What is the formula for calculating minimum takeoff speed of a light aircraft?
  • Thread starter Thread starter Towely
    Airplane Speed
The formula for calculating the minimum takeoff speed (V1) of a light aircraft is given by V1 = square root of ((2Fw)/(pA(((d2/d1)^2)-1))). In this equation, Fw represents the weight force of the aircraft, p is the air density, A is the wingspan area, and d1 and d2 are the lower and upper wing distances, respectively. The ratio d2/d1 must be greater than 1 to ensure a valid calculation, as taking the square root of a negative number is not feasible. Understanding the relationship between these variables is crucial for determining the aircraft's takeoff speed.
  • Understanding of basic aerodynamics principles
  • Familiarity with Bernoulli's equation for ideal fluids
  • Knowledge of aircraft weight and lift dynamics
  • Basic mathematical skills for manipulating equations
  • Research the concept of lift and how it relates to aircraft takeoff
  • Learn about the application of Bernoulli's equation in aviation
  • Study the effects of air density on aircraft performance
  • Explore the relationship between wing design and takeoff speed
Aerospace engineers, flight instructors, aviation students, and anyone involved in aircraft design or performance analysis will benefit from this discussion.
Towely
1. A light aircraft has a mass of 2.0x10^3 kg, a wingspan area of 10.0m^2, an upper wing distance of 1.75m, and a lower wing distance of 1.00m. What minimum takeoff speed must the airplane travel to become airborne?
2. V1= square root of ((2Fw)/(pA(((d2/d1)^2)-1))
3. How am I supposed to find p and Fw? Which length is d1 and which is d2?
Look at the ratio of d2/d1 and its effect on take off velocity V. Should V decrease as d2/d1 increases? If so then d2 is the longer length. Also d2/d1 > 1, because one does not want to be taking the sqrt of a negative number (argument) in this case.
Isn't there some discussion of the variables and the equation from the source (text) where the equation was taken?
No, it isn't taken out of the textbook. I read through multiple chapters a few times and haven't even found that equation in the book. I was gone the day he went through it too and he told me to ask one of my students for help because there's no time for us to meet outside of class. Every student I asked gave the reply "I just got the answeres from x." So I ask x how to do it. "Oh I just stole y's answers."
None of them could help explain it.
edit: Thank you for the answer about d2/d1. I am almost posative you are correct(and now that I look at it I feel silly for having to ask that question :frown: lol...) I gtg eat but I'm going to try and figure it out again, will post the results and how I got them within the hour.
p is sapposed to be density correct? but how am I sapposed to figure out density from the given information if I can only figure out the volume of the wing and not the entire plane and only the mass of the entire plane is given?
And why would density matter in the first place?
Towely, you can use Bernouilli's equation for ideal fluids (even though air, strictly speaking isn't an ideal fluid) and you also have to take into account that the total force which is "pulling" the jet up must be greater than its weight. I hope that cleared things up a bit. :)
Hint: pressure = force/ wingspan area , also remember that you have TWO wings.
12K
12K
