All possible resonance structures for SO4 2-
9 replies · 17K views · last reply
Faelyn
What are all of the possible Lewis Dot diagrams for SO4 2-?
n/a
So I know about the 6 stable resonance Lewis Dot diagrams for sulfate:
Six Lewis structures of sulfate ion arranged in a cycle, each with S at the centre, two oxygens with double bonds, and two oxygens carrying negative charges, linked by double-headed resonance arrows.
As well as the unstable diagram that only has single bonds between the sulfur and oxygen atoms.But, is it possible for there to be other resonant structures with either 1 or 3 double bonds, even if they're more unstable? I was thinking the one with a single double bond should be possible, but not as much for the three double bonds due to sulfur only having enough valence electrons for six bonds. In both cases the charge is 2- and there are 32 electrons.
Handwritten Lewis structure of SO4 2- with sulfur in the center, one double bond to the top oxygen, and single bonds to three other oxygens; formal charges (0), (+1), (-1) and (-1) are noted, with the whole ion in brackets marked (2-).
(sulfur is double bonded to only 1 of the oxygen atoms, seems totally possible)
Handwritten Lewis structure of SO4 2- with brackets and a 2- charge: sulfur in the centre with one double bond to an oxygen on the left, a double bond to an oxygen on the right, a single bond to an oxygen below, and a fourth oxygen with lone pairs above, with formal charges labelled.
(sulfur is double bonded to 3 of the oxygen atoms, doesn't seem that possible)
Unless it breaks the laws of physics, if you can draw it (following the rules of resonance structures), it in principle exists. However, its contribution to the resonance hybrid could be so negigible that it's meaningless.
So could it even be possible with 4 double bonds, or with one of the oxygen atoms triple bonded?
Maximum Valence of sulfur is 6, so octovalence is probably not possible.
dextercioby said:
Shouldn't you be guided by the octet rule still? How many electrons would be available to the Sulfur atom?
Well sulfur can form 6 bonds maximum due to having access to the D orbital, which is why I'm thinking the scenario with only one double bond should be possible while the one with three double bonds wouldn't be possible.
But then theoretically a scenario with one triple bond and 3 single bonds might also be possible since there's still 6 bonds in total.
You've got an SO43- among your 6 "stable" structures!
The availability of d-orbitals in main group elements for bonding has been disproven more than 50 years ago.
This is a nice modern reading on the subject: https://doi.org/10.3390/chemistry4040082
