus}}{R_{\oplus}^{\,2}}\left(1+\frac m {M_{\oplus}}\right)[/tex]
So it is not quite true that the acceleration is constant. However, because the fraction m/M is extremely small compared to one, we have [tex]1+m/M_{\oplus} \approx 1[/tex]. The acceleration of the Earth toward the object is not observable.
How small is that effect? Consider the Apollo 11, which at almost 3 million kilograms at launch is one of the heaviest objects ever lifted from the surface of the Earth. 3 million kilograms is about 5×10-19 Earth masses. So even for something as massive as the Apollo 11 at launch, its gravitational acceleration toward the Earth's surface is, to within 18 decimal places of accuracy, equal to the gravitational acceleration of those little chunks of ice that fell off the Saturn V during the launch of the spacecraft .
Thanks very much for the replies,
D H, I am not sure what you mean by 'relative acceleration'. Is that the overall acceleration of the 'system'? Could you also please explain your derivations? I understand that:
F = G (Mm/R^2)
is the force in which both masses experience.
Then combining Newton's 2nd you get:
ma = G (Mm/R^2)
a = G (M/R^2) <---- this is the acceleration of the test mass
Repeating this process for Earth's mass:
a = G (m/R^2)
And this is where I am confused. You know the acceleration of both masses but how do you "combine them".
I think I do understand your conclusion though.
Please correct me if I'm wrong:
Relative acceleration is proportional to m / M. Therefore a larger mass will yield a greater acceleration, but considering the denominator in the fraction (the Earth's mass), the increase is negligible.
The acceleration that you obtain using Newtons law is based on an inertial frame of reference. In the case of M and m accelerating toward each other, that inertial frame of reference would be the center of mass of M and m. The relative acceleration that you obtain using the equation in DH's post is based on a non-inertial frame of reference, which would be either M or m.
In other words, if you were standing on either M or m and you used some kind of instrument to measure the acceleration of the other mass toward you, then you would be measuring the relative acceleration. If you positioned yourself at the center of mass between M and m then you would measure the accelerations of M and m as predicted by Newtons law.
assuming a = G (M/R^2) and a' = -G (m/R^2) then
[itex]a_{rel} = a - a'[/itex]
D H, what does the [itex]\oplus[/itex] mean? / never mind, I looked it up. :) Although I'm not sure how you are applying it here. If it's the astronomical symbol for Earth then why do you use it with R?
  • · Replies 51 ·
  • · Replies 39 ·
