AdS/CFT as quantum to classical correspondence
22 replies · 5K views
naturale
This paper proposes an intuitive interpretation of basic aspects of Maldacena's conjecture in QFT and of the mathematical beauty of extra-dimensional theories. Its ansatz is that every particle is a reference clock. It is a peer-reviewed paper and uses an extremely original and simple formalism. Please discussed the paper in a fair and objective way.
Classical geometry to quantum behavior correspondence in a Virtual Extra Dimension
Donatello Dolce
In the Lorentz invariant formalism of compact space-time dimensions the assumption of periodic boundary conditions represents a consistent semi-classical quantization condition for relativistic fields. In [arXiv:0903.3680] we have shown, for instance, that the ordinary Feynman path integral is obtained from the interference between the classical paths with different winding numbers associated with the cyclic dynamics of the field solutions. By means of the boundary conditions, the kinematics information of interactions can be encoded on the relativistic geometrodynamics of the boundary [arXiv:1110.0315]. Furthermore, such a purely four-dimensional theory is manifestly dual to an extra-dimensional field theory. The resulting correspondence between extra-dimensional geometrodynamics and ordinary quantum behavior can be interpreted in terms of AdS/CFT correspondence. By applying this approach to a simple Quark-Gluon-Plasma freeze-out model we obtain fundamental analogies with basic aspects of AdS/QCD phenomenology.
Subjects: High Energy Physics - Theory (hep-th); High Energy Physics - Phenomenology (hep-ph)
Journal reference: Annals of Physics, Volume 327, Issue 9, September 2012, pp 2354-2387
http://arxiv.org/abs/1110.0316
This paper is a Copernican revolution in physics :bugeye:. After more than 10 years it gives the formal prove of AdS/CFT, equ.(66), from clock periodicities. Must be read and understood.
Are you the author?
mitchell porter said:
Are you the author?
No. I'm not the author.
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction" A. Einstein
Why do you have such confidence in the correctness of his work?
I read papers, it is published on a peer-reviewed journal, it is an intriguing idea. Why don't you read the paper and see if you can get the same conclusions?
It seems that Dolce's big idea has nothing to do with AdS/CFT. He seems to be claiming that quantum mechanics is a manifestation of a compact timelike direction. That is, some time "t" in the future is literally the same as a time "0" in the past; space-time joins up with itself like a donut in which one of the cyclic directions is timelike. Quantum mechanics is to result from imposing these timelike periodic boundary conditions on a classical theory.
But then he talks about individual particles having individual internal times, with the time to repetition depending on the mass. I do not see how to make sense of this. Consider a particle that is created at one point in space, travels through it, and then gets absorbed somewhere else. There's no time loop, so what is the meaning of the "compact internal time" here? The original idea is to take repetitive behavior, like the cycling of the phase factor in an energy eigenstate, and to interpret it the successive cycles as literally identical: the next cycle doesn't just repeat the previous cycle, it is the same thing, because space-time loops back on itself. That might make sense if it was done on a single global scale, like a Godel universe, but how can you apply this interpretation to an object which is clearly created at one time and destroyed at a later time?
Regarding AdS/CFT, he only engages with it superficially. AdS/CFT is an identity of two quantum theories, a correspondence between a quantum string theory in AdS space and a quantum CFT on the boundary of that space. There are lesser versions of the correspondence in which you only concern yourself with a classical limit of the AdS theory, and he seems to be talking about that, and then trying to relate it to his earlier ideas about repeating time. I assure you that there is no proof of AdS/CFT here (and certainly no real discussion of either of the quantum theories in the duality), just some elementary talk about classical boundary conditions in AdS, that are combined in a confusing way with the already confusing ideas about cyclic time.
Quite a few people have tried to get QM from time loops. A few others hope to get quantum mechanics emerging along with gravity and the extra dimension, in an extended version of holographic duality. There are time loops in some versions of AdS. So it would be really interesting if you could indeed get QM on the boundary from time loops in a classical AdS bulk.
But I don't see anything like that here. I suppose it's obvious that I struggle to make sense of the paper, and that I think it is based on conceptual confusions that are hard to track down because they are never explicitly stated and rigorously defined, instead they are spread throughout the text as background assumptions. Maybe I'm missing something and it all makes sense somehow, but really, I doubt it. I have tried at least to pull out some of the component ideas which make sense by themselves, and to indicate how they might have been combined into a comprehensible research program, but I do not think that program is what Dolce is following, he's doing some other confused thing.
