Angular Acceleration of a Pulley
To find the angular acceleration of a pulley with a radius of 0.1 m and a moment of inertia of 0.15 kg*m² under a force of 12 N, Newton's second law for rotation is applied. The formula used is angular acceleration = torque / moment of inertia, where torque is calculated as force multiplied by radius. Substituting the values gives angular acceleration = (12 N * 0.1 m) / 0.15 kg*m², resulting in an angular acceleration of 8.0 rad/s². This calculation confirms the correct application of the principles of rotational dynamics. The solution effectively demonstrates the relationship between force, torque, and angular motion.
Cheddar
A cable is around a pulley with:
radius = 0.1 m
moment of inertia = 0.15 kg * m(squared)
The cable receives a pull of:
force = 12 N
Find the magnitude of the resulting angular acceleration of the puller.
Average angular acceleration = Change in angular velocity / Elapsed time
Average angular velocity = Angular displacement / Elapsed time
I'm completely stuck since none of the given information can be used in the equations listed above.
Hint: Consider Newton's 2nd law for rotation.
Thanks, I think I have it. So:
angular acceleration = 12 * 0.10 / 0.15 = 8.0 rad/s(squared)
You got it.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 18 ·
  • · Replies 32 ·
