Adding extra socket share with water heater power supply
Adding an extra socket to a water heater power supply for light usage raises safety concerns. The original setup and proposed add-on connection lack clarity, making it difficult to assess safety. Experts advise against making such modifications without a thorough understanding of electrical systems. Specifically, using a double pole switch to interrupt the neutral is not standard practice in the USA. Overall, it is recommended to consult a qualified electrician before proceeding with any alterations.
JJ1
It is safe to add on extra socket by this way?
Original connection:
postimg.org/image/v6nshoygh/
Add-on connection:
postimg.org/image/vkoccsyu5/
The extra socket is for light usage only. Water heater is instant water heater without tank. The switch is double pole single switch.
Please give me some advise.
That drawing really doesn't tell us anything. If you have to ask, you shouldn't do it. If you have a reference book that explains something like this well and you completely understand it then go ahead and do it. My bet is that you will not. A circuit that feeds a tankless water heater will be too large to safely run a light circuit. In the USA we never interrupt the neutral so right off the bat you are wrong (if you are in the USA) with a double pole switch as I am assuming you will use one pole to switch the neutral and the other to switch the hot.
Likes JJ1 and davenn
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 51 ·
  • Sticky
  • · Replies 701 ·
24
117K
  • · Replies 20 ·
27K
  • · Replies 21 ·
13K
