Alternative spacelaunch methods
  • Thread starter Thread starter ShotmanMaslo
The discussion revolves around alternative methods for space launch, focusing on concepts such as launch loops, mass drivers, and beam-powered propulsion. Participants explore the feasibility, cost-effectiveness, and technological requirements of these methods compared to traditional chemical rockets, particularly in the context of human space exploration and colonization.
  • Some participants propose the launch loop as a cost-effective alternative to chemical rockets, suggesting it could reduce launch costs to as low as $3/kg.
  • Others discuss the mass driver concept, which could accelerate payloads to high speeds before releasing them for rocket-assisted launch, potentially lowering the fuel requirements for reaching orbit.
  • Beam-powered propulsion is mentioned as a promising method, where lasers provide thrust by heating air or propellant, potentially leading to lower launch costs.
  • Concerns are raised about the estimated costs of constructing a launch loop, with comparisons made to existing infrastructure projects, suggesting skepticism about the feasibility of such large-scale investments.
  • Participants express differing views on the practicality and economic viability of these alternative launch methods compared to traditional approaches.
There is no consensus among participants; multiple competing views remain regarding the feasibility and cost-effectiveness of the proposed alternative launch methods.
Participants highlight limitations in the cost estimates and feasibility of the launch loop and other methods, with some questioning the assumptions behind the proposed costs and the scale of the projects.
ShotmanMaslo
Space is the final frontier. The biggest obstacle to human space exploration and colonisation of the solar system are not the distances involved, but rather our hard-to-escape imprisonment - Earth gravity well. Conventional way using only chemical rockets has surely achieved a lot in the past, but it still doesn't allow practical space colonisation. Present-day launch costs are very high — $10,000 to $25,000 per kilogram from Earth to low Earth orbit (LEO). Thats after 100 years of chemical rocket development - clearly we need far more cost-effective ways if we ever want to settle space. So, what are the best options?
http://en.wikipedia.org/wiki/Non-rocket_spacelaunch"
http://en.wikipedia.org/wiki/Launch_loop"
A launch loop or Lofstrom loop is a design for a belt-based maglev orbital launch system that would be around 2000 km long and maintained at an altitude of up to 80 km (50 mi). Vehicles weighing 5 metric tons would be electromagnetically accelerated on top of the cable which forms an acceleration track, from which they would be projected into Earth orbit or even beyond.
The published cost estimates for a working launch loop are significantly lower than a space elevator, with a greater launch capacity, lower payload costs and similar or greater payload masses; and unlike the space elevator no new materials need to be developed. The structure would constantly need around 200 MW of power to keep it in place.
The system is designed to be suitable for launching humans for space tourism, space exploration and space colonization with a maximum of 3g acceleration.
Lofstrom estimates that an initial loop costing roughly $10 billion with a 1 year payback could launch 40,000 metric tons per year, and cut launch costs to $300/kg, or for $30 billion, with a larger power generation capacity, the loop would be capable of launching 6 million metric tons per year, and given a 5 year payback period, the costs for accessing space with a launch loop could be as low as $3/kg.[2]
http://en.wikipedia.org/wiki/Mass_driver"
In contrast to a space gun, a mass driver can have a length of hundreds of kilometers and therefore achieve acceleration without excessive g forces to the passengers. It can be constructed as a very long and mainly horizontally aligned launch track for spacelaunch, targeted upwards at the end, partly by bending of the track upwards and partly by Earth's curvature in the other direction.
Natural elevations, such as mountains, may facilitate the construction of the distant, upwardly targeted part. The higher up the track terminates, the less resistance from the atmosphere the launched object will receive.[2]
By being mainly located slightly above, on or beneath the ground, a mass driver may be easier to maintain compared with many other structures of non-rocket spacelaunch. If not underground then it still needs to be housed in a pipe that is constantly vacuum pumped in order to reduce drag.
In order to be able to launch humans and delicate instruments, it would need to be several hundreds of kilometres long. For rugged objects, with magnetic assistance, a significantly smaller, circular, track may suffice.[3]
A mass driver on Earth would be a compromise system. A mass driver would accelerate a payload up to some high speed which is not high enough for orbit. It would then release the payload, which completes the launch with rockets. This would drastically reduce the amount of velocity needed to be provided by rockets to reach orbit, since most fuel is needed for the initial phase of conventional rocket launch. On Earth, a mass driver design could possibly use well-tested maglev components.
http://en.wikipedia.org/wiki/Beam-powered_propulsion#Lightcraft"
Another promising method could be beam-powered propulsion, when powerful laser is aimed at the craft which can concentrate this energy to combust a propellant or even the air, producing thrust.
A lightcraft is a vehicle currently under development that uses an external pulsed source of laser or maser energy to provide power for producing thrust (beam-powered propulsion).
