Aharonov-Bohm topological explanation
171 replies · 22K views · last reply
tom.stoer said:
No!
Integrating around closed loops tells you something regarding topology, winding number etc. The integral is NOT path-independent in general but only path-indep. for homotopic paths. That's one key lesson: the magnetic flux IS a topological quantity related to the first homotopy group of the base manifold.
Once again you start with a negative and then go on to say what I'm saying in other words rather than answering specific questions.
TrickyDicky, I don't get your point b/c there seems to be no point at all!
I do not start with the negative! I simply say that the integral is not path-independent in general (this is contary your statement). The path-dependence related to the first homotopy group is is one key factor in understanding the topology of the AB effect. So I do not simply repeat what you are saying "in other words", there is a fundamental difference
And I do not answer specific questions b/c I don't see them. So what are your questions? (and what is missing in our explanations?)
mfb, strangerep and Jano L. got what I was saying perfectly well. For the last two the solution came from discarding the topology as relevant to the effect, an opinion I don't agree with.
Well, then you dindn't understand my wording, I was precisely underlining that the path independence is NOT general but TOPOLOGY DEPENDENT, are you actually reading what I write?
Have you not spotted posts #56 and #59 for instance?
For a particle that behaves symmetrically with respect to external fields, path independence would be broken if the curl of the particle's internal field (projected outward) were interrupted by an obstacle of some kind, right? Are there other obvious reasons for a breakdown of path independence?
This is how the magnetic AB effect is described in wikipedia just for reference:"The most commonly described case, sometimes called the Aharonov–Bohm solenoid effect, takes place when the wave function of a charged particle passing around a long solenoid experiences a phase shift as a result of the enclosed magnetic field, despite the magnetic field being negligible in the region through which the particle passes and the particle's wavefunction being negligible inside the solenoid. This phase shift has been observed experimentally.
The magnetic Aharonov–Bohm effect can be seen as a result of the requirement that quantum physics be invariant with respect to the gauge choice for the electromagnetic potential, of which the magnetic vector potential A forms part.
Electromagnetic theory implies that a particle with electric charge q traveling along some path P in a region with zero magnetic field B, but non-zero A (by [itex]\mathbf{B} = 0 = \nabla \times \mathbf{A}[/itex]), acquires a phase shift [itex]\varphi[/itex], given in SI units by
[itex]\varphi = \frac{q}{\hbar} \int_P \mathbf{A} \cdot d\mathbf{x},[/itex]
Therefore particles, with the same start and end points, but traveling along two different routes will acquire a phase difference [itex]\Delta \varphi[/itex] determined by the magnetic flux [itex]\Phi_B[/itex] through the area between the paths (via Stokes' theorem and [itex]\nabla \times \mathbf{A} = \mathbf{B})[/itex], and given by:
[itex]\Delta\varphi = \frac{q\Phi_B}{\hbar}.[/itex]
In quantum mechanics the same particle can travel between two points by a variety of paths. Therefore this phase difference can be observed by placing a solenoid between the slits of a double-slit experiment (or equivalent). An ideal solenoid (i.e. infinitely long and with a perfectly uniform current distribution) encloses a magnetic field B, but does not produce any magnetic field outside of its cylinder, and thus the charged particle (e.g. an electron) passing outside experiences no magnetic field B. However, there is a (curl-free) vector potential A outside the solenoid with an enclosed flux, and so the relative phase of particles passing through one slit or the other is altered by whether the solenoid current is turned on or off. This corresponds to an observable shift of the interference fringes on the observation plane." End quote
I'm only centering on this part of the quote: "but non-zero A (by [itex]\mathbf{B} = 0 = \nabla \times \mathbf{A}[/itex])", to make the addition that is not mentioned in the wikipedia that what is between parenthesis only hold when the space is simply connected, and that requirement is precisely the one demanded by the explanation of the effect that not be fulfilled.
Is this apparent contradiction so hard to see?