You have completely missed the meaning of the idea. Congratulation!
Read "Comments and Outlook" at the end of the first section. Everything is made of particles, particles are clocks (periodic phenomena with cyclic time, as the angular variable in waves), then everything is described by cycles! The (virtual) AdS tells the particle how to vary "ticks" as Schwarzschild metric in gravity. Think a couple of days about that and then let us know.
"The wise man points to the moon, the fool looks at the finger" - Chinese proverb
This is what Dolce does. He derives QM (on the boundary of a virtual extra dimension, which is not a real extra dimension) from time loops of elementary clocks/particles.
Let's start with something really simple and tell me if you agree with my assessment.
It is possible to build up perturbative quantum field theory from the concept of particles in energy-momentum eigenstates. Interactions can be expressed in terms of annihilation and creation of particles in such states, and then we can construct wavepackets as desired, by summing appropriately over the momentum eigenstates.
Dolce has constructed some sort of correspondence between these space-time-filling, single-particle, energy-momentum eigenfunctions, and classical fields in a space-time with compact periodic time. Many times in his paper, he will mention 4-momentum, and then follow it with a supposedly equivalent statement about 4-periodicity. The question is whether this adds anything of substance to the original theory. So far it seems to be quite superfluous.
Yes, you can take perturbative quantum field theory, and where you would normally talk about 4-momentum eigenstates, you can instead talk about "4-periodicity in the virtual extra dimension". I can only see two ways for this to mean anything: it's a step towards the true physical ontology, or it is a fruitful new mathematical trick. But I don't see how to interpret the locally varying VXD as something real (though presumably Dolce is interested in this option, given his "boson determinism" paper), and I don't see what it allows us to calculate better (I didn't yet try to figure out what's going on in the QGP section, but the derived formulas look relatively elementary).
You have passed from
to the opposite
The correct attitude is right in the middle between this doesn't "make sense" and this doesn't "add something new". It is like a Copernican revolution, like using the sun as origin of your coordinates rather than the earth, an idea that suddenly simplifies everything. Or like passing from a model with flat Earth to a spheric earth. It may seem absurd or trivial, depending on the point of view, but it works.
I agree with this. It is more correct to say: extra dimensional formalism is a mathematical trick to describe quantum physics as proposed by Klein. This is the meaning of "virtual" extra dimension and the interpretation to AdS/CFT proposed by Dolce.
Thank you very much for posting this Naturale. This is best papers I've read in a while and agree with you that the ideas in here are quite revolutionary. There was one minor thing I didn't understand though, perhaps you can help clear it up. On page 9 Dolce says the periodicity transforms contravariant near eq (9) but near eq (11) he says it transforms as a covariant tangent vector. This is mystify to me.
Mitchell Porter, I quite certain you do not understand what is AdS/CFT. On the other AdS/CFT thread (I can't quote because is locked) you wrote: "AdS/CFT duality is a highly nontrivial equivalence between two quantum theories. The bulk of this paper talks about purely classical relations like boundary conditions. Quantum mechanics hardly shows up, except for a few token comments."
This is just... wrong. Consider Witten quote that appears in Dolce paper. "In AdS/CFT quantum phenomenon are encoded in classical geometry." AdS/CFT correspondence is that the symmetry group of AdS space and 4D conformal theories are the same. It doesn't matter what you do in the AdS space or if you use a classical or quantum field on boundary. The thing that is interesting is that can use string theory and can use QFT.
No that is not Dolce's idea at all. That is Tooker's big idea. You confusing the threads. Dolce only mentions in passing that intrinsic periodicity can be applied to entire universe. Dolce's big idea is to to derive a time from the de Broglie relations and use as a backbone to support a field theory.
If read the paper you would see that the internal time is much shorter than the time that is taken between creation and annihilation. Furthermore, you are confusing what Dolce says about isolated systems with more complicated scenarios. Dolce writes:
"However, such a non-elementary system in general has no periodic dynamics, as the ratio of periodicities doe snot necessarily form a rational number."