The laser shines on a parabolic reflector on the underside of the vehicle that concentrates the light to produce a region of extremely high temperature. The air in this region is heated and expands violently, producing thrust with each pulse of laser light. In space, a lightcraft would need to provide this gas itself from onboard tanks or from an ablative solid. By leaving the vehicle's power source on the ground and by using ambient atmosphere as reaction mass for much of its ascent, a lightcraft would be capable of delivering a very large percentage of its launch mass to orbit. It could also potentially be very cheap to manufacture.
Testing
Early in the morning of 2 October 2000 at the High Energy Laser Systems Test Facility (HELSTF), Lightcraft Technologies, Inc. (LTI) with the help of Franklin B. Mead of the U.S. Air Force Research Laboratory and Leik Myrabo set a new world's altitude record of 233 feet (71 m) for its 4.8 inch (12.2 cm) diameter, 1.8 ounce, laser-boosted rocket in a flight lasting 12.7 seconds. Although much of the 8:35 am flight was spent hovering at 230+ feet, the Lightcraft earned a world record for the longest ever laser-powered free flight and the greatest "air time" (i.e., launch-to-landing/recovery) from a light-propelled object. This is comparable to Robert Goddard's first test flight of his rocket design. Increasing the laser power to 100 kilowatts will enable flights up to a 30-kilometer altitude. Their goal is to accelerate a one-kilogram microsatellite into low Earth orbit using a custom-built, one megawatt ground-based laser. Such a system would use just about 20 dollars' worth of electricity, placing launch costs per kilogram to many times less than current launch costs (which are measured in thousands of dollars).
Myrabo's "lightcraft" design is a reflective funnel-shaped craft that channels heat from the laser, towards the center, using a reflective parabolic surface causing the laser to literally explode the air underneath it, generating lift. Reflective surfaces in the craft focus the beam into a ring, where it heats air to a temperature nearly five times hotter than the surface of the sun, causing the air to expand explosively for thrust.
I have not included presently unrealistic methods which require some technology breakthrough, like antigravity or high tensile strenght materials. Even without them, we are still able to make Earth to LEO trip more practical and cost-effective.
The estimated cost of the Launch Loop concept does not exceed 30 billion dollars, electromagnetic catapults would be far less costly, but offer higher launch costs (still far less than current method). Compare that to estimated Iraq War cost - $100 to $200 billion.
We could already have 5 Launch Loops or many more EM catapults running, driving the launch costs to few dollars per kilogram or even less. Shouldnt we concentrate on this rather than "Big dumb booster" approach aka Constellation? I does not have the promise for vastly reducing launch costs..
Um.............no.
"Lofstrom estimates that an initial loop costing roughly $10 billion " for a 2000km long maglev track suspended 80km in the air!
The jubilee line subway extention in London cost almost as much as that and is only 16km long.
I would hope the subway isn't 80 km in the air as well.
Thats hell of a expensive subway btw... Maybe digging through hard soil instead of air could be the cause.
Anyway, here is the original Launch Loop paper with more exact figures, preliminary designs and much more: http://launchloop.com/LaunchLoop?action=AttachFile&do=view&target=launchloop.pdf
The space elevator sounds downright practical compared to some of this stuff.
"Space Fountain" is also something that we could do with current technology. It's kind of like a space elevator, except it doesn't go nearly as high.
Imagine a looooooong vacuum tube going very high up into the air. As high as you want, let's say 80km. At the very top, the tube bends around and comes back down, forming a closed loop.
Then you send a bunch of projectiles through this tube at high speed. As the projectiles curve around the crest of the loop, their inertia supports the entire structure.
It would work, it can be made safe and maintainable, and it's very doable with current technology. The only problem is that it's an "active" structure. It constantly needs masses flying around inside of it to keep it standing.
http://en.wikipedia.org/wiki/Space_fountain
I think launch loop design is better because it gives you not only velocity, but also correct velocity vector for orbital insertion (compared to Hyde design).
I was thinking the same thing
on the space fountain how do you launch something?
dr
The space fountain is a structure that goes high up in the air...almost to space. Once you have a structure that extends to the edge of space, the biggest problem in launching has already been overcome.
But I don't know. I guess you climb it. Maybe you climb using magnets at high speed and then fly off into space. Maybe you climb slowly and then fire a rocket at the top. Maybe both. Many different ways...
why exactly are you guys dismissing Lightcraft?
Myrabo got some partners already... Brazil is doing hypersonic tunnel tests for lightcraft while Myrabo works with the US airforce.
Also, people forgot to mention SKYLON here.
  • · Replies 89 ·
  • · Replies 183 ·
20K
  • · Replies 271 ·
31K
  • · Replies 24 ·
  • · Replies 30 ·
11K
