Advantages of Three Wheel Boot Strap System Airconditioning
  • Thread starter Thread starter Rahul Mohan P
    System Wheel
The discussion revolves around the advantages of a three-wheel Bootstrap air-conditioning system compared to a two-wheel system in air cycle machines used in aircraft environmental control systems. Participants explore various aspects of these systems, including operational efficiency and thermodynamic considerations.
  • One participant seeks clarification on the advantages of the three-wheel system over the two-wheel system.
  • Another participant expresses unfamiliarity with the systems and requests a source for further information.
  • A participant suggests that the three-wheel system may provide a more controlled airflow through the heat exchanger, particularly benefiting passenger comfort on the ground.
  • There is a repeated assertion that thermodynamically, the difference between the two systems may not be significant.
  • A later reply discusses operational perspectives, noting that the three-wheel system may allow for easier fault diagnosis and maintenance compared to the two-wheel system, which has more components to check.
Participants express differing levels of familiarity with the systems, and while some speculate on the advantages of the three-wheel system, there is no consensus on the overall benefits or drawbacks of either system.
Participants reference operational and thermodynamic aspects without providing detailed definitions or assumptions, leaving some points open to interpretation.
Rahul Mohan P
Hi
I want to the advantages of three wheel Bootstrap air-conditioning System over two Wheel system in an air cycle machine used in aircraft environmental control system. Can anyone please help.
I've never heard of any of that - there may be a translation issue. Can you provide a source describing these different systems?
Just an guess, maybe educated or not.
But the three wheel provides a more controlled amount of air through the heat exchanger from the fan being connected to the shaft.
It would work "better" on the ground for the comfort of the passengers I think, when there is no forced air from the movement of the airplane.
Thermodynamically there doesn't seem to be all that much of a difference if any.
Yes may be you are right.Thanks Dude.
As an after thought, rather than from just a design perspective, there is also the operations perspective.
The number of system components to check for proper operation, and if a fault detected then mantainance turnaround.
With the three wheel, if the airconditioning doesn't function, the fault can be pinpointed more directly to the AC unit - replace the unit.
In the two wheel, is it the fan for forced flow and/or its electrical circuit, or the AC unit. Mechanics have a few more things to check.
  • · Replies 24 ·
