Ammeter and voltmeter resistance
6 replies · 12K views
tommoturbo
A little help with this one please
The power in a 10ohm resister when connected to a 100v supply is measured by an ammeter and voltmeter. There are two possible ways of connecting the instruments (as seen in the attachment)
The values of Ra and Rv represent the resistance of the ammeter and volmeter respectfully.
When connected as in Fig a The voltmeter reads 100v and ammeter reads 9.901A
When connected as in Fig b The voltmeter reads 99.01v and ammeter reads 9.911A
Calculate the values of Ra and Rb
Not sure where to start with this one but what i have so far is
i know that the ammeter resistanse will be tiny and the voltmeter should be really large
i calculated the voltage drop across the 10 ohm resistor
Vd=IxR
99.01V=9.901x10
i get Ra to be .99ohms
and Rb to be 1000.1ohms
can really put my working out down its long winded and a bit of guess work, working back to give figures,
there is another part to the question about calculating percentage error but i can do that fine as i didnt need to know Ra or Rv
if anyone can shed some light on a preferred method of calculating them please let me know
many thanks ian
I stared at your circuit for a good few seconds, trying to figure out how the heck you were going to analyze it, and how you could possibly get the numbers that you were getting. Then I realized what was wrong with it: you should remember that a real voltmeter has an ideal voltmeter (with infinite resistance) in parallel with its internal resistance, not in series as your pictures indicate.
A real ammeter has an ideal ammeter (with zero resistance) in series with its internal resistance, as you show in your diagrams.
I'll get you started. In figure A, there should be four parallel branches:
1) the battery
2) the branch including the ammeter
3) the voltmeter's internal resistance
4) the ideal voltmeter with infinite resistance (i.e. no current flows through it--you can show this by connecting it to the rest of the circuit using dashed lines, such that it's connected, but not really connected)
The remainder of the question is left as an exercise to the reader!
Thanks that makes a bit more sense
what i have now is Ra to = 0.099ohms
as I = Vx R
9.901=100 x R
R= 100/9.901 10.0999 OHMS We know 1 resistor is 10 ohms therefore Ra = .099ohms
Now fig b I am assuming you need to use both figures to determine Ra and Rv
im still not sure about how to calc the value of rv
ive had a go and got a current of 0.01A flowing towards V of 99.01V giving a resistance of Rv=10k??
does that sound right?
as I = Vx R
9.901=100 x R
You've got Ra, mostly (I rounded to 0.100 ohm, but that might just be me, after getting 0.099901 ohms). However, start by redraw that circuit in B properly (with Rv in parallel with an ideal voltmeter). You'll find out that you know what the voltage across Rv is. And remember where the current flowing through the ammeter flows through (you do not need to use the value of Ra in circuit B)
I have calculated Rv to be 9901 Ohms
the voltage drop across Rv and Rl add up to the measured voltage of 99.01v
I3 which i worked out as the current flowing to the voltmeter (in practice it is about zero) is 0.01 amps which appliing ohms law
Rv =V/i 99.01/0.01 = 9901 ohms
i think!
as I = Vx R
9.901=100 x R
You've got Ra, mostly (I rounded to 0.100 ohm, but that might just be me, after getting 0.099901 ohms). However, start by redraw that circuit in B properly (with Rv in parallel with an ideal voltmeter). You'll find out that you know what the voltage across Rv is. And remember where the current flowing through the ammeter flows through (you do not need to use the value of Ra in circuit B). And remember what the formula for a parallel resistor is!
i think!
That's the value I get. However, I used a different method (also more complicated, since I took another three lines to unwrap parallel resistance). Good on you for recognizing the shortcut!
