[Android] Camera App crashes when run
6 replies · 6K views · last reply
Yoyo_Guru
I am working on an android application that will need to take and store pictures. I'm familiar with java but not with the Android APIs. I tried to start by just including the functions for taking and saving an image using the information on the android developers page(Camera | Android Developers) however when I attempt to run the program it says it had to close. Install is successful though. My activity, preview class and manifest.xml are below. I do not want to use an intent because I will be displaying images and buttons over the preview and be adding buttons to interact wiht the camera. I would really appreciate it if anyone could point out where the problem is or anything like that.
Activity:
Code:
import android.hardware.*;
import android.os.*;
import android.app.*;
import android.widget.*;
import android.view.*;
import android.net.*;
import java.io.*;
import android.util.*;
import java.text.*;
import java.util.*;
import android.hardware.Camera.*;
public class ConverterActivity extends Activity
    private Camera mCamera;
    private CameraPreview mPreview;
private PictureCallback mPicture = new PictureCallback() {
private String TAG;
@Override
public void onPictureTaken(byte[] data, Camera camera) {
File pictureFile = getOutputMediaFile(MEDIA_TYPE_IMAGE);
if (pictureFile == null){
// Log.d(TAG, "Error creating media file, check storage permissions: " +
//  e.getMessage());
return;
try {
FileOutputStream fos = new FileOutputStream(pictureFile);
fos.write(data);
fos.close();
} catch (FileNotFoundException e) {
Log.d(TAG, "File not found: " + e.getMessage());
} catch (IOException e) {
Log.d(TAG, "Error accessing file: " + e.getMessage());
    @Override
    public void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
// Add a listener to the Capture button
Button captureButton = (Button) findViewById(R.id.button_capture);
captureButton.setOnClickListener(
new View.OnClickListener() {
@Override
public void onClick(View v) {
// get an image from the camera
mCamera.takePicture(null, null, mPicture);
        // Create an instance of Camera
        mCamera = Camera.open(this.getBackCamera());
        // Create our Preview view and set it as the content of our activity.
        mPreview = new CameraPreview(this, mCamera);
        FrameLayout preview = (FrameLayout) findViewById(R.id.camera_preview);
        preview.addView(mPreview);
@Override
    protected void onPause()
        super.onPause();
        releaseCamera();              // release the camera immediately on pause event
    private void releaseCamera(){
        if (mCamera != null){
            mCamera.release();        // release the camera for other applications
            mCamera = null;
public static final int MEDIA_TYPE_IMAGE = 1;
public static final int MEDIA_TYPE_VIDEO = 2;
/** Create a file Uri for saving an image or video */
private static Uri getOutputMediaFileUri(int type){
return Uri.fromFile(getOutputMediaFile(type));
/** Create a File for saving an image or video */
private static File getOutputMediaFile(int type){
// To be safe, you should check that the SDCard is mounted
// using Environment.getExternalStorageState() before doing this.
File mediaStorageDir = new File(Environment.getExternalStoragePublicDirectory(
Environment.DIRECTORY_PICTURES), "MyCameraApp");
// This location works best if you want the created images to be shared
// between applications and persist after your app has been uninstalled.
// Create the storage directory if it does not exist
if (! mediaStorageDir.exists()){
if (! mediaStorageDir.mkdirs()){
Log.d("MyCameraApp", "failed to create directory");
return null;
// Create a media file name
String timeStamp = new SimpleDateFormat("yyyyMMdd_HHmmss").format(new Date());
File mediaFile;
if (type == MEDIA_TYPE_IMAGE){
mediaFile = new File(mediaStorageDir.getPath() + File.separator +
"IMG_"+ timeStamp + ".jpg");
} else if(type == MEDIA_TYPE_VIDEO) {
"VID_"+ timeStamp + ".mp4");
} else {
return null;
return mediaFile;
public int getBackCamera()
int numCameras = Camera.getNumberOfCameras();
CameraInfo cInfo = new CameraInfo();
for (int i = 0; i < numCameras; i++)
Camera.getCameraInfo(i, cInfo);
if (cInfo.facing == CameraInfo.CAMERA_FACING_BACK)
return i;
return -1;
Camera Preview:
Code:
import android.content.*;
import java.io.*;
public class CameraPreview extends SurfaceView implements SurfaceHolder.Callback {
    private SurfaceHolder mHolder;
    public CameraPreview(Context context, Camera camera) {
        super(context);
        mCamera = camera;
        // Install a SurfaceHolder.Callback so we get notified when the
        // underlying surface is created and destroyed.
        mHolder = getHolder();
        mHolder.addCallback(this);
        // deprecated setting, but required on Android versions prior to 3.0
        mHolder.setType(SurfaceHolder.SURFACE_TYPE_PUSH_BUFFERS);
    public void surfaceCreated(SurfaceHolder holder) {
        // The Surface has been created, now tell the camera where to draw the preview.
        try {
            mCamera.setPreviewDisplay(holder);
            mCamera.startPreview();
            Log.d(TAG, "Error setting camera preview: " + e.getMessage());
    public void surfaceDestroyed(SurfaceHolder holder) {
        // empty. Take care of releasing the Camera preview in your activity.
    public void surfaceChanged(SurfaceHolder holder, int format, int w, int h) {
        // If your preview can change or rotate, take care of those events here.