I'm not sure what you mean by "behaves symmetrically with respect to external fields" and " internal field (projected outward)".
Anyway here the obvious reason for a breakdown of path independence is the nontrivial topology.
TrickyDicky said:
... then you didn't understand my wording, I was precisely underlining that the path independence is NOT general but TOPOLOGY DEPENDENT, are you actually reading what I write?
Where have you written this statement?
I saw these posts and I already commented them:
In #56 you are asking "What do you mean is not required, there is no effect without a magnetic flux inside the solenoid" I said (quite often in the meantime) that there is a difference between the magnetic FIELD (which is zero outside and which is NOT required) and the magnetic FLUX as calculated via the line integral.
Please try to get the following statement: the AB effect does not require any B-field; it can be expressed purely in terms of the A-field; and the A-field is evaluated purely outside the solenoid where the B-field is zero. The electrons do not interact with an B-field but with an A-field!
In #59 you are asking "how does the independent of path closed line integral of A work?" I think we agree that there is no path independence in general.
OK; so what are you specific questions that have not been addressed? (sorry for insisting on these questions, but I want to avoid answering the wrong questions or addressing issues that are already clear to you)
tom.stoer said:
Where did you wriute this?
Tom, it is the key to my argument so it is all over my posts but for instance "Integrating around the closed loop independently of path requires the trivial topology" meaning that it requires simply connectednes, in post #55.
I am not sure whether I get this point (which was not addressed to me, I guess) "Integrating around the closed loop independently of path requires the trivial topology".
The phase shift measured is
[tex]\Delta\phi \sim \oint_C A[/tex]
This does neither require trivial topology (or Stokes theorem to calculate the flux) nor any B-field.
Let's cite Wikipedia:
The Aharonov–Bohm effect ... is a quantum mechanical phenomenon in which an electrically charged particle is affected ... despite being confined to a region in which both the magnetic field B and electric field E are zero. The underlying mechanism is the coupling of the electromagnetic potential with the complex phase of a charged particle's wavefunction ...
This is the AB-effect!
The next sentence refers to the very specific case of solenoids, but this is only one possible experimental setup, not the general case:
The most commonly described case, sometimes called the Aharonov–Bohm solenoid effect, ...
So all you need is
[tex]\oint_C A \neq 0[/tex]
There seems to be some confusing communication regarding "path dependence." Probably we can all agree on the following unambiguous statements:
1. In a simply connected space where curl(A) = 0 everywhere, line integrals of the A field are path-independent.
2. In a non-simply-connected space where curl(A) = 0 everywhere, line integrals of the A field may be path-dependent.
TrickyDicky, I have the sense that you are arguing as follows: "People claim that the line integral of A depends on the winding number around the solenoid, because the space R^3 \ (solenoid) is not simply connected. But this is nonsense. The actual physical space is simply connected. Therefore the line integral of A cannot be path dependent. In particular, it's nonsense to claim that the line integral can depend on something topological like a winding number when the physical space has no nontrivial topology to speak of."
Correct me if that's a misrepresentation; it's just a guess at what you are getting at. In any case, the response is that the two cases above neglected the actual physical case:
3. In a simply connected space where curl(A) is NOT everywhere zero, line integrals of the A field may be path dependent.
If the physical space is simply connected, what justification do we have for talking about non-simply-connected spaces and reasoning topologically? The point is that if you work in the simply connected space, but don't consider line integrals that intrude into the solenoid, you get the same results for line integrals as if you had worked in the non-simply-connected space. Therefore whatever topology has to say about line integrals in the non-simply-connected space also applies to the same line integrals in the simply connected space.
I think this addresses another point you seem to be making, namely, "People talk about this non-simply-connected space, but simultaneously use Stokes' theorem, which does not hold in such a space, to discuss the magnetic flux."
