Acceleration of a Block on an Inclined Plane
11 replies · 33K views
riseofphoenix
7. A block of mass m = 5.5 kg is pulled up a θ = 22° incline as in the figure with a force of magnitude F = 38 N.
(a) Find the acceleration of the block if the incline is frictionless
So I got this one right, and here is what I did...
From the free body diagram I drew:
Fnet = (38 N) + (-mg sin 22)
ma = 38 - mg sin 22
a = (38 - mg sin 22)/m
a = [ 38 - (5.5)(9.81)(sin 22) ] / (5.5)
a = (38 - 20.211) / 5.5
a = 3.24 m/s2
(b) Find the acceleration of the block if the coefficient of kinetic friction between the block and incline is 0.12.
So...I know that
fk = μkn
fk = 0.12(Fappliedsin θ - mg)
QUESTION 1: So this is where I'm a little confused...Normal force should be UPWARDS, right? then would that mean that n = Fappliedsin θ + (- mg) after rotating my free body diagram so that I can see the axis better? Because I almost got the answer...
fk = 0.12[38 sin 22 - (5.5)(9.81)]
fk = -4.767 (the negative number makes sense since kinetic friction is OPPOSING the motion of the block which is moving up the incline.
So then I add it to the equation for acceleration at the top
ma = (38 N) + (-mg sin 22) + (-4.767)
a = [ 38 - (5.5)(9.81)(sin 22) - 4.767 ] / (5.5)
a = 13.022 / 5.5
a = 2.36 m/s2
This answer is wrong...Webassign says the answer is actually a = 2.15 m/s2
QUESTION 2: Where did I go wrong? Was it the normal force equation part?
riseofphoenix said:
So...I know that
fk = μkn
Right.
Not right.
The normal force is 'normal'--perpendicular--to the surface. Figure out the normal force by analyzing force components perpendicular to the incline. They must add to zero.
Doc Al said:
Right.
Not right.
No wait...
it would be
-mg + (-mg sin 22)?
Doc Al said:
Right.
Not right.
It's just F cos θ, which is 38 cos 22...
But I still don't get the right answer when I multiply 0.12 by 38 cos 22, and then add 4.22 to this equation...
ma = 38 - 20.11
a = (38 - 20.11 + 4.22) / 5.5 doesn't give me 2.15 m/s2
Something else is wrong
The applied force F is parallel to the incline. It has no normal component.
The weight of the block, being vertical, will have a normal component.
So it's -mg cos 22?
Which is basically -(5.5)(9.81)(cos 22)...
fk = 0.12[-(5.5)(9.81)(cos 22)]
fk = -6.003
So,
a = [ 38 - 20.211 + (-6.003) ] / 5.5
a = 2.159638636
Thanks!
riseofphoenix said:
So it's 5.5 cos 22?
Almost. What's the weight of the block?
It's just 5.5 kg isn't it?
No, that's the mass.
oh...Weight = mg
Weight = -(5.5)(9.81) = -53.955 N
riseofphoenix said:
oh...Weight = mg
Right. The weight = mg and acts downward.
Ohh ok!
Thanks a lot!
