Amplitude of a wave hitting a boat
42 replies · 6K views
No.
The climb is changing, but stays in the range between 2.1m and 4.5m. What would be the average?
Okay, good. With no wave present, the height difference (or the climb, as they put it) will be 3.3 m.
Now let's add the waves. The boats are 1/2 wavelength apart, so when the taller boat height is higher by A (the amplitude), the shorter boat is lower by A.
So take that 3.3m climb, and:
1. raise the tall boat by a distance A
2. lower the shorter boat by a distance A
What will the climb be then (in terms of A and the 3.3m)?
tall boat will be 8.7 m
shorter boat will be 1.2 m
so the climb will be 7.5 m?
does the solution involve the quadratic equation by any chance?
No.
Refering back to my post #33, let's try to imagine/picture this another way.
Suppose there is a vertical spring or elastic cord stretched out, from the deck of the shorter boat up to the deck of the taller boat. Normally, the spring is 3.3 m long (the distance between the 2 decks, with no waves present).
Now, take the top end of that spring and move it by a distance A upward. At the same time, move the bottom end of the spring downward by the same distance A.
By how much has the spring's length been increased?
Yes, good. The spring's length has increased by 2A, from 3.3m to 3.3m+2A.
If you equate that last expression with the maximum climb given in the problem statement, you can find the amplitude A.
3.3 m + 2A = 4.5 m
A= 0.6 m
Thank you for all your help!