Only in the simply connected space can you apply Stokes' theorem. Only in the non-simply-connected space do you have nontrivial topology and winding numbers. But since you get the same line integrals and the same physics either way, we feel comfortable talking about Stokes theorem and nontrivial topology at the same time, even though strictly speaking we are imagining different spaces in each case. We're just using different mathematical tools to get the same answer.
Agreed.
Thanks for trying to understand my point. Your interpretation is not exactly what I was getting at but not so far either. I can see the difference between our actual space and the space of the experiment, and see the logic behind the path dependence of the R^3 \ (solenoid) space of the experiment.
But the electrons are always in the non-simply connected space, no?
This is closer to my point, yes.
I'm just not sure you get the same line integrals and therefore the same physics if the Stokes theorem doesn't apply to the space of the experiment.
I don't know, I guess I'll just study it better, I might as well just leave it here.
Thanks everyone.
thanks, I think this should contribute to clarification; my arguments seemed to be - at least partially - distracting.
Regarding the_duck's the last paragraph, a) simply connected space and application of Stokes' theorem and b) non-simply-connected space i.e. nontrivial topology and winding numbers: that was the reason for me to cite Wikipedia. I wanted to make clear that they are talking about two entirely different things, namely a non-vanishing loop integral over A (which is the general case for the AB effect) and the solenoid case which is a rather special experimental setup.
tom.stoer said:
I am not sure if I get your point; are you saying that the existence of A satisfying B = rot A is ruled out b/c the space may not be contractable?
Yes, not so much as rule out, but certainly it makes one wonder what's going on.
The problem is that "existence" has not yet been well defined.
What topology tells us is that the existence of a global A-field and a global B-field is indeed problematic; that's the reason we have to use R³ \ R instead of R³. A- and B-field are not well-behaved on R³.
This can be seen by using the A-field outside the solenoid
[tex]A = \frac{\Phi}{2\pi r^2}(-y,x,0) = \frac{\Phi}{2\pi}\nabla\theta[/tex]
and taking the limit
[tex]r \to 0; \Phi = \text{const.}[/tex]
Physically this seems to be unproblematic b/c the electrons only "feel" the flux as a physical observable via the phase
[tex]e^{i\Phi}[/tex]
which remains constant. But the A-field as defined above and the gauge function
[tex]U = e^{-i\Phi\theta / 2\pi}[/tex]
from which it can be derived as
[tex]A^\prime = 0 \to A = U^\dagger\,(A + i\nabla)\,U[/tex]
cannot be defined globally; r=0 has to be excluded from our configuration space, i.e. from the base manifold, which results in R³ \ R.
That means that we can define
[tex]F = dA = 0[/tex]
locally but not globally.
[tex]dA = 0[/tex]
means that A is locally flat i.e. has vanishing curvature 2-form F (i.e. vanishing el. mag. field strength, i.e. E=0, B=0) locally.
In other words A is pure gauge locally i.e. A ~ A' = 0 but not globally.
What Stokes' theorem (and cohomology) tells us is that
[tex]\oint_C A[/tex]
does only depend on the homotopy class of the loop C w.r.t. r=0, i.e. it depends only on the winding number
[tex]w[C] = n = 0,\pm 1,\pm 2, ...[/tex]
of the loop C around the r=0.
Using Stokes' theorem naively
[tex]\int_{\partial M} \omega = \int_M d\omega\;\;\to\;\; \int_{C} A = \int_D \nabla\times A = \int_D B = 0[/tex]
one would derive a vanishing magnetic flux. But this is wrong due to the fact that the extension of A from the loop C to the disc D is not allowed due to the above mentioned singularity in r=0. Therefore the naive application of Stokes theorem is wrong, but this is due to the r.h.s. (= the surface integral) not due to the l.h.s.
Physically one can save the theorem by explaining the B-field via the solenoid, i.e. via replacing the A-field and the B-field by the solenoid solution on a disc D. Mathematically one can save the story by using the locally flat A-field outside and vanishing B-field! Instead one has to cut out the disc D with shrinking radius such that one arrives at R³ \ R where the A-field is well-defined.