Again you are confusing this thread with [the other one that has Tooker's paper](https://www.physicsforums.com/showthread.php?t=665116). Dolce makes use of fundamental period of oscillation derived from the de Broglie relations and doesn't use cyclic time for anything but in a brief aside on the few pages Naturale suggested that you read. (I admit I have only read 20 pages, but I do not see cyclic time when I flip forward and it is not relevant to basis of the Dolce inquiry.)
In order to get on with my life, I would like to withdraw from this discussion. I never wanted to engage with these papers; my first impressions were wholly negative; I only attempted a quick intuitive assessment in order for there to be a counterbalance to naturale's bombast. It would have been wiser to say nothing and to quit is the wise course now.
But I will repeat that AdS/CFT is an equivalence between two quantum theories. The prototypical example is N=4 super-Yang-Mills and the thesis is that it is equivalent to Type IIB string theory in AdS_5 x S^5. These are both quantum theories. That some of the features of the quantum theory on the boundary can be related to classical properties of the bulk, does not mean that the correspondence stops there.
Thank you BandwagonNinja :smile:
Indeed it is a revolution! - this explains why my other posts on the topic in other threads are mysteriously disappeared, though the idea is published in several peer-reviewed papers and PF rules say "Generally, discussion topics should be traceable to standard textbooks or to peer-reviewed scientific literature."
It is a typo. Check the other papers, he always says contracovariant tangent vector.
You are welcome in this discussion. Criticisms are vital in science. But sometimes, papers are so original that it is not sufficient a rapid scan to understand them. It is necessary to follow the derivation of the idea and see if it really works, step after step. Try and you'll see. Science is this! This is the scientific method! This idea cannot be ignored. AdS/CFT, like string theory, after many years of speculations, allows several different interpretations ("one for every taste"). This paper tries to restart from ground zero, to reconsider the foundations of both. They are amazing mathematical properties (ex: classical to quantum correspondences). There is surely something correct. Dolce has tried to find the correct idea at the base of the complicated universe of AdS/CFT, avoiding crap things. He is not a criminal.
You may think this is in competition with mainstream researches. On the contrary, it is a new possibility for physics. If you are a researcher you probably dream to be part of a Copernican revolution, this idea looks like chance. :wink:
No actually mitchellporter is right. The AdS/CFT correspondence is not just that the symmetry group of AdS space and 4D conformal theories are the same. The fact they are the same points towards a duality, but this coincidence does not a duality make. In order to proof there is actually a duality between two theories you have to do nontrivial checks, like calculating the partition function and some correlation functions. The most famous example that mitchellporter brings up has been heavily tested (and is between two quantum theories) and there are plenty of similar dualities we don't fully understand, even though we know the symmetry groups match.
Also even though the duality relates quantum aspects of one theory to classical aspects of another doesn't imply any quantum/classical correspondence. In the weakly coupled limit of string theory we obtain objects from classical geometry (as we should if it and SUGRA are to reduce to GR), but the duality from which these relations spring is still between quantum theories and hopefully still holds for all values of the coupling constant.
Quote by mitchell porter
Are you the author?
https://www.physicsforums.com/showthread.php?t=664870
https://www.physicsforums.com/showthread.php?t=307961
https://www.physicsforums.com/showthread.php?t=424860
https://www.physicsforums.com/showthread.php?t=310733&page=2
If you're not the author you sure do show an affinity for his work.
It is my understanding that AdS/CFT is fundamental a correspondence between abstract mathematical objects. The theories we can build in these objects are very interest, and that why there is interest in AdS/CFT. AdS/CFT is the narcissus name for holography principle no? Perhaps I am mistaken, but you have not convinced me. Perhaps you and I make semantics.
AdS/CFT dualities obey the holographic principle, but not vice versa. That is the holographic principle is an older and broader concept then AdS/CFT. AdS/CFT refers specifically to just one kind of duality where the holographic principle comes into play.
The AdS/CFT duality is not a correspondence between abstract mathematical objects, it is a relation between a CFT in d-1 dimensions to string theory (or a theory whose origin is in ST) in d dimensions. Neither of these are well defined mathematical objects. There are QFTs that have been put on a rigorous footing by mathematicians, but for the most part this is not the case.
To a certain extent there is some bad language at play. AdS/CFT has become a catchall for many different ideas and for holography in general, although it is just one subset of ideas.
