An elevator moving up and a bolt falling down
2 replies · 7K views
chaotixmonjuish
A bolt comes loose from the bottom of an elevator that is moving upward at a speed of 6.38 m/s. The bolt reaches the bottom of the elevator shaft in 3.85 s. How high up was the elevator when the bolt came loose?
I integrated 6.38 to get the position equation and plugged in 3.85. However, I'm not really sue that's right at all. Could someone show me what type of equation I should be using?
Should I get the height of the elevator at 3.85 seconds. Then use 9.8m/s and create a position equation for the falling bolt.
firstly you have posted this in the wrong forum
here are some hints which maybe able to help you
[tex]s = ut + \frac{1}{2}at^2[/tex]
the velocity of the elevator is acting in the opposite direction to gravity, therefore it is a negative velocity in respect to gravity so gravity will be 9.8m/s/s and the elevator velocity will be -6.8m/s
you have the value of t so use the equation above, where s is the displacement, i.e., how high up the elevator was in the shaft
