Calculating Air Volume for Boat Stability in Water
  • Context: High School
  • Thread starter Thread starter champ2823
    Air Water
The discussion focuses on calculating the air volume required for pontoons to stabilize a 15' aluminum boat, enabling it to float a total weight of 300 pounds. Utilizing Archimedes' principle, it is established that to achieve this buoyancy, the pontoons must displace an equivalent weight of water, which is 300 pounds. The calculation indicates that 1 cubic foot of air displaces approximately 62.4 pounds of water, leading to the conclusion that around 4.8 cubic feet of air is necessary. Additionally, it is advised to oversize the pontoons by 25% to 50% to ensure adequate stability.
  • Understanding of Archimedes' principle
  • Basic knowledge of buoyancy calculations
  • Familiarity with volume measurements (cubic feet and cubic centimeters)
  • Concept of weight displacement in fluids
  • Research buoyancy calculations for different materials used in pontoons
  • Learn about the design principles for stable boat pontoons
  • Explore the effects of weight distribution on boat stability
  • Investigate the properties of various buoyant materials
Boat builders, marine engineers, hobbyists interested in boat stability, and anyone involved in designing floating structures.
champ2823
Being that I have little experience in physics, but have grown a fascination for it, I am hoping you guys can help with a problem. A friend of mine wants to make a few pontoons to make his boat more stable. It's just a smaller 15' aluminum boat that he uses for hooping (catching lobsters).
He wants to know how much air volume he needs to float about 300 pounds. How much weight a specific volume of air will hold in water. What exactly would the equation be to figure that out? I'm guessing it's so simple that I've overanalyzed it. I'm hoping that I've made myself clear enoug.
1 cc of air will displace about 1 gram of water. That works out to about 62.4 pounds of water displaced by 1 cubic foot of air. The weight of the air is negligible. I think that's all you need.
All you need is Archimedes principle. That is, the upwards thrust on a submerged object is equal to the weight of water that is displaced. So to provide 300 pounds of floatation you need to displace 300pounds of water (I'm not sure how much that is, I use metric). If you use an air filled device to displace that water, then the weight of the air is negligible. But if you use something heavier (say wood for example), then you need to add the weight of the wood to the weight of the boat.
I assume that means the boat will hold 300lb of cargo, so remember to factor in the weight of the boat when doing the calculations. And oversize the pontoons by 25%-50%
Ok thanks guys, I was looking at Archimedes principle and figured it had to do with that.
  • · Replies 19 ·
  • · Replies 39 ·
15K