That means that the physical solenoid can be replaced by the non-trivial base manifold R³ \ R.
Now the question remains what is physically meaningful. At first glance one could argue in favor of the solenoid with non-vanishing B-field, but even this may be obscure: iff (if and only if) we know that the A-field has been prepared using a solenoid everything is fine. But we (and the electrons) are not able to penetrate the solenoid, so there is no physical mechanism to distinguish between the "physical solenoid" and the "R³ \ R".
What I am saying is that if somebody prepares an impenetrable solenoid with locally flat but non-zero A-field outside w/o telling you any details, you are not able to distinguish between the following two scenarios:
a) the impenetrable solenoid contains a non-vanishing B-field
b) the impenetrable solenoid wraps a topological singularity
Tom, I do not understand how you can write solenoidal field as a gradient in that way. Is the angle [itex]\theta[/itex] in your writings a multiple-valued function of position? Otherwise we get sudden jump of A at [itex]\theta = 0[/itex], which makes the loop integral zero...
I am not sure whether I understand you problem. It's true that θ is in [0,2π[ and that therefore θ itself is not a "global coordinate". But that doesn't matter b/c all physical quantities are well-behaved:
The first definition of A is fine.
The loop integral becomes a multipliation by the length i.e. by 2π for constant and is OK.
The gauge transformation has been introduced via U which is periodic in θ and therefore well-defined.
Therefore the gradient acting on U is well-defined, too; acting on θ may be problematic, but this is due to θ, not due to the gradient
θ itself is not a globally well-defined coordinate, and in principle one would have to use a "cut R²" with several charts using different angle coordinates; but as usual in physics I am a bit sloppy and avoid all this stuff.
OK, now I get it, your prescription gives correct solenoidal A without delta function in A. I mistakenly thought that we would get delta function in A due to chain rule and jump in theta. But now I realize the chain rule does not apply for [itex]e^{i\theta}[/itex], so it is OK.
Tricky Dicky: I read the passage in the book by Nash&Sen and also sec. 2.2 in D. J. Thouless, Topological quantum numbers in nonrelativistic physics, (1998) which Wikipedia cites and was surprised that they do not say more than that topology is somehow relevant to BA shift. They do not elaborate on that.
Furthermore, the papers on BA effect I have seen in PR do not seem to claim that considerations of topology are necessary.
So can you give some reference to work where the authors really show there is some connection ?
It depends on what you call the AB effect ;-)
According to Wikipedia The Aharonov–Bohm effect ... is a quantum mechanical phenomenon in which an electrically charged particle is affected ... despite being confined to a region in which both the magnetic field B and electric field E are zero. The underlying mechanism is the coupling of the electromagnetic potential with the complex phase of a charged particle's wavefunction ... Following that line of reasoning one may conclude that the effect is due to locally but not globally flat gauge field which indicates a non-trivial vector bundle structure, so in this general setup it's a topological effect.
http://www.encyclopediaofmath.org/index.php/Bohm-Aharonov_effect
http://iopscience.iop.org/0143-0807/9/3/007
But physically one could simply study the most commonly described case, sometimes called the Aharonov–Bohm solenoid effect, ... which does by no means require any topological reasoning.
As you may have observed I think that topology of gauge field and vector bundles is more fundamental than one specific experimental setup (just as quantization of action is a more fundamental principle than the black body radiation). I hope the above mentioned reference clarifies some of the topological concepts.
I don't have access to your second reference, so let me follow line by line the encyclopedia of math one:
"A phenomenon in which the topological non-triviality of a gauge field is measurable physically [a1]. Moreover, this topological non-triviality, which can be expressed as a number , say, is a global topological invariant and so is not expressible by a local formula; this latter point being in contrast to a simpler topological invariant such as the dimension of the underlying space, which is deducible locally."
I think we all agree with this paragraph, the main reason of the need for globality being IMO that homotopy relations always contain global information as it is well known.
