Does the Alternating Series Test show convergence for this series?
The discussion centers on the application of the Alternating Series Test to the series \(\sum\limits_{n=1}^{\infty} (-1)^n\frac{\sqrt n}{2n+3}\). The original poster (OP) correctly identifies \(a_n = \frac{\sqrt n}{2n+3}\) and demonstrates that \(\lim_{n \to \infty} a_n = 0\). However, there is debate regarding the logical flow of proving that \(a_{n+1} \leq a_n\). While some participants argue that the OP's steps are reversible, others point out flaws in the reasoning, particularly concerning the implications of squaring inequalities. Ultimately, the series is confirmed to be convergent by the Alternating Series Test.
  • Understanding of the Alternating Series Test
  • Knowledge of limits and convergence in calculus
  • Familiarity with sequences and their properties
  • Basic skills in manipulating inequalities
  • Study the conditions for the Alternating Series Test in detail
  • Learn about the implications of squaring inequalities in proofs
  • Explore the concept of monotonicity in sequences
  • Investigate other convergence tests such as the Ratio Test and Root Test
Students of calculus, mathematicians analyzing series convergence, and educators teaching series tests will benefit from this discussion.
murshid_islam
To determine whether a series is convergent using the Alternating Series Test
[tex]\sum\limits_{n=1}^{\infty} (-1)^n\frac{\sqrt n}{2n+3}[/tex]
The Alternating series test has to be used to determine whether this series converges or diverges: \sum\limits_{n=1}^{\infty} (-1)^n\frac{\sqrt n}{2n+3}
Here's what I have done:
Let a_n = \frac{\sqrt n}{2n+3}. Therefore, a_{n+1} = \frac{\sqrt {n+1}}{2n+5}
Now, for a_{n+1} to be less than or equal to a_n \\,
\frac{\sqrt {n+1}}{2n+5} \leq \frac{\sqrt n}{2n+3} \\
\Rightarrow \sqrt {\frac{n+1}{n}} \leq \frac{2n+5}{2n+3} < \frac{4n+6}{2n+3} \\
\Rightarrow \sqrt {\frac{n+1}{n}} < 2 \\
\Rightarrow \frac{n+1}{n} < 4 \\
\Rightarrow 3n > 1 \\
\Rightarrow n > \frac{1}{3}
Therefore, a_{n+1} \leq a_n for all n \geq 1
And \lim_{n \to \infty} a_n = \lim_{n \to \infty} \frac{\sqrt n}{2n+3} = \lim_{n \to \infty} \frac{1}{2 \sqrt n+ \frac{3}{\sqrt n}} = 0
Therefore, by Alternating Series Test, the series is convergent.
Is this ok?
I know it as Leibniz criterion, but anyway. You have to write it backwards: from ##n> \frac{1}{3}## to ##a_{n+1}<a_n##, since that it is what you want to show. You have shown an implication of an already convergent series, the wrong logical direction.
Likes member 587159
fresh_42 said:
You have shown an implication of an already convergent series, the wrong logical direction.--
I disagree. To show that an alternating series converges, all you need to do is to verify the two conditions:
  1. ##\lim_{n \to \infty} a_n = 0##
  2. The terms are decreasing; i.e., ##a_{n + 1} \le a_n##
In the OP's work on determining the latter condition, I believe that all the steps are reversible.
Another way to check that the terms are decreasing is to look at the limit of ##\frac{a_{n+1}}{a_n}. if this limit is less than 1, the sequence is decreasing.
The OP has done both of these, and has concluded that the series converges. I agree with his conclusion.
Fresh merely pointed out that the implication is in the wrong order and he is correct. You are also correct that all steps are reversible, but logically the solution contains a flaw and if I would grade it I would subtract a small point.
What I had shown was that for a_{n+1} \leq a_n, n has to be greater than \frac{1}{3}. Since n \geq 1, the reverse implication works and therefore a_{n+1} \leq a_n. I can of course write all of that backward so that a_{n+1} \leq a_n follows from n &gt; \frac{1}{3}.
Yes, but they are written in the wrong direction. There is a squaring on the way which is not reversible, at least not always. So additional and unmentioned informations come into play. Such steps are notorious flaws in more complex situations. Better to learn it at those easy examples.
Yep, I see it.
Likes member 587159
Or I can assume the opposite, that is, a_{n+1} &gt; a_n, and show a contradiction.
Hang on, I have checked the function f(x) = \frac{\sqrt x}{2x + 3} and its derivative. There's a maximum at x = 3/2. The function increases up to x = 3/2 and then it decreases.
Does the Alternating Series Test apply here if the sequence \left\{ \frac{\sqrt n}{2n+3} \right\} isn't monotonically decreasing for all n?
Yes. The behavior has to be for "large" n. What happens for a few terms for small values of n doesn't matter.
Likes murshid_islam
So if he used double arrows all would be copacetic?... So if the infererence is IFF always write the double arrow!
No. As mentioned, squaring isn't reversible.
If you show ##A=B \Longrightarrow 1=1##, then you cannot just write it as ##A=B \Longleftrightarrow 1=1##. The logic says: True can follow from False, but False cannot follow from True. Hence you have to write ##1=1 \Longrightarrow A=B## if that is what you want to show.
This means in practice, that you scribble ##A=B \Longrightarrow 1=1##, hope that it can be reversed, and if so, finally write down ##1=1 \Longrightarrow A=B##. It is a matter of hygiene.
Yes I somehow missed the discussion. But the sum stipulates n is positive...in a formal proof does that not allow the twin arrow at that step? Or do you notate it differently?
In the example we only consider that part of the root function which is above the ##x##-axis, so it is equivalent here. This should be mentioned in a proof at this level. Especially in calculus we often have the situation in which things have to be written backwards: For ##\varepsilon## there is an ##N## ... Nobody knows this ##N## from the start, but you have to start with it and end up with ##<\varepsilon##. And those deductions are often not reversible!
For squaring we only have ##a< b \Longrightarrow a^2<b^2 \Longrightarrow |a|<|b|##. So if ##a,b## aren't numbers but some complicated expressions, then it is not obvious that ##a=|a|## and ##b=|b|##. The OP has asked 'Is this ok?' and the answer is 'Almost.'
Maybe I'm a bit spoiled since I saw ##A<B \Longrightarrow AC<BC## in a thesis where the author didn't care about ##C>0##, which wasn't obvious at all, since ##C ## was an expression which could have been negative without assuming further properties. Another one claimed a group ##G\cong SL(2)## where it actually was ##G\cong PSL(2)##. No big deal, because ##G## was a tensor group and of course we have ##x \otimes y = \gamma x \otimes (1/\gamma) y## only up to the center.
Since then I find that it is important to practice such subtleties in time. Not, that I wouldn't make such mistakes myself, too, from time to time.
Likes hutchphd
I think it would be better if I consider the function f(x) = \frac{\sqrt x}{2x + 3} and show that f&#039;(x)&lt;0 (and therefore, f(x) is decreasing) on the interval \left( \frac{3}{2}, \infty \right). And so, \left\{\frac{\sqrt n}{2n + 3}\right\} is a decreasing sequence.
Likes member 587159
