AI vs. Humans as Processors in an Environment
  • Thread starter Thread starter BillTre
75 replies · 8K views
256bits said:
Should the concept of agent be terminated at the single cell, or continue down into the cell internal structure including the proteins and chemicals within that react to their local environment .
If it's useful in helping to understand what they do, sure.
"Agent" is a model. It's a tool for human understanding. It's something we use to describe the world, including ourselves.
PeterDonis said:
The best heuristic I can give is that anything that can do something, even something very simple, on its own, without being told what to do, is an agent. A thermostat, for example, tells your heating or A/C to turn on and off, without being told when to do it. So it's an agent--an extremely simple one.
An agent cohort myself, if I must commit.
Just wondering if the agency concept and classifications can explain anything more easily than a cause and effect approach that the physical sciences has depended upon to explain the world. EDIT I see your above posting - makes sense/
Control systems and machines have a whole branch of science dedicated to design and analyse that has worked so.
Would Boeing ever use the agent concept to produce their planes?
Or ASML use agency concepts to explain how their $300 million UEV ( low x-ray ) machine is so precise that the laser within has an error along the lines of pinpointing the edges of a dime on the moon from earth?
These are complex machines, the ASML being said to be the most complex ever produced, and yet both not fully or completely having an AI brain controlling their operation would have to be designated as being closer to the simple model of the agency spectrum.
Point being that complexity may not signal the intelligence of the machine as outlined in the agency model.
For any system where it's computationally intractable to predict its behavior using physical laws, yes, if it can be modeled as an agent, that's a benefit. Humans, of course, are the obvious example: nobody predicts any human's behavior using physical laws. But we predict each other's behavior pretty well, in general, by modeling each other as agents.
There's an intermediate level of modeling, which Daniel Dennett called the design stance, where you aren't using physical laws directly, you're treating the system as having an abstract design and being made out of physical parts that will do what they're designed to do, but without any attribution of agency. For a thermostat, this stance works as well as modeling it as a very simple agent, because its design is so simple and uses such simple physical parts: a temperature sensor, a couple of switches and relays, and some logic gates. But even then we're not using physical laws directly.
Autopilots in planes are examples of simple agents. And actually nowadays they're not even all that simple, they can do more than just "fly the plane straight and level on this course", which was their original purpose.
Which needs a human operator to do anything, right? So no, it would not be an agent. It doesn't do anything without being told to by a human operator.
Someone may appreciate this, even if not directly applicable to the opening OP,
Dune by Brian Hebert was a series of books, the first being Dune: The Butlerian Jihad. One of the characters is named Serena Butler, whose murder of her son is the catalyst for the uprising of the humans against their machine overlords. So, some speculation as to why the name Butler and Butlerian Jihad.
Rewind to Samuel Butler , 1863. The publication of a letter to the editor " Darwin among the Machines". Whether this is from where Hebert selected the Butler name, it still is an interesting read of imagination of machines as being a separate group of species.
https://diogenesii.wordpress.com/wp-content/uploads/2013/06/darwin-among-the-machines.pdf
256bits said:
Can one believe at the same time in evolution and its processes of randomness of natural selection, and teleology
The normal evolutionary process can be conceived of as having two parts: the production of variability (random to some degree or not) and the selection of the variants for those that are well adapted to their situation (meaning they are more likely to live long and prosper). In this way variants of control mechanisms can be produced (at "random"). However, those that most functionally benefit the organism (or living system) will propagate to a greater extent and come to dominate in succeeding generations. The step of selecting of the "good" or "bad" variants has been compared to an engineering step.
This is pure natural selection.
256bits said:
which in its final extension leads to some sort of divine intervention?
This part is not required.
256bits said:
Ie-the universe has a purpose.
One might say the purpose of the universe is to make self-assembling or self-propagating entities before its heat death, or one might not say that.
Divine intervention not required.
sbrothy said:
"Enchanted Looms" is another good book about this subject.
Looked this up.
It seems to be a similar to the wetware book but focused on the nervous system and the possibly emergent process of consciousness.
256bits said:
Can one believe at the same time in evolution and its processes of randomness of natural selection, and teleology which in its final extension leads to some sort of divine intervention? Ie-the universe has a purpose.
