Altitude of Geostationary Orbit
The discussion focuses on calculating the altitude of a geostationary orbit using the formula T = 2πR / v, where T represents the revolution period, R is the distance from the center of the Earth, and v is the orbital velocity. Participants emphasize the importance of Newton's law of gravitation and the relationship between gravitational force and centripetal force in determining R. The conversation highlights the need to express velocity in terms of period and radius, ultimately leading to a clearer understanding of geostationary orbits.
  • Newton's Law of Gravitation
  • Circular Motion Dynamics
  • Understanding of Geostationary Orbits
  • Basic Algebra for Rearranging Equations
  • Study the derivation of the gravitational force and centripetal force equations
  • Learn how to calculate orbital velocity using T and R
  • Explore the concept of geostationary satellites and their applications
  • Investigate the implications of altitude on satellite communication
Students studying physics, aerospace engineers, and anyone interested in satellite dynamics and orbital mechanics.
duchuy
Deduce at what distance from the center of the Earth are positioned the geostationary satellites which, observed from the terrestrial frame of reference, are motionless in the sky.
T = 2piR / v
Hi,
They gave me this formula T = 2piR / v, with T the revolution period of the satellite, R the distance between the center of masses and v the velocity.
They gave me the value of G and the eath's mass and asked to determine the value of R.
I don't even see fromwhere I should start...
Thank you for your help!
Have you studied what Mr. Newton said about gravitation?
Probably I have, but I'm not quite sure how I would use those formulas for an object in geostationary orbit... and I'm taking physics as a minor so I don't really remember much
O.K. Can you make a search about Newton's gravitation law and circular movement?
And, do you know what a 'geostationary' orbit is.
If a satellite appears to be stationary above the earth, what must its period T be? Can you also write an expression for v in terms of T and R? Then you'd be left with an expression with R as the only unknown.
BUT
Usually to tackle a Q like this, rather than using that equation you've quoted, I'd start from the fact that the gravitational force on the satellite is what provides the centripetal force. So if you can write an expression for each of these (I usually prefer the mrω² version for centripetal force), and equate them, you can do it from there - though you still need to know T of course.
In the end, it will get you to the same place, but doing it this way helps you to understand and therefore remember how this works.
