Angle does it rotate & angular acceleration?
The discussion revolves around solving two physics problems related to angular motion. The first problem involves converting angular speed from revolutions per minute to radians per second and determining the angle rotated in a given time. The second problem requires calculating the angular acceleration of a wheel with a known final angular velocity and displacement over time, emphasizing the need for initial angular velocity. Participants suggest using angular motion equations similar to linear kinematics to find the necessary variables. Understanding the relationship between angular displacement, velocity, and acceleration is crucial for solving these problems effectively.
DrMcDreamy
This is a two part problem, but I don't know what equation to use for part II.
a) A record has an angular speed of 15.4 rev/min. What is its angular speed? Answer in units of rad/s. 1.61 rad/s
b) Through what angle does it rotate in 1.1 s? Answer in units of rad.
What equation am I supposed to use?
A wheel rotating with a constant angular acceleration turns through 11 revolutions during a 6 s time interval. Its angular velocity at the end of this interval is 17 rad/s. What is the angular acceleration of the wheel? Note that the initial angular velocity is not zero. Answer in units of rad/s2.
Just like linear kinematics but for rotations.
Linear: position = x, speed = v
Angular: position = \theta, speed = \omega
So for linear, you know x=x0+vt. Write out the similar equation for rotation and it will give you your angle in radians.
Same concept as before: substitute angular variables for linear ones in linear kinematics equations.
Known: \Delta\theta, t, \omega_f
Want: \alpha
Need: \omega_0 to get \alpha
Work it out in two steps, first one gets you \omega_0 in terms of \alpha, plug that into another equation that relates \Delta\theta to the everything you know so far and then solve for \alpha.
you are going to have use the appropriate angular motion equation
What is the angular motion equation that relates angular displacement with angular acceleration and time?
So it would be: \omega = \omega o + \alpha t
than:
\alpha = \Delta \omega / \Delta t
There are several motion equations to choose from, and which one you use depends upon the problem. In part 1, you have a constant angular speed, and the time is given. You don't have any acceleration, it's a record spinning at a uniform angular speed. In part 2, follow 232thorium's hint.
  • · Replies 17 ·
