Aharonov-Bohm topological explanation
171 replies · 22K views
Now one could in principle use the Dirac equation to re-derive the AB effect; but I don't expect any fundamental difference
are you talking about the reality of A.from the hamiltonian for free dirac field one can readily get dirac eqn.Just minimal coupling is required for getting interaction with EM field.How can dirac eqn be used to derive AB effect.(Schrödinger can also be used then,right!.it does not make difference.)
as already said: I don't see any fundamental difference; all I wanted to explain is that the standard approach for the AB effect (non-rel. Schrödinger equation) can be derived from full QED (QED → Dirac eq. → Pauli eq. → non-rel. Schrödinger eq.)
yes,sure.Now please can you tell something about the conclusion of this thread in terms of topological consideration.thank you.
One conclusion is that an impenetrable solenoid with a given flux can be replaced by a space R³ with a line R removed, i.e. R³ \ R on which a non-vanishing A-field exists. This A-field is "pure gauge" locally, i.e. A ~ U* dU with dA = 0, but not globally b/c the line R prevents us from constructing a global gauge function U' to gauge away this A → A' = 0 globally.
This can be extended to more than one flux line R, R', R'', ..., i.e. several lines removed: R³ \ R \R' \ R'' ...
Then there is a non-local flux observable ∫A which corresponds to a topological quantity, the cohomology of the one-form A of the fibre bundle of the U(1) gauge group over the base manifold R³ \ R. This ∫A depends on A and on the the path C via an integer winding number w[C] of the path C w.r.t. the line R.
This can be expressed in terms of the gauge function U = exp(iχ) from which A can be constructed as U* dU, therefore already this U carries the full information on the topological structure.
Note that in principle it's not ∫A which is observed directly but only the fractional part of the flux mod 2π/q (where q is the value of the electric charge of the particle). This is due to the fact that we study the compact gauge group U(1) with U ~ exp(iχ), not only the gauge function χ. This is related to the problem of the logarithm χ of U on R³ \ R. There are continuous single-valued gauge functions U where χ jumps by 2πw along a path C for winding number w[C], the simplest one is χ ~ θ where θ is the cylindrical angle coordinate w.r.t. the z-axis.
So this results in a quite complex structure of the gauge group defined over R³ \ R; one may see this by applying the following gauge fixings:
1) gauging away A° = 0
2) gauging away A³ = 0 (we assume that the line R corresponds to the z-axis) with a time-indep. gauge function respecting A° = 0
(up to now this is standard)
3) now there is a residual gauge symmetry with t- and z-indep. gauge transformations U respecting A° = 0 and A³ = 0 such that the integral part of the flux is still unobservable, i.e. related to a global residual gauge symmetry
So the Aharonov-Bohm effect is related to a physical observable
[tex]\phi_C = \oint_C A \;\text{mod}\; 2\pi[/tex]
which is the "fractional part of the flux".
This is defined in terms of a pure gauge vector potential
[tex]A = U^\dagger i\nabla U[/tex]
which is sensitive to the topology of the base manifold, i.e. we have
[tex]\phi_C = \phi_C[/tex]
So neither the base manifold nor the gauge group alone are sufficient top describe the Aharonov-Bohm effect; what really matters is the topology of the fibre bundle F which locally (i.e. for each point of the base manifold M) looks like a direct product F ~ M * U(1); but a non-trivial structure of M, i.e. R³ \ R induces a non-trivial structure of F, and we finally arrive at the conclusion that the physical observable is sensitive to
[tex]\phi_C = \phi_C[F][/tex]
A final remark: this consideration can be generalized to arbitrary base manifolds (not necessarily 3-dim., complicated singularity structure, ...), arbitrary gauge groups and arbitary compact integration sub-manifolds (complicated knots, higher dimensional submanifolds, ...).
Doing that one is no longer doing physics but rather differential geometry and algebraic topology, i.e. one is studying topological structures of manifolds using fibre bundles constructed over these manifolds (or one is studying knot invariants expressed in terms of gauge field configurations in R³).
This is all fine, but when we restrict ourselves to 3D with time as parameter NRQM/classical ED(prior to relativistic formulation) space the following are relevant points:
-In R^3/R the classical Kelvin-Stokes theorem is not valid , so no observable ( fractional part of) flux in this topology.
-Given this we are again stuck with an A field that has gauge freedom, and therefore can't be a physical observable.
-In a purely NRQM or classical ED interpretation(without using the relativistic covariant formulation), with only three dimensional space and time as parameter, local action is not respected and therefore there is "action at a distance".
However:
-In the context of QED which is the one your explanation is valid in, local action is respected and in that sense there is no "action at a distance", and yet we still have nonlocality since there is no separability, nor observability which are required together with local action to consider the effect local.
The conclusion is that the A-field interpretation of the effect respects local action principle but that is because the Lagrangian density that integrates over spacetime is used, since we are calling A-field to the 4-potential while I was actually restricting to the 3-vector potential of classical Maxwellian ED without covariant formulation, R^3 and the Lagrangian with the integral over time.
