An elementary equation manipulation in CFT
The discussion focuses on an elementary equation manipulation in 2-dimensional conformal field theory (CFT), specifically addressing the relationship between the left-hand side (LHS) and right-hand side (RHS) of an equation involving the metric and the Kronecker symbol. Participants clarify that setting indices μ and ν to 0 and 1 leads to confusion regarding the equality of LHS and RHS. The correct interpretation involves recognizing that ∂⋅ε represents a sum of components, leading to the conclusion that 2∂0ε0 equals ∂0ε0 plus ∂1ε1 for the 00 component.
  • Understanding of 2-dimensional conformal field theory (CFT)
  • Familiarity with the Kronecker delta and its application in tensor calculations
  • Knowledge of partial derivatives and their notation in mathematical physics
  • Basic grasp of metric tensors in Euclidean space
  • Study the properties of the Kronecker delta in tensor analysis
  • Learn about the implications of metric tensors in conformal field theories
  • Explore the concept of inner products in the context of vector fields
  • Investigate the role of partial derivatives in higher-dimensional field theories
This discussion is beneficial for theoretical physicists, particularly those specializing in conformal field theory, as well as students and researchers looking to deepen their understanding of tensor manipulations and metric properties in physics.
Lapidus
A presumably basic introductory equation manipulation in 2-d conformal field theory. How does from
(when the metric is Euclidean) follow
The right equation is clear (the metric is zero for different indices). But how do i get to the first equation on the left?
thank you
set μ = ν = 0 and calculate, then μ = ν = 1 and compare the results
Thanks for the reply! But I don't understand what you mean. If I set zero or one, then RHS and LHS do not add up, in either case.
0ε0 + ∂0ε0 = ∂0ε0
I do not know for sure how ##η## is defined. Since you did not explain it and I'm too lazy to search what you might have meant, I supposed ##η## to be the Kronecker symbol according to your calculation above.
If I then first compute ##δ_0 ε_0 = ...## and next ##δ_1 ε_1 = ...## then I get the same result, i.e. they are equal.
0ε0 + ∂0ε0 = ∂0ε0
Since presumably ##\partial\cdot \epsilon = \partial_0 \epsilon_0+\partial_1 \epsilon_1## in your conventions, you should have found ##2\partial_0 \epsilon_0 = \partial_0 \epsilon_0+\partial_1 \epsilon_1## for the 00 component.
Ahaa. I did not understand that ∂⋅ε is a sum. (or an inner product)
Thanks everybody!
  • · Replies 22 ·
  • · Replies 0 ·
