Why are both positive and negative amplitudes counted as maxima in a sine curve?
  • Thread starter Thread starter ZaZu
    Waves
The discussion clarifies why both positive and negative amplitudes are counted as maxima in a sine curve. Participants agree that amplitude represents the magnitude of displacement from the equilibrium position, regardless of direction. The key takeaway is that while maxima and minima correspond to physical positions, both contribute to the overall amplitude, which is defined as the absolute value of displacement. The wavelength is calculated based on the number of maxima or minima observed, confirming that both types of peaks are relevant in this context.
  • Understanding of sine functions and their properties
  • Knowledge of wave mechanics and standing waves
  • Familiarity with the concept of amplitude in oscillatory motion
  • Basic mathematical skills for calculating wavelength
  • Study the properties of sine and cosine functions in detail
  • Learn about wave interference and standing wave patterns
  • Explore the mathematical derivation of wavelength in oscillatory systems
  • Investigate the physical implications of amplitude in various waveforms
Students of physics, particularly those studying wave mechanics, as well as educators seeking to clarify concepts related to amplitude and wavelength in oscillatory motion.
ZaZu
Hello there,
There is a question that says :
...etc...the metal is then moved towards the hardboard. In moving 6.4cm, four further maxima are observed. Calculate the wavelength of the ...etc...
Now I know how to solve it, and got the answer.
(sine curve)
But why do we count the amplitudes both below in the and above the axis as maxima ?
I thought the maximum points are all the points above the x axis, and the minimum points are the minimum points ??!
All I did was : 4 max = 2\lambda .. But these 4 maximum points are both ABOVE and BELOW the x-axis for a sine curve.
Then 2\lambda=6.4cm
\lambda=3.2cmIf you need me to explain my question exactly, please ask me to clarify.
Hi ZaZu,
I'm not 100% of what you're asking so if I'm telling you something you already know - forgive me.
I presume the experiment involves counting how many maxima OR minima of a standing wave propagating between two fixed points, the distance between which you know already.
In this case you're really only after counting either the number of consecutive maxima or minima, not both, for this is the definition of wavelength.
astrorob said:
Hi ZaZu,
Yes that's exactly what I mean, but in our class we did the following :
http://img404.imageshack.us/img404/2170/image352.th.jpg Is this correct ?
The amplitude is the magnitude of the displacement from the equilibrium position of the oscillating variable. It doesn't matter whether this displacement is positive or negative since the amplitude is the magnitude of the displacement.
For example, consider the function y = sin(x). A maximum value of y occurs as sin(pi/2) = 1 and a minimum value of y occurs at sin(-pi/2) = -1. However, in both cases the amplitude is 1, since A = |y|. Since the amplitude, by definition is non-negative, it's minimum value is clearly the minimum of y > 0.
Do you follow?
Yes it is.
Note the 2 on the RHS corresponding to 2 consecutive peaks/troughs of maxima OR minima.
Do you follow?
So in my question, I can say that both the minimum AND maximum points are the MAXIMA ??
astrorob said:
Yes it is.
Oh alright, so its concluded that both the crests and troughs can be considered the maximum points ?
Careful here. They correspond to points of maximum amplitude but in regards to their physical positions, they must be differentiated (i.e. by the use of maxima/minima).
Oh I see, great !
Its clearer now :)
Thanks a lot astrorob and Hootenanny :D :D :D
11K
  • · Replies 0 ·
  • · Replies 17 ·
13K