Plenty of people claim to believe both, for whatever that's worth.
jack action said:
From the link I gave above, note that the first four classes of intelligent agents are pretty similar, each one having an add-on over the simpler one. The model for the fifth one is completely different, though. This might help reconcile the facts that every automated machine is an agent, and that there is also a big difference between the decision processes of a human (or even an equivalent AGI) and a thermostat.
I probably just have a very layman-ish access to the topic. I'm well aware it's a discussion I'm never going to "win" (which was also never my point). It just seemed almost outrageous to me to compare the agency of a roomba and a human. I realize though that that's not what you're doing. Darn my idiot intution! Why do I get myself mixed into these discussions?!
Ah well, I learn something every time. It's not a complete waste of time (for me at least :woot:).
jedishrfu said:
Yes MS destroyed many promising companies in their rise to dominance.
Zip tools when MS introduced a compressed filesystem. I don't think users responded well to this new os since disk failures become unrecoverable for text files that looked encrypted.
OS/2 when MS repackaged the code to sell Windows NT. IBM made sure MS didn't get access to the networking part of OS/2 and also sold separately as a product. When Windows NT would have a system fault the error would say OS/2 error.
Lattice C initially resold by MS until they expanded their compiler portfolio with multiple languages including C. Lattice faded away a few years later.
M$ have a history of either buying up their competition or downright squashing it, for instance by copying their product and giving it away for free. Not many startups can survive that.
And who can forget United_States_v._Microsoft_Corp.
As a wise man once said, Confusuous perhaps, or it could have been Sydney Sweeneey, I forget.
"A man who asks can only be fool for a minute. A wise man who doesn't ask is a fool for life."
Or something like that, you get the drift/
Anyways,
Ye old style of thinking, with humans superior to all else.
Humans - have agency, purpose, free will, make choices, etc.
Animals - act only on instinct.
Machines - totally dumb
along comes New Materialism
The divide between humans and animals erodes. Animals really do have some agentic qualities. And recently plants.
Along comes AI
Machines are also brought into the fold.
Since human-machine interactions can effect each others 'self' --- *self in quotes* -> as of now theoretically it is still more human centric, ( or supposed to be, contrary to the tech's and pundit's doom and gloom marketing scheme to attract $/ See post 66 to where that can lead for their version of the future )
And if AI, then why not all machines.
The Biology and Economics described their field with agency lines for ages with good reason.
How can one get away from statements such as "The Heart pumps the blood."
The philosophy has extended itself into other fields. Any fruit to pick off from the tree, some are not so sure, while others try it out.
https://en.wikipedia.org/wiki/New_materialism
Here is an open access review article from Genetics on the unction of sevenless in Drosophila retinal development (from the Genetics Society of America. This is a well known (among those interested in fly neurobiological development) research story that stretches back about 50 years.
Its relevance to this thread is that major aspects of this developmental process have been documented in great genetic and cellular detail (reviewed in the article). Many "decisions" made by molecular interactions between a variety of cells are described. The effects of specific mutations on the process are also described. Decisions between are contingent upon cellular interactions that maybe or may not occur underlie the process. There are many small agent-like processes involved in the larger process of fly eye development.
It is often overlooked that components of biological processes are usually multiple in number (tens to thousands or more in a small cell like an E. coli). in addition, these parts often distributed over the vast molecular volume of a single cell or even among several different cells and therefore receiving different inputs.
The smallness and large numbers of the interaction parts reminds me of an interesting old Feynman article, There's plenty of room at the bottom. It can be found here.
I found this blog post by James Somers and Edwin Morris which goes into great detail about what I consider agentic molecular behavior of the simple prokaryotic cell E. coli.
It is concerned with how E. coli detects chemical gradients which then drive its behavior (movement). Going up gradient of certain chemical gradients is how these guys find their food (specific molecules).
More efficient finding of food provides a reason to select these agency mechanisms because they allow better solving of the problem of getting food.
This has been heavily studied molecularly and genetically (E. coli lots of mutants) and worked out in great detail.
It has many nice visuals.
