Alpha Particle shot at Nucleus Energy
The energy required for an alpha particle to reach the surface of an aluminum nucleus with a radius of 4 femtometers (fm) is calculated using Coulomb's law and conservation of energy principles. The relevant equation is F=(kqQ)/r², where k is Coulomb's constant, q is the charge of the alpha particle, and Q is the charge of the aluminum nucleus. The integral of the Coulombic force from infinity to 4 fm yields an electrostatic energy of approximately -1.5 x 10-12 Joules. The approach of using conservation of energy to relate kinetic energy to electrostatic potential energy is confirmed as the correct method for this calculation.
  • Understanding of Coulomb's law and electrostatic forces
  • Familiarity with classical mechanics and energy conservation principles
  • Knowledge of nuclear physics, specifically alpha particle interactions
  • Ability to perform calculus-based integrals
  • Study the principles of Rutherford's gold foil experiment for context on nuclear interactions
  • Learn about electrostatic potential energy calculations in nuclear physics
  • Explore advanced topics in classical mechanics related to particle collisions
  • Investigate the properties and behavior of alpha particles in various materials
Students and educators in physics, particularly those focusing on nuclear physics, classical mechanics, and electrostatics. This discussion is beneficial for anyone seeking to understand the energy dynamics involved in alpha particle interactions with atomic nuclei.
pearbear21
What energy alpha particle would be needed to just reach the surface of an Al nucleus if its radius is 4fm?
*This problem is found in a section dealing with Rutherford's gold foil scattering experiment, so take it in that context.
F=(kqQ)/r2
I assume the book (Modern Physics by Tipler and Llewellyn ed. 5) wants this performed a classical manner, so I started by considering the energy of the particle as an integral of the coulombic force equation from r=\infty to r=4X10-15m.
so, kqQ\intr-2dr=kqQ[-r-1]
evaluated from \infty to 4X10-15m gives a value of -1.4995992X10-12 Joules. This seems quite unreasonable as the repulsion seems intuitively large at such small distances and a joule is a small unit to begin with.
What do you think of my method and answer? Do you feel there is a different way I should have approached the problem? At first, I tried finding the force to hold the alpha particle just on the surface of the Al nucleus, but after finding that force couldn't find a way to convert to energy correctly.
The energy you are trying to calculate is the final electrostatic energy of the system. When the alpha particle is fired with zero impact parameter, the initial kinetic energy of the alpha particle is entirely converted into electrostatic energy at the point of closest approach. Just use conservation of energy.
Thanks, I think I figured it out upon further inspection of the text. rd, distance of closest approach, may be calculated as follows:
rd = kqQ/.5mv2
13K