In the next line is where I find my conundrum rather than with the effect itself:
"To demonstrate this effect physically, one arranges that a non-simply-connected region of space has zero electromagnetic field . This electromagnetic field is related to the gauge field by the usual relation F=dA"
The usual relation F=dA for a non-simply connected region is not granted, that is what I mean by my doubts about the existence of the A-field in this particular not simply connected set up(see my link "A short rant..." from the Unapologetic mathematician to check this).
Here in the 5th paragraph:
"If we flip over to the language of differential forms, we know that the curl operator on a vector field corresponds to the operator [itex]\alpha\mapsto *d\alpha[/itex] on 1-forms, while the gradient operator corresponds to [itex]f\mapsto df[/itex]. We indeed know that *ddf=0 automatically — the curl of a gradient vanishes — but knowing that [itex]d\alpha=0[/itex] is not enough to conclude that [itex]\alpha=df[/itex] for some f. In fact, this question is exactly what de Rham cohomology is all about!"
In our case F is a 2-form and A is a one-form. See also the wikipedia page "Closed and exact differential forms" to see that a closed form like F=0 needs a simply connected space to imply F=dA.
I don't know why you say the solenoid effect, that is an example of the AB effect, "by no means require any topological reasoning". I don't think your distinction between a topological general effect and a non-topological special magnetic case is founded. See this: http://rugth30.phys.rug.nl/quantummechanics/ab.htm
The relation F=dA is granted locally but not globally, so F and A may required patching, cutting out singularities etc. In the case of the A-field as described above one has to remove r=0. On this R³ / R the relation F=dA=0 is valid (so "not globally" means "not on R³ but on R³ / R").
In the solenoid case one has a finite disc with non-vanishing B-field; one has a regular solution inside the solenoid; one can use Stokes' theorem w/o any problem. In the case with a point-like singularity at r=0 there is a vanishing B-field; there is an A-field with dA=0 in R³ / R, so the explanation via a B-field is invalid b/c it's zero. The solenoid case can be realized experimentally; this is not possible for the R³ / R case. Therefore this distinction is relevant.
tom.stoer said:
The relation F=dA is granted locally but not globally, so F and A may required patching, cutting out singularities etc. In the case of the A-field as described above one has to remove r=0.On this R³ / R the relation F=dA=0 is valid (so "not globally" means "not on R³ but on R³ / R").
But you need it to be granted globally, at least at the global region where electrons are influenced by the A-field so their wave function is shifted.The homotopy from R^3 to R^3/R always carries global information.
In any case I don't think is granted locally either for the R^3/R case and you haven't explained why.
The solenoid case should work just like the idealized case, you guarantee the simply- connectedness just by making the electrons unable to traverse the solenoid. So you are removing r=0 just the same.
Come on! it is granted locally! you can see A (it has been written down ;-) and you can check dA=0 by explicit calculation of the curl; and it is granted globally on R³/R b/c the check works for all (x,y,z) when r=0 is excluded
In case,if one transform to a frame which moves uniformly with respect to any original one it is possible to eliminate magnetic field,in that frame of course the so far gauge invariant integral is zero.In that case the effect comes from A0, by a phase like-q/h-(∫∅dt),negative in sign with original one.Now here no line integral,no stokes theorem,or I should say no topology?
You should realize that you are taking for granted A everytime, if we are debating the existence of A, you cannot write dA=0 to beging with bc then you are already assuming it. You are affirming the consequent to quote the UM. ;)
Wrt to the trick of cutting out the singularity r=0, well it is a bit silly since then we get back to R^3, and it defeats any further consideration about the problem of a non simply connected space for the existence of an A-field.
I guess my doubt is more related to topology and vector calculus than to the quantum mechanical effect itself since it involves a step previous to the effect proper, so I might take it to the Topology and geometry subforum.
Can you show us the calculation? From what I understand you start in the A°=0 gauge in the rest frame and then transform to an inertial frame which moves parallel to the solenoid.
