Algebra Problem About Quadratic Function
3 replies · 2K views
Joystar77
These 3 equations all describe the same quadratic function. What are the coordinates of the following points on the graph of the function? From which equation is each point most easily determined?
y = (x - 5) (x + 1)
y = x ^ 2 - 4x - 5
y = (x - 2) ^ 2 - 9
X-intercept, what are the points, equation, and explanation why that equation is the one
from which the x-intercepts are most easily determined?
Please tell me someone if this is correct or am I thinking of something else:
The simple way to graph y = (x - 5) (x + 1) is to generate at least four points, put those on graph paper and draw a straight line through them.
Here's how I generate the required points:
Use the equation, y = (x -5) (x + 1) and choose an integer for x, say x = 2, and substitute this into your equation to find the corresponding value of y.
y = (x - 5) (x + 1)
y = (2-5) (2 + 1)
y = (-3) (3)
y = -9
So, my first two points has coordinates of (2, -9). Now am I suppose to repeat this operation with a different value of x, say x = 4.
y = (x - 5) (x + 1)
y = (4 -5) (4 + 1)
y = (-1) (5)
y = -5
So, my second two points has coordinates of (4, -5).
Now mark these two locations on graph paper starting at the origin of my graph (where the x-axis crosses the y-axis), go to the right of 2 squares (x = 2) then down 9 squares
y = -9) and mark your first point.
For the second point, again, start at the origin and go right 4 squares (x = 4) and then down 5 squares (y = -5) and mark your second point.
Using a straight edge, draw a line joining these two points. You have now graphed the equation y = ( x -5) (x + 1).
Compare your graph with the graph of y = (x -5) (x + 1).
Am I starting this out right or am I thinking of something different? Please somebody let me know.
Mathematics news on Phys.org
You are correct that the factored form:
$$y=(x-5)(x+1)$$
is the easiest form for determining the $x$-intercepts. These intercepts occur for $y=0$, and this factored form allows us to use the zero-factor property to quickly determine them by equating each factor to zero and solving for $x$.
As far as graphing the function, you need to observe that it is a quadratic function, and so its graph will be that of a parabola, not a straight line. For graphing, the easiest way is to use the vertex form:
$$y=(x-2)^2-9$$
and observe that this is simply the graph of $y=x^2$ translated two units to the right and nine units down. Its vertex is at $(2,-9)$.
Why is the equation y = (x - 2) ^2 - 9 the one out of all three equations listed below:
y = (x - 5) (x + 1)
y = x^2 - 4x - 5
y = (x - 2) ^2 - 9
the one from which the x-intercepts are most easily determined? Can you explain this?
y = (x - 5) (x + 1)
y = x^2 - 4x - 5
y = (x - 2) ^2 - 9
It is the factored form:
$y=(x-5)(x+1)$
from which the $x$-intercepts are most easily determined, the reason for which I explained in my post above. However, the vertex form:
$$y=(x-2)^2-9$$
is the easiest to use for graphing purposes. :D
