An upper bound for a conditional probability
The discussion revolves around the validity of the inequality P(A│B∪C)≤P(A│B)+P(A│C)-P(A|BC) and whether a tighter upper bound can be established. Participants explore the relationship between conditional probabilities and suggest using Venn diagrams to visualize the problem. They discuss the implications of disjoint sets on the inequality and the need for clarity in defining what constitutes a "better" upper bound. The conversation emphasizes the importance of precise notation and definitions in probability theory, particularly in the context of conditional probabilities. Ultimately, the goal is to determine the maximum coefficient K for P(A|B∩C) to achieve the tightest upper bound for the inequality.
sabbagh80
Hi everyone,
The problem:
Is this relation true? If so, how (or maybe where) it could be proved?P(A│B∪C)≤P(A│B)+P(A│C)-P(A|BC)
and what about its possible generalization?
thanks a lot in advance.
What about this:
P(x)= 1/8 for x = 1,2,..,8
B = \{ 1,2,3 \}
C = \{ 3,4,5 \}
A = \{2,3,4,6,7,8 \}
so you mean that this inequality is not always true. But of course we have: P(A│B∪C)≤P(A│B)+P(A│C)
Can we find a better upper bound for P(A│B∪C)?
The upper bound of P(A|B\cup C) is when P(A|B) + P(A|C)\geq P(A). Draw Venn diagrams to see why.
You'll have to explain what you are trying to do before anyone will know what "better"means in this context.
Using the idea:
P(X|Y) = P(Y|X) \frac{P(X)}{P(Y)}
and not worrying about the possibility of division by zero, you could try:
P(A| B \cup C) = P(B \cup C | A) \frac{P(A)}{P(B \cup C)}
= \Bigg( P(B|A) + P(C|A) - P(BC| A) \Bigg) \frac{P(A)}{P(B \cup C)}
= \Bigg( P(A|B) \frac{P(B)}{P(A)} + P(A|C) \frac{P(C)}{P(A)} - P(A|BC) \frac{P(BC}{P(A)} \Bigg) \frac{P(A)}{P(B \cup C)}
= P(A|B) \frac{P(B)}{P(B \cup C)} + P(A|C)\frac{P(C)}{P(B \cup C)} - P(A|BC)\frac{P(BC)}{P(B \cup C)}
\leq P(A|B) + P(A|C) - P(A|BC) \frac{P(BC)}{P(B \cup C)}
Another approach is the algebraic realization of a Venn diagram. The possible sets in this problem are: ABC, ABC^c, AB^cC,A^cBC,A^cBC^c,A^cB^cC,A^cB^cC^c
Each probability, such as P(A|B) can be expressed as a fraction involving sums of the probabilities of those sets.
by "better", I mean "tighter" than the derived upper bound. can we further improve this bound?
That doesn't clarify what you want because it doesn't say what quantities are desired on the right hand side.
The equality:
P(A|B \cup C) = P(A|B) \frac{P(B)}{P(B \cup C)} + P(A|C)\frac{P(C)}{P(B \cup C)} - P(A|BC)\frac{P(BC)}{P(B \cup C)}
is "tighter" than any inequality.
The equality:
you are right, I have not explain it precisely.
What I mean is this:
If I want to have both P(A|B) and P(A|C) on the right hand side of inequality and I want to find a coefficient for P(A|BC) such that the obtained expression be the tightest upper bound for the left side expression, what is it?
in other words,
P(A|B \cup C) \leq P(A|B)+P(A|C)-?P(A|B \cap C)
See if I have rephrased you problem correctly:
To find
Max K such that P(A|B \cup C) \leq P(A|B)+P(A|C)- K P(A|B \cap C)
Define:
P_1 = Pr( A B C)
P_2 = Pr( A B C^c)
P_3 = Pr( A B^c C)
P_4 = Pr( A B^c C^c)
P_5 = Pr( A^c B C)
P_6 = Pr( A^c B C^c)
P_7 = Pr( A^c B^c C)
P_8 = Pr( A^c B^c C^c)
The problem becomes: Minimize K subject as a function of the P_i subject to the constraints:
0 \leq P_i \leq 1
\sum_{i=1}^8 P_i = 1
\frac{P_1 + P_2 + P_3}{P_1 + P_2 + P_3 + P_5 + P_6 + P_7} = <br /> \frac{P_1 + P_2}{P_1 + P_2 + P_5 + P_6} + \frac{P_1 + P_3}{P_1 + P_3 + P_5 + P_7} - K \frac{P_1}{P1 + P_5}
in other words,
If B and C are disjoint sets then P(A|B\cup C)=P(A|B)+P(A|C)- (K = P(A|B\cap C)) where K=0.
The maximum value of K will be the maximal intersection of B and C. K is not a coefficient. It is simply the value of the last term on the right side of the equation. Note the maximum value of the left side is when K=0.
Are we using the same notation? For P(X|Y) meaning "the probability of X given Y" we have:
P(B \cup C | A) = P(B|A) + P(C|A) - P(B \cap C | A)
but not
P(A| B\cup C) = P(A|B) + P(A|C) - P(A| B \cap C)
but not
I'm taking the OPs question at face value. As posed, this is question is about the summation of (conditional) probabilities, not a calculation of posterior probabilities.
It seems clear that if B and C are disjoint sets then:
P(A|B\cup C)= P(A|B)+P(A|C).
This would be the maximum value of the left side of the equation which I understand to be the OP's question. It's not clear to me why you replaced the OP's notation with the likelihoods.
In terms of conditional probabilities, an example of what I'm talking about is:
B = \{ 1,2\}
C = \{ 4,5\}
P(A|B \cup C) = \frac{ P(\{2,4\} }{P(\{1,2,4,5\}} = (2/8)/(4/8) = 1/2
P(A|B) = \frac{ P(\{2\})}{P(\{1,2\}} = (1/8)/(2/8) = 1/2
P(A|C) = \frac{ P(\{4\}}{P(\{4,5\})}= (1/8)/(2/8) = 1/2
sabbagh80 can say if he means something different.
I don't know what distinction you are making between probabilities and liklihoods.
but not
The top line of terms above are the likelihoods of the corresponding terms of the bottom line.
I'm satisfied with both comments #5 and #9 (by "Stephen Tashi").
I also thank "SW VandeCarr" for his/her useful discussions.
  • · Replies 0 ·
  • · Replies 16 ·
