Acoustics and Frequency Question (easy)
3 replies · 2K views
sobo22
1. Two nearly identical forks one of which has a frequency of 384Hz produce 7 beats per second when they vibrate at the same time. A small clamp is placed on the 384Hz fork and then only 5 beats per second are heard. What is the frequency of the other fork?
I honestly have no idea
Well I know the answer is 377 and I've been trying to work backwards but the only thing I can think of is 5 +/- uncertainty then 2 for the change in beats so 7? But even then I have no idea why it would be 377 vs 381.. Can someone please help me out I'm so lost
Look up the equation for beating (Wikipedia has it, for example).
hey thanks man. So would it be
f = f1 - f2
f2 = f1 - f
f2 = 384 - 7 (amount of beats) = 377?
what about the 7 to 5 beats thing, is that just irrelevant filler?
does someone mind explaining the concept of it? I am still lost
is it because 7 beats are heard so that means there is a difference of 7 hz?
At first there are 7 beats between the forks, so you know their frequency difference -- but do you actually know whether the second fork is higher or lower than 384 Hz?
What happens to the frequency when you attach a "small" clamp to the 384 Hz fork?
