Is an open map also a homeomorphism?
  • Thread starter Thread starter 1MileCrash
The discussion centers on the relationship between open maps and homeomorphisms in topology. It is established that while a homeomorphism is indeed an open map, the reverse implication does not hold without additional conditions, such as bijectivity and continuity. Participants argue that a bijective continuous map is a homeomorphism if and only if it is an open map, and they also explore the conditions under which a closed map can imply a homeomorphism. Examples are provided to illustrate cases where an open map fails to be a homeomorphism. The conversation emphasizes the necessity of specific hypotheses for the implications to be valid.
1MileCrash
I was told to prove that
f: X -> Y is a homeomorphism iff it is an open map
While I see that if f is a homeomorphism, it is certainly an open map, but is the implication in the other direction even true? Because I see no reason to believe it is.
That is false. I suspect they meant a bijective continuous map ##f## is a homeomorphism iff it is open iff it is closed.
I think it should be "A bijective, continuous map ##f:X\to Y## is a homeomorphism iff it is an open map."
For fun, prove "A bijective, continuous map ##f:X\to Y## is a homeomorphism iff it is a closed map." :-p
Edit: WN got there first. Why you type so fast? :smile:
this false without some hypotheses. if X is an open subset of Y, the inclusion map is open but not a homeomorphism.
if f is projection of the plane X onto the y - axis Y, this map is open but not a homeomorphism.
If X and Y are the same set equipped with different topologies so that Y has more open sets than X, then the identity map is open but not a homeomorphism.
etc...
take a look at the open mapping theorem for complex analysis.
Let X be any space and Y a point. Map X to Y.
Oh, ok. But isn't that kind of trivial? If it is an open map then that is exactly the same (from what I can see) as saying that f-inverse is continuous. So basically that means I'm asked to show that f is a homeomorphism if f is continuous, f-inverse is continuous, and f is a bijection, but that's just what a homeomorphism is.
  • · Replies 54 ·
  • · Replies 21 ·