        // Make sure to stop the preview before resizing or reformatting it.
        if (mHolder.getSurface() == null){
          // preview surface does not exist
          return;
        // stop preview before making changes
        try {
            mCamera.stopPreview();
        } catch (Exception e){
          // ignore: tried to stop a non-existent preview
        // set preview size and make any resize, rotate or
        // reformatting changes here
        // start preview with new settings
        try {
            mCamera.setPreviewDisplay(mHolder);
            Log.d(TAG, "Error starting camera preview: " + e.getMessage());
Manifest.xml
PHP:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="[PLAIN]http://schemas.android.com/apk/res/android"[/PLAIN]
          package="your.Converter"
          android:versionCode="1"
          android:versionName="1.0" >
     <uses-sdk android:minSdkVersion="10" />
   <uses-permission android:name="android.permissions.CAMERA" />
   <uses-feature android:name="android.hardware.camera" />
   <uses-feature android:name="android.hardware.camera.autofocus" />
     <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
   <application
    android:icon="@drawable/ic_launcher"
    android:label="@string/app_name" >
     <activity
      android:name=".ConverterActivity"
      android:screenOrientation="landscape">
                <intent-filter>
         <action android:name="android.intent.action.MAIN" />
         <category android:name="android.intent.category.LAUNCHER" />
       </intent-filter>
     </activity>
   </application>
   </manifest>
You haven't posted a stack trace, so I'm going to guess that you're having a problem on start-up. The Eclipse plugin (at least for me) doesn't seem to display a useful stack trace in that case - it's all Android internals. However, if you tell it to resume execution (there's a button in the Eclipse toolbar, from memory) your program finishes crashing, and the useful bit of the stack trace appears in the logcat window. You may need to scroll up a bit.
Actually I was using AIDE, and ide on the android, it shows logcat but does not have a way of exporting it. I will run app in eclipse when I get home tonight and add stack trace. I was testing on my phone because I did not know how the virtual device in eclipse would deal with the camera.
Here is logcat errors.
Code:
E(  167) Permission Denial: can't use the camera pid=9354, uid=10009  (CameraService)
E( 9354) FATAL EXCEPTION: main  (AndroidRuntime)
E( 9354) java.lang.RuntimeException: Unable to start activity ComponentInfo{your.Converter/your.Converter.ConverterActivity}: java.lang.RuntimeException: Fail to connect to camera service  (AndroidRuntime)
E( 9354) at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2049)  (AndroidRuntime)
E( 9354) at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2083)  (AndroidRuntime)
E( 9354) at android.app.ActivityThread.access$600(ActivityThread.java:134)  (AndroidRuntime)
E( 9354) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1233)  (AndroidRuntime)
E( 9354) at android.os.Handler.dispatchMessage(Handler.java:99)  (AndroidRuntime)
E( 9354) at android.os.Looper.loop(Looper.java:137)  (AndroidRuntime)
E( 9354) at android.app.ActivityThread.main(ActivityThread.java:4697)  (AndroidRuntime)
E( 9354) at java.lang.reflect.Method.invokeNative(Native Method)  (AndroidRuntime)
E( 9354) at java.lang.reflect.Method.invoke(Method.java:511)  (AndroidRuntime)
E( 9354) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:787)  (AndroidRuntime)
E( 9354) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:554)  (AndroidRuntime)
E( 9354) at dalvik.system.NativeStart.main(Native Method)  (AndroidRuntime)
E( 9354) Caused by: java.lang.RuntimeException: Fail to connect to camera service  (AndroidRuntime)
E( 9354) at android.hardware.Camera.native_setup(Native Method)  (AndroidRuntime)
E( 9354) at android.hardware.Camera.<init>(Camera.java:317)  (AndroidRuntime)
E( 9354) at android.hardware.Camera.open(Camera.java:274)  (AndroidRuntime)
E( 9354) at your.Converter.ConverterActivity.onCreate(ConverterActivity.java)  (AndroidRuntime)
E( 9354) at android.app.Activity.performCreate(Activity.java:4539)  (AndroidRuntime)
E( 9354) at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1049)  (AndroidRuntime)
E( 9354) at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2013)  (AndroidRuntime)
E( 9354) ... 11 more  (AndroidRuntime)
Ok, I found the problem. I said in the manifest,
it should say android.permission, not android.permissions.
Ah. I did wonder if it was permissions, although I was just guessing because the browser on my Android phone isn't rendering the page properly, ironically enough. I always find those strings a risk because they aren't checked or auto-completed by the IDE. I recommend cut-and-paste where possible.
As a side note, you can deploy to a phone from Eclipse just like the emulator. Turn on USB debugging on the phone, plug in and click run in Eclipse. Works on my phone, anyway.
Yeah thanks, I had read about that before. Never got around to setting it up though. And I'm away from my desktop a lot, so it's just easier to do it in AIDE and transfer the files to my desktop or dropbox when I work in Eclipse.
