Ampere's law -- application with two conducting loops
1 reply · 3K views · last reply
Physicslearner500039
Figure 29-67 shows two closed paths wrapped around two conducting loops carrying currents
i j = 5.0 A and i2 = 3.0 A. What is the value of the integral ~ B· d'S for (a) path 1 and (b) path2?
No specific equations
I am trying to get more confidence on the direction of current using Amperes law, the problem statement is
Loop1:
My first task was to assign the direction of current. If I wrap around the my right hand fingers in the direction of integration the thumb is pointing up hence Positive Y direction current is +Ve and Negative Y direction current is -Ve. Hence i1 is -ve and i2 is +Ve.
∫B.ds = (-5+3)*μ = -2*4*π*10^-7 = -2.5u T.m.
Is everything ok?
Loop2:
The real confusion happens here while assigning the current direction I have shown the integration points
Right hand rules for integration points
A: Up current is positive.
B: Up current is negative.
C: Up current is positive.
So which direction should i consider positive?
For side 1 the current is one direction and for side 2 it is opposite direction. Do they always cancel? Please advise.
I suggest that you draw a picture of the system as seen from above, including the currents going in/out of the paper and the loop with directional arrows.
