How can I calculate wheel thrust for a given acceleration and time?
  • Context: Undergrad
  • Thread starter Thread starter MrDieselT
    Accleration Speed Time
The discussion focuses on calculating wheel thrust required to accelerate a 5000 lb vehicle to 75 mph in 15 seconds. The key formula referenced is F = dp/dt, where F represents force, dp is the change in momentum, and dt is the change in time. The calculated wheel thrust is 3600 pound-force, equating to an average acceleration of 7.33 feet per second squared. The conversation also highlights the impact of air resistance and rolling friction on acceleration, particularly at higher speeds.
  • Understanding of Newton's Second Law (F = MA)
  • Basic knowledge of vehicle dynamics and acceleration
  • Familiarity with torque calculations at the axle shaft
  • Concept of G-forces and their application in automotive performance
  • Research "Calculating vehicle acceleration using force and mass"
  • Explore "Torque calculations for electric vehicle motors"
  • Learn about "Air resistance and rolling friction in vehicle dynamics"
  • Investigate "Battery pack design for electric vehicles"
Automotive engineers, electric vehicle designers, and anyone involved in performance calculations for vehicles will benefit from this discussion.
MrDieselT
Ok so here's what I'm trying to figure out:
Given a required time i need to figure out how much wheel thrust is required to accelerate a car or truck to a given speed. (ie take a 5000 lb car to 75 mph in 15 seconds...)
I've been searching but can't find a good formula to use.
please help
omg, I was just talking about this formula in another thread!
f = dp/dt! lol!
(note: lol is not a part of the formula)
could you break that down for me. what is dp and dt? and I'm thinking f is force?
I can find the G Force exerted on the car i just don't know how to turn that into time to a given speed
here is what i have so far
Givens:
Weight: 5000 lbs
Wheel Radius - 10 in
Tq @ Wheel 3000 ft-lbs
Calculated:
Wheel thrust = 3600 pound-force of thrust = .72 g
Let's break it down a bit. 75mph is 110 ft per second. If it takes 15 seconds to get to 75 mph, the vehicle experiences an average acceleration rate of 7.33 feet per second squared or about .23 gs. That means that your 5000 lb vehicle has to generate an average of 1140 lbs of thrust, or 950 ft lbs of torque at the axle shaft for your tire size.
If you could accelerate at a constant .72 g, you'd reach 75 mph in 4.74 seconds. Better dial up the boost!
thanks! actually I'm working on designing a EV truck with 6 150hp AC motors one on each wheel so making enough tq for 15 seconds is not a problem... my problem is building a battery pack, Super Cap pack and generator to power it all.
Now how does this work if i start at say 25 mph and want to go to 75 mph with all the same numbers
F = MA so to accelerate at the same rate (A) you continue to apply the same force as calculated. BUT: only when air resistance and rolling friction becomes significant do you have to worry about "drag"...that depends on the shape of your car...but might be appreciable at maybe 40 MPH and up...
Well, since your change in speed is now 50 mph instead of 75 mph ...
This of course assumes that your acceleration rate stays constant, which it won't for a few reasons (two listed above) but I'm thinking that you're after a general trend rather than the exact numbers.
Yeah i know acceleration won't be constant but tq will remain constant thanks to nifty little devices called VFDs. like you said I am just after the general numbers not the exact one. thanks for you help!
  • · Replies 41 ·