Finally, as commented in post #120, the QFT-QED interpretation itself is not without severe ontological problems, for instance:"First there is the general problem faced by any interpretation of a quantum field theory. In this case this involves understanding the relation between the quantized electron field and the electrons which are its quanta on the one hand, and the relation between the quantized and classical electromagnetic fields on the other. Without some account of the ontology of quantum fields one can give no description of either electromagnetism outside the solenoid or the passage of the electrons through the apparatus, still less a separable description. And one is therefore in no position to show that interactions between these two processes conform to Local Action", but that belongs more to the philosophy of science.
Right, we have here not just the manifold non trivial topology but the gauge group non trivial topology. So we need for this interpretation additional structure to the base manifold, that of the principle bundle with its non trivial gauge potential, and this additional mathematical structure is not governed by the field equations which leads to indeterminism of the AB effect.
DickyTricky, I just summarized some well-known topological consideration andrien asked for. Everything is standard textbook, well estanblished, known for yearsm and there is no reason for any further discussion.
Anyway ...
Please try to understand my reasoning (or if you like read some standard textbooks) to learn why the fractional part of the flux is an observable; and forget about the Stokes theorem; you need it to convert the integral from a line to a surface integral; but I don't need this theorem in this context b/c I do not use a surface integral; the flux is encoded in the loop integral over A !
I never said that A is an observable; the loop integral mod 2π is an observable !
There is no physical result which depends on the formulation (using 4-vectors or not); ED is always covariant, even if you don't use 4-vectors; the action is local, and there is no action at a distance.
TrickyDicky said:
-In the context of QED which is the one your explanation is valid in ...
My explanation (all explanations on the AB effect) is valid in non-rel. QM; I never used QED, I never quantized the el.-mag. field.
TrickyDicky said:
... since we are calling A-field to the 4-potential while I was actually restricting to the 3-vector potential of classical Maxwellian ED without covariant formulation, R^3 and the Lagrangian with the integral over time.
As I already said; the explanation and the effect does in no way depend on the formulation; the formulation of electrodynamics and its gauge symmetry is more transparent using 4-vectors, but physics is not affected, of course (classical electrodynamics didn't change after introduction of 4-vectors; the Maxwell equations today predict the same physics as they did 150 years ago)
Sorry, but as long we do not agree on basic problems in quantum mechanics it seems too early to try to discuss ontological problems in quantum field theory.
I just summarized some well-known topological consideration andrien asked for. Everything is standard textbook, well established, known for years and there is no reason for any further discussion.
Book?which book.I have never seen any book describing AB effect in terms of topology of fiber bundle.:confused:
I think Nakahara has a nive chapter on the AB effect; he discusses fibre bundles, perhaps w/o explicitly mentioning the AB effect, but the relation should not be too difficult. Nash and Sen have no chapter on the AB effect afaik, but they provide the necessary topological tools as well. I never studied Frankel's book but from the contents I see that he discusses the AB effect in a chapter on vector bundles.
Edit:
Perhaps this paper is interesting: http://128.84.158.119/abs/0909.0370v2
Edit 2:
DickyTricky, that was a comment on your way of questioning the explanations; they are not mine, they are standard in mathematical physics; and they are even used by mathematicians themselves. Of course my explanations can be unclear to you, and other texts may be better formulated (pedagogically). But it is really frustrating that you are questioning arguments I have never put forward; two examples: you always argue against the Stokes theorem which is never used in the topological context; you always argue against A being an observable which I never claimed. In order to make progress you should focus on facts, not on guesses
Sorry if I give that impression, part of it has to do with my struggling with english (not to mention with math and physics ;-)).
So yes I know you are not claiming A is an observable, and no, my last post was not arguing against anything in your post nor saying the standard explanation is plain wrong or anything like that.
Wrt the Stokes theorem which to save further confusion I should clarify I'm not referring to the general theorem but to the classical Stokes-Kelvin one used in vector calculus in the Euclidean 3D setting, this one requires the topological condition of simply connected space, I'm just making that distinction.
By the way you claim you are not mentioning QFT but I associate loop integrals with Feynman diagrams.
You are right that a particular formulation should not be of relevance to the physics, but I'm actually referring to the difference between considering a 3 dim. space vs a 4 dim. spacetime, I hope you admit this makes a difference, you just have to take a look to the last 100 years in physics.
Thanks, that clarifies a lot!
OK, fine, then we agree
Of course, I understand. I only wanted to make clear that nothing follows from this theorem b/c I don't use it.
OK, just to clarify that: I called the line integral [itex]\oint A = \int_C A[/itex] using a closed loop C a loop integral; perhaps that was misleading; it's nothing else but a standard line integral evaluated for a classical field A; sorry for the confusion!
TrickyDicky said:
... but I'm actually referring to the difference between considering a 3 dim. space vs a 4 dim. spacetime, I hope you admit this makes a difference, you just have to take a look to the last 100 years in physics.
