Algebra II Trigonometry Circular Functions
The discussion revolves around finding the exact values of the six trigonometric functions for the angle 11π/6. Participants explore the conversion between radians and degrees and the representation of trigonometric values in fractional form versus decimal form.
  • The original poster attempts to convert radians to degrees and expresses confusion about the expected form of answers. Some participants suggest using known properties of trigonometric functions to find exact values without relying on calculators. Others discuss the use of geometric interpretations, such as drawing triangles, to understand sine and cosine values.
Participants are actively engaging with the problem, with some providing helpful insights and clarifications. There is a recognition of different approaches to finding solutions, including the use of identities and geometric reasoning. However, there is no explicit consensus on a single method or approach.
Some participants mention a lack of familiarity with certain trigonometric identities, indicating a potential gap in knowledge that may affect their ability to apply these concepts across different problems.
velox_xox
Find the exact values of the six trigonometric function of the given number. If a function is undefined for the number, say so.
11\pi/6
The way I did it was to turn it into radians by simply doing the math...
5.76 radians
Then, I multiplied that by 57.3 to get degrees.
330 degrees
After that, I double checked it against -30 degrees so that I could use the table.
I didn't have an issue with getting the correct answers. My issue is with the form.
The answers weren't decimals.
Example:
sin = - 0.5000
cos = 0.8660
tan = - 0.5774
They were left in fraction form.
Example:
sin = - 1/2
cos = \sqrt{3}/2
tan = - \sqrt{3}/3
I have a feeling that my exams want me to answer in the fractional form. And, I don't have an idea of how to do that. Please forgive me if it is obvious.
Also, sorry that my LaTex is rather sloppy. Apparently, the board has changed since I've been away.
Thanks in advance for the help. :D
I can't imagine why you would do all that. The point of this exersize is to use what you know about the trig functions to get exact values, not to just to plug numbers into a calculator to get approximate answers.
Just notice that 11\pi/6= (12pi- \pi)/6= 2\pi- \pi/6 so, because sine and cosine have period 2\pi, sin(11\pi/6)= sin(-\pi/6) and cos(11\pi/6)= cos(-\pi/6). And since sine is an odd function and cosine is an even function those are equal to -sin(\pi/6) and cos(\pi./6).
If you don't know, off hand, what those are, imagine an equilateral triangle with each side of length 2. Each angle has measure \pi/3 and if you draw a perpendicular from one vertex to the opposite side, you have a right triangle with angle \pi/6, hypotenuse of length 2 and "opposite side" of length 1. What is the length of the "near side" and what are sin(\pi/6) and cos(\pi/6)?
@HallsofIvy: Thank you so much for your help. In particular, the equilateral triangle explanation really enabled my understanding. I drew everything out, figured that one of the legs is '1' because the perpendicular line bisects that side, and from the Pythagorean Theorem that the other leg of the triangle is \sqrt{3}. Then, from there, I was able to just pay attention to sine and cosine. Now, I understand that in the example you gave me sine is 1/2 and cosine is \sqrt{3}/2.
The visual of drawing out the triangle really was the key to me understanding and getting the correct answers in the correct form for this particular problem, but I also had a problem -5\pi/6 which I solved the same way as in my earlier post and got the correct answers but in the wrong form. How do I apply what you have taught me to all problems of this nature?
Why don't you make use of the simple identities \cos(2\pi-x)=\cos(2\pi)\cos(x)+\sin(2\pi)\sin(x)=\cos(x) and \sin(2\pi-x)=\sin(2\pi)\cos(x)-\cos(2\pi)\sin(x)=-\sin(x) Also, \cos(-x)=\cos(x) and \sin(-x)=-\sin(x). These are very well known properties.
@Millennial: Hm, I haven't learned that yet or I somehow overlooked it. Today I'm going to try and go back to review in my textbook anyways, so I'll keep my eye out for that.
Could you give me an example using one of the identities or point me in the direction of a website (or thread on on PF) that has examples of it? I normally need to see an identity in action to understand how to apply it correctly.
Thank you for your help.
