brotherbobby
- 809
- 178
- Homework Statement
- Consider a cannon shell of mass ##M## moves along a parabolic trajectory in the earths gravitational field. An internal explosion, generating an amount ##E## of mechanical energy, blows the shell into two parts. One part of mass ##kM## where ##k<1##, continues moving along the same trajectory with velocity ##v'## while the other part is reduced to rest. Find the velocity of the mass ##kM## immediately after the explosion.
- Relevant Equations
- 1. According to (linear) momentum conservation, if masses ##m_1## and ##m_2## moving with velocities ##v_{1i}## and ##v_{2i}## collide and have velocities ##v_{1f}## and ##v_{2f}## after the collision, then, in the absence of any external forces, ##\underline{m_1v_{1i}+m_2v_{2i}=m_1v_{1f}+m_2v_{2f}}##
2. According to energy conservation, if masses ##m_1## and ##m_2## moving with velocities ##v_{1i}## and ##v_{2i}## collide and have velocities ##v_{1f}## and ##v_{2f}## after the collision, then ##\underline{\dfrac{1}{2}m_1v^2_{1i}+\dfrac{1}{2}m_2v^2_{2i}\pm W'=\dfrac{1}{2}m_1v^2_{1f}+\dfrac{1}{2}m_2v^2_{2f}}##, where ##W'## is the work done on (or by) the system during the collision.
Problem :
I start by putting the image of the problem to the right.
A cannon of mass ##M## moving with a velocity (say) ##v##, splits into two parts of masses ##kM## and ##(1-k)M## following an explosion that generated an amount of energy ##E##. The second piece falls straight to the ground while the first piece of mass ##kM## continues in the same direction with a velocity ##v'##. What is the velocity ##{\color{red}{v' =?}}##
Using momentum conservation, we have ##Mv=kMv'\Rightarrow v=kv'\qquad (1).##
Using energy conservation, ##\dfrac{1}{2}Mv^2+E=\dfrac{1}{2}kMv'^2##, to which, upon using ##(1)## to replace ##v\rightarrow v'##, we get ##\dfrac{1}{2}kMv'^2-\dfrac{1}{2}k^2 Mv'^2=E\Rightarrow \boxed{v'=\sqrt{\dfrac{2E}{k(1-k)M}}}\quad\color{DarkGreen}{\Huge\checkmark}##
The answer is correct and matches with that of the text.
Doubt :
Let's have the answer again : ##\boxed{v'=\sqrt{\dfrac{2E}{k(1-k)M}}}##, as the velocity of the piece of mass ##kM##. Clearly, the value of ##k## has to be between 0 and 1.
(1) What happens (intuitively) when ##k\approx 0##?
When ##k## goes to 0, the first piece has neglible mass while (almost) the whole of the mass of the cannon is taken by the second piece which has no kinetic energy. Hence the first piece must take (almost) the entire kinetic energy of the original cannon. Having negligle mass, it means that its velocity ##v'\rightarrow \infty##.
Thus, we can say that ##\displaystyle{\lim_{k\to 0}\; v'\rightarrow \infty}\qquad (2)##
I plotted the solution for ##v'## in ##\verb|Desmos|## as given above, ##v'=\sqrt{\dfrac{2E}{k(1-k)M}}##, taking ##E=\dfrac{1}{2}## and ##M=1##. I copy and paste the image of the plot to the right. From the plot, as ##k\rightarrow 0##, the velocity ##v\rightarrow\infty##.
(2) What happens (intuitively) when ##k\approx 1##?
This is where I run into trouble.
Intuitively, as ##k\rightarrow 1##, the first piece has almost the entire mass of the cannon while the second piece has a negligible amount and falls down under gravity. Hence the first piece should be moving with a velocity ##v'=v+2\dfrac{E}{m}## using equation ##(1)## above, whatever the value of ##v## was. Putting the values of ##E,m##, we get ##2E/m=1##
We can capture this as above : ##\displaystyle{\lim_{k\to 1}\; v'\rightarrow v+1}\qquad (2)##
But the graph from the plot shows that ##v'## goes to ##\infty## as k goes to 1.
What is going on?
Request : The plot of the function is correct I suppose. I'd like a hint or clue as to where am I going wrong in my reasoning above for the case where ##k \approx 1##.