No, it doesn't make any physical difference. The formulation is different, the math looks different, but the results are identical; whether you use the lengthy Maxwell equations or whether you simply write dj = 0, d*F = 0 makes no physical difference. You can mix all these formulations w/o running into trouble.
ohh,thanks again.Got all of them.:devil:
But how do you relate the magnetic flux with the line closed integral of A, then?
By using the gauge function U, right?
I'm not talking about the formulation only, but I agree the physics happens to come out the same because the topological properties of infinite dimensional Hilbert spaces in the NRQM case allow it (I'm referring to the unitary group U(1)).
Just to be sure whenever you refer to A, you mean the EM 4-potential or the magnetic 3-vector potential?
Tom, the paper you linked in #160 is interesting even if it adds further complexity, some of it helps clarify some of the things I was arguing and you considered wrong, for instance:
"Many authors consider infinitely thin solenoid and the Euclidean space R3 with removed
axis corresponding to the solenoid as the base M. In this case, the base M is not
simply connected, and the Aharonov–Bohm effect could be called topological. As was
shown earlier, this is not necessary. It is sufficient to assume that the magnetic field differs
from zero only in the bounded region on the plane, and the integration contour does
not cross this region. Moreover, if we assume that the base M is the Euclidean space R3
with removed axis then the Stokes formulae is not applicable, and hence the expression
for the Aharonov–Bohm phase through the magnetic field flux (26) requires additional
assumptions. So the Aharonov–Bohm effect must be considered as geometrical rather
then topological
The loop integral [itex]\oint A[/itex] is the flux; w/o considering a B-field I do not need anything else; the gauge function U is only oused to construct the A-field.
I never talked about the "topological properties of the Hilbert space"; I am talking about topology of the base manifold or about the fiber bundle. There is no need to refer to the Hilbert space structure in order to understand the AB effect
In principle yes, but it doesn't matter b/c
[tex]\int_C dx^\mu\,A_\mu = \int_C dx^i A_i[/tex]
b/c C has no timelike direction, i.e. x° is constant along C, i.e. dx°=0 on C (in addition one can fix the A°=0 gauge)
You do realize that in order to make that identification between the integral and the flux you are using the Stokes theorem, don't you?
No, I am not using the Stokes theorem; at least not in the standard way.
The idea is the following: usually the magnetic flux through a surface S is related to the line integral along a curve C (which is the boundary of S). Now b/c the A-field is the fundamental entity, from now on I never use the B-field through S but only the A-field through C.
So now I call [itex]\oint A[/itex] the magnetic flux; I never use B, I don't care about it; it's a derived quantity, and I can explain all physical effects w/o ever using B. There are even effects (the Aharanov-Bohm effect ;-) where the explanation via B is cumbersome or not sufficient and where I should use A instead.
So instead of using the surface integral [itex]\int_S B[/itex] to define the magnetic flux, and then relating it to the line integral along C via Stokes' theorem, I would argue the other way around: I use the line integral [itex]\oint_C A[/itex] to define the magnetic flux! I don't need any B-field which is
a) not the fundamental entity
b) not sufficient to explain the AB-effect
c) requires the applicability of Stokes's theorem
So from principle of maximum simplicity it follows that we need not (should not) care about B, S and Stokes theorem; all what matters is A and C.
I don't known whether you know the philosopher Ludwig Wittgenstein and Wittgenstein's ladder from Tractatus Logico-Philosophicus:
"My propositions serve as elucidations in the following way: anyone who understands me eventually recognizes them as nonsensical, when he has used them - as steps - to climb beyond them. He must, so to speak, throw away the ladder after he has climbed up it"
Here the ladder is B, S and Stokes' theorem ;-)
I see, nice post, I've always admired Wittgenstein(BTW thanks for bearing with my questions).
Do you agree that starting with the loop integral of A to get the flux is not allowed unless you consider the vector potential physically significant to begin with, but that is something that classically was not considered possible, and that is only considered the right explanation from a prediction in QM and the empirical proof of the AB effect.
TrickyDicky said:
Do you agree that starting with the loop integral of A to get the flux is not allowed unless you consider the vector potential physically significant to begin with, ...
yes, one must attribute a fundamental, physical role to the vector potential; otherwise this reasoning would not be forbidden, but physically unreasonable (*)
TrickyDicky said:
... but that is something that classically was not considered possible, ...
no, it is possible classically, but it's not necessary in classical electrodynamics; there everything, including interaction with charged particles, can be described in terms of E and B; A is only an auxiliary variable;
(*) one could even say that using A introduces gauge invariance and unphysical redundancy which has to be removed via gauge fixing, so in some sense using A instead of E and B could even be seen as pointless
TrickyDicky said:
... and that is only considered the right explanation from a prediction in QM and the empirical proof of the AB effect.
yes, it's QM which indicates that one should use A instead of B; [itex]\oint_C A[/itex] is a physical, gauge invariant observable in classical electrodynamics; but it's QM which tells us that we should better use [itex]\oint_C A[/itex] instead od [itex]\int_S B[/itex]; in classical electrodynamics based on (*) we would prefer [itex]\int_S B[/itex]