Please look at eq. 2.11 of Witten paper hep-th/9892150. He then writes: "The generating function of these correlation functions [quantum] would be the partition function [classical] of the conformal field theory ..." Then you can quantize as much as you want things that are already quantized, but you won't describe reality. The central meaning of AdS/CFT is give by eq. 2.11 (or similar). Dolce has derived that equation just from clocks.
Also even though the duality relates quantum aspects of one theory to classical aspects of another doesn't imply any quantum/classical correspondence. In the weakly coupled bla bal bla... .
If, as you say, "duality relates quantum aspects of one theory to classical aspects of another", where is the quantization? Where does QM emerge? Dolce answers to this simple question, He concludes that quantization is in the (virtual) extra dimensional formalism.
His arguments are correct, if you believe in mathematics.
All your questions are discussed in Dolce's paper. Please read it.
Concerning holography try with ctrl-F and write "holography". He mentions holography 50 times.
You'll see that:
"For instance, it is well known that in General Relativity (GR) the deformations of space-time associated to gravitational interaction encode the modulations of space-time periodicity of reference lengths and clocks, [44]. Moreover, [2], in this formalism the kinematical information of the particle is encoded in the geometrodynamics of the boundary in the manner of the holographic principle [45, 46]."
"a collective description of the KK modes typical of a VXD is implicit in the usual holographic description of an ordinary KK theory."
"In an ordinary XD theory, holography provides an effective and collective description of the propagation of the KK modes. However, as already noted at the end of sec.(5), by assuming a VXD, such a collective description is already explicit, even without holography. In fact the virtual KK modes naturally describe the quantum excitations of the same fundamental system (string), i.e. they are not independent fields. On the other hand, the fundamental"
read also "Comments and Outlooks" pag.40.
Holography mades the extra dimension "virtual", and virtual extra dimension is quantization.
Now they are better defined mathematical objects.
I agree. This paper catches the origin of that enormous subset of ideas. The result is spectacular. :cool:
I assume you're referring to blackwagonninja because I didn't have any questions about holography and was trying to explain the distinction between AdS/CFT and holography. That they are not equivalent terms. In fact I never mentioned the contents of the paper because I have not read it yet.
I don't understand why you would need to quantize. The point of AdS/CFT is that you have two quantum theories and you can simplify calculations for strong coupling if you take the classical or semiclassical limit on one side. Typically you take the semiclassical limit of a string theory to obtain a theory of supergravity, which has classical geometrical objects, but there is no need to then quantize the theory because we already know its (more) quantum origin: string theory.
There is no quantization. Quantization refers to a process by which we construct a quantum theory out of a classical theory. Here both theories in the duality are quantum and we can recover semiclassical in the limit of weak coupling.
As I said before, I haven't read the paper in full yet, the primary purpose of my post was to explain that the ads/cft duality is much more complicated then checking symmetry groups. If and when I read the paper I would be happy to have a discussion on it.
Again, in this limit you have a correspondence between classical and quantum. AdS is used to compute quantum. Think to AdS/QCD. Witten is explicit in this "quantum phenomena such as the spontaneous breaking of the center of the gauge group, magnetic confinement, and the mass gap are coded in classical geometry." Where the quantization is in passing from classical in d dimension to quantum d-1 dimensions?
Let me understand. Are you saying you prefer to work with "not well defined mathematical objects" - your words? Is this because you can publish without too many complications as nobody of us will be here when N=4 super-Yang-Mills or Type IIB string theory in AdS_5 x S^5 will be tested to be wrong or correct? Are you saying that you prefer epicycles as long as people believe in that, no matter what physical reality is? If this is want you think about science, I must be twice grateful to people like Dolce and their courageous researches.These kind of black swans carry on science.
Dolce proposes a extreme reconsideration of particles nature and proves in detail a solution to longstanding issues. Every fair physicist has the duty to check whether he is correct or not.
Does it make sense to say "every particle is a clock"? Do eq.6 or eq.56 describe particles?
I am make think. Why do they no call it IIB/QFT correspondence? To me it is evident that when researches on IIB/QFT it was discovered the much bigger and more general thing AdS/CFT. But they do not call IIB/QFT so it must not be that. Pardon me for beating dead horse.
