Acceleration problem. me vs book
  • Thread starter Thread starter Rhine720
    Acceleration Book
A bus traveling at 30.0 km/h accelerates at 3.5 m/s² for 6.8 seconds. The book states the final velocity is 120 km/h, while the user calculates it as 115 km/h. The user converts the initial speed to meters per second and applies the formula Vf = Vi + a x delta t, arriving at 115.668 km/h. The discrepancy is attributed to significant figures, with the book rounding to 120 km/h. The user acknowledges the oversight regarding significant figures in their calculations.
Rhine720
A bus is traveling at 30.0 km/h speeds up at a constant rate of 3.5 ms/^2. What velocity does it reach at 6.8 seconds later?
book says 120.km/hour
I get 115 km/hour
Vf=Vi+a x delta t
First I changed 30.0 km/hour to 30000 m/3600s then reduced to 8.3 m/s. Used formula to get Vf=32.13m/s
I divide 32.13 by 1000 to get .03213 km/s then 1.9278 km/m then 115.668 km/h.
I've worked this problem a hundred different ways and get the same answer. AM i right or the book?
Looks like you and the book are correct. I would assume that the book is answering the question to 2 significant figures, thus 115.668km/h is 120km/h assuming your math is correct.
oh my goodness i forgot all about sig figs. Thank you very much
14K
9K
