MHB Additional intercept form problems.
  • Thread starter Thread starter jamescv31
    Form
This discussion focuses on solving intercept form problems using the equation $$\frac{x}{a} + \frac{y}{b} = 1$$. For part (a), the equation of the line passing through the point (-5, -7) with a y-intercept of 3 is determined to be $$y = 2x + 3$$, with the slope (m) calculated as 2. In part (b), the correct equation derived from the x-intercept of 1/3 and y-intercept of 2/5 is $$6x + 5y = 2$$, achieved by applying the "invert and multiply" rule for fractions.
  • Understanding of intercept form equations
  • Familiarity with slope-intercept form
  • Knowledge of cross multiplication and the "invert and multiply" rule
  • Basic algebraic manipulation skills
  • Practice deriving equations from given intercepts using the intercept form
  • Explore the concept of slope in linear equations and its significance
  • Learn more about the "invert and multiply" rule in fraction operations
  • Study examples of converting between different forms of linear equations
Students learning algebra, educators teaching linear equations, and anyone seeking to improve their understanding of intercept form problems.
jamescv31
Hello, I'm here for another related intercept form problem of the formula: $$\displaystyle \frac{x}{a} + \frac{y}{b} \:=\:1$$
a) Find the equation of the line passing through (-5,-7) AND with y-intercept 3.
b) Find the equation of the line passing with x-intercept 1/3 and y-intercept 2/5.
I'm not sure how this solution will be, I need this as my reference pattern.
Thank you.
Note: In letter B I couldn't figured since its a fraction and the way of having an LCD might be unsure of the correct equation so really need an informative information.
Also in Letter A, we don't have an example related for that.
Mathematics news on Phys.org
For part a) I would begin with the slope-intercept form, using the given intercept of 3:
$$y=mx+3$$
Now, use the given point $(x,y)=(-5,-7)$ and you will then be able to solve for $m$:
$$-7=m(-5)+3$$
For part b) I would use the two-intercept form you cited, and recall the "invert and multiply" rule for division by fractions:
$$\frac{c}{d/e}=c\cdot\frac{e}{d}=\frac{ce}{d}$$
Can you proceed with a) and b) now? Please feel free to post your progress. :D
Here's my progress, in letter a)
is it an M as slope only? not the whole equation? because the answer of my M is 2.
Then on letter B my equation answers as $$6x+5y-30=0$$?
Yes, $m=2$, and so your line is:
$$y=2x+3$$
For part b) that isn't quite correct. Can you show your work so we can see where you went wrong?
I'm not sure on how the "invert and multiply" works.
$$x/1/3 + y/2/5 = 1
x/5 + y/6 =1 [/math] I made like a cross multiplication it becomes
[Math] 6x + 5y = 30$$ then made an LCD to obtain the
You use cross multiplication when you have two fractions that are equal to one another. What you want to do here is:
$$\frac{x}{1/3}+\frac{y}{2/5}=1$$
Invert and mutliply:
$$x\frac{3}{1}+y\frac{5}{2}=1$$
Multiply through by 2:
$$6x+5y=2$$
