Can Interference Patterns be Observed with Sound Waves?
  • Thread starter Thread starter arkofnoah
    Interference
The discussion focuses on whether interference patterns can be observed with sound waves, specifically in a scenario resembling the double-slit experiment. Participants clarify that the standard interference equation does not apply due to the absence of two slits; instead, they analyze the path differences of sound waves reaching a point M from a source S and its reflection. The importance of considering phase changes during reflection is emphasized, with a 180° phase change noted as relevant to the overall path difference. The conversation also touches on the implications of using different materials for the reflecting surface. Ultimately, the group converges on the conclusion that the correct answer involves understanding these path and phase differences.
arkofnoah
http://img337.imageshack.us/img337/285/64902163.png
\Delta x = \frac{\lambda L}{d}
where delta x is the fringe separation
L is the distance from screen to signal source
d is the slit separation
Okay you see I'm using the equation from the double-slit experiment (should I?) But I cannot draw an analogy between double-slit experiment and the situation here. Am I on the right track?
No, you don't want to use that equation. You don't have interference due to waves emanating from two slits in this problem, so that formula doesn't apply.
You get maxima and minima because of waves interfering, and to get interference, you have to have two waves reaching M. So the first step is determining what the two path waves follow to go from S to M.
Okay, I suppose that there's a wave going from S to M directly and the wave reflected from the screen.
Actually I've been thinking along the line about treating the reflected wave as one emanating from a fictitious source situated behind the screen, symmetrical to S. Then the minima would be akin to having a dark fringe on M. That should work as well?
Yeah, that should work, I think.
Okay I need more help because I still cannot get the answer. (The supposedly correct answer is A by the way.)
One wave has to travel 12 cm to go from S to M. The other one travels a bit more because it reflects from the wall. Calculate the difference in path length for the two waves. If they differ by a half wavelength, you'll get destructive interference.
okay cool i got it thanks :D
Is no phase change at the wall?
ehild
during reflection the phase changes by 180°, but that should be quite irrelevant to solving this question since we're only interested in the overall path difference.
No, we are interested in the overall phase difference.
ehild
Good point. I totally forgot about the phase change at the screen.
I just wondered what happens if the screen is made from some elastic material?
ehild
Did you guys get the answer A?
Yes, if there is a pi phase change at the screen.
But that speaker should be a bat...
ehild
  • · Replies 23 ·
